ULYCÒô²æÒºÎ»¿ª¹Ø TUNING FORK LEVEL SWITCH
¡ô¸ÅÊö GENERAL
ULYCÒô²æÊ½Îïλ¿ª¹ØÒ²½ÐµçÆø¸¡×Ó¿ª¹Ø,²»ÊܽéÖÊÃܶÈÓ°Ïì,ÊÊÓÃÓÚ½¢´¬¼°»¯¹¤É豸ÖжԲֹñÄÚ½éÖÊҺλ»òÁÏλ½øÐÐÁ½Î»Ê½¿ØÖƺͱ¨¾¯¡£
ULYC tuning fork level switch is also called the electric float switch, is not affected by the medium density,applicable to ships and chemical equipment to warehouse in medium contained in the cabinet Liquid level or material level for two type control and alarm.
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
ÐͺŹæ¸ñModel:ULYC
²âÁ¿·¶Î§Measuring range:100¡«2000(mm)
°²×°ÐÎʽMounting type:¶¥×°Top mounting/²à×° Horizontal mounting
¹«³ÆÑ¹Á¦PN:≤1MPa
½éÖÊζÈMedium temp:≤120¡æ
µçÔ´µçѹPower voitage:AC220V/DC24V
Êä³öÐźÅOutput:µ¥µ¶Ë«ÖÀSPDT
Íâ¿Ç·À»¤Protection:IP65
