SETSXRD30ϵÁе¼²¨À×´ïÎïλ¼ÆSERIES OF GUIDED WAVE RADAR LEVEL METER
¡ô¸ÅÊö GENERAL
µ¼²¨À×´ïÊÇ»ùÓÚʱ¼äÐгÌÔÀíµÄ²âÁ¿ÒÇ±í£¬À״ﲨÒÔ¹âËÙÔËÐУ¬ÔËÐÐʱ¼ä¿ÉÒÔͨ¹ýµç×Ó²¿¼þ±»×ª»»³ÉÎïλÐźš£Ì½Í··¢³ö¸ßƵÂö³å²¢ÑØÀÂʽ̽ͷ´«²¥£¬µ±Âö³åÓöµ½ÎïÁϱíÃæÊ±·´É仨À´±»ÒDZíÄڵĽÓÊÕÆ÷½ÓÊÕ£¬²¢½«¾àÀëÐźÅת»¯ÎªÎïλÐźš£
Guided wave radar is based on the principle of time travel is measuring instrument, radar wave are running at the speed of light,Running time can be transformed into material level signal by electronic parts. The probe sends out high frequency pulse along Cable type probe transmission, when the pulse in the material surface reflected by the instrument of receivers
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
ÐͺÅModel
SXRD31
SXRD32
SXRD33
SXRD34
SXRD35
SXRD36
²âÁ¿·¶Î§Measuring range
35m
6m
35mÀÂʽcable type
6m
¾«¶ÈAccuracy
3mm
Á¬½Ó·½Ê½connection method
ÂÝÎÆ/·¨À¼ Thread/flange: G1 1/2”/ DN40-DN250
¹¤×÷ζÈWorking temperature
-40¡«250¡æ
-200¡«400¡æ
-40¡«180¡æ
¹¤×÷ѹÁ¦working Pressure
-0.1¡«2MPa
-0.1¡«40MPa
-0.1¡«2MPa
ƵÂÊ·¶Î§ Frequencyrange
100Hz¡«1.8GHz
Êä³öÐźÅoutput signal
DC24V 4¡«20mA/HART(Á½Ïß/ËÄÏß)(two line/four line)
·À»¤Protection
IP67
·À±¬explosive-proof
ExiaIICT6 Ga
Ó¦ÓÃapplication
ÒºÌå,¹ÌÌå·ÛÁÏ
Liquid, solid
powder
ÒºÌå
Liquid
¹ÌÌå·ÛÁÏ,½éµç
³£Êý½ÏµÍµÄÒºÌå
Solid powder, low
dielectric constant
of the liquid
ÒºÌå
Liquid
¸¯Ê´ÐÔÒºÌå
corrosive liquid
½éµç³£ÊýµÍ»ò±í
Ãæ²¨¶¯ÒºÌå
Low dielectric
constant liquid
or liquid surface
waves
