YSZK-01LÐÍѹÁ¦Ê½ÒºÎ»´«¸ÐÆ÷PRESSURE TYPE LEVEL TRANSMITTER
¡ô¸ÅÊö GENERAL
ѹÁ¦Ê½ÒºÎ»´«¸ÐÆ÷Ö÷ÒªÓÉ´«¸ÐÆ÷¡¢ÐźŷŴóÆ÷µÈ×é³É¡£ÊÊÓÃÓÚ³ÖÐø²âÁ¿Ñ¹Ôزա¢³ÔË®¼ÆÒÔ¼°È¼ÓͲյȶàÖÖ½éÖʵÄҺλ¡£°²×°ÔÚÒº²Õµ×²¿µÄ´«¸ÐÆ÷¿É¼°Ê±¸ÐÓ¦ÓÉÓÚҺλ±ä»¯ÒýÆðµÄѹÁ¦±ä»¯£¬²¢½«Ñ¹Á¦±ä»¯×ª»»³ÉµçÐźţ¬Í¨¹ýµçÀ´«Ë͸øÐźŷŴóÆ÷£¬Êä³ö4-20MAa(Á½ÏßÖÆ)Ö±Á÷ÐźÅ,´ËÐͺſÉÓÉҺλÏÔʾ
Æ÷Ö±½ÓÏÔʾҺλµÄÊýÖµ,²¢¿ÉÓÉ×°ÔØ¼ÆËã»úÏÔʾºÍ¿ØÖƲչñµÄҺλ¡£
Pressure type level transmitter consists of transmitter,signal amplifier etc.It is user for continously measuring the liquid level of ballast tank,draft and fuel oil tank.The pressure type transmitter in the liquid tank bottom can timely sense the pressure change due to the height change,and change the level height signal into pressure electric signal.The output signal is changed into 4-20mA(two-wire)DC level signal via amplifier.The level signal is transformed to the level indicator in the control panel via safety barrier,or tank level is indicated and controlled by loading computer
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
²âÁ¿·¶Î§ L Measuring range:0-50m(¿ÉÑ¡option)
°²×°¸ß¶È H Installation height:£¼²âÁ¿·¶Î§L Measuring range
²âÁ¿¾«¶È Accuracy:0.5%F.S
µçÔ´µçѹ Power supply:DC:24V 10%
Êä³öÐźŠOutput:4-20mA (HART)
¹¤×÷ÎÂ¶È Working temp:40-80¡æ
ÊÊÓýéÖÊ Medium application:Ë®¡¢È¼ÓÍ¡¢²ñÓÍ¡¢»¬ÓÍWater.F.O.,D.O.,L.O.
²Ä ÁÏ Material:SUS304 SUS316L
Á¬½Ó·¨À¼ Conn.flange:GB2506-89
·À»¤µÈ¼¶ Protection:IP66/IP68
·À±¬ÐÍʽ Explosion proof type:ExiaIIBT6 Ga/Gb
¡ôÓÃ; APPLICATION
1¡¢ºáÇã²ÕҺλң²â Heeling and trim remote reading
2¡¢²Õ´¬³ÔË®Éî¶ÈÒ£²â Draft remote reading
3¡¢Ñ¹ÔزÕҺλң²â Ballast tank remote reading
4¡¢È¼ÓͲÕҺλң²â Fuel oil tank remote reading
