SXRD90ϵÁÐ¸ßÆµÀ×´ïÎïλ¼Æ HIGH FREQUENCY RADAR LEVEL METER
¡ô¸ÅÊö GENERAL
SXRD90ϵÁд«¸ÐÆ÷ÊÇ26G¸ßƵÀ×´ïʽÎïλ²âÁ¿ÒÇ±í£¬Êä³ö4-20mAÄ£ÄâÐźţ¬²âÁ¿×î´ó¾àÀë¿É´ï70Ãס£ÌìÏß±»½øÒ»²½ÓÅ»¯´¦Àí£¬ÐÂÐ͵ĿìËÙµÄ΢´¦ÀíÆ÷¿ÉÒÔ½øÐиü¸ßËÙÂʵÄÐźŷÖÎö´¦Àí£¬Ê¹µÃÒDZí¿ÉÒÔÓÃÓÚÈ磺·´Ó¦¸ª»ò¹ÌÌåÁϲַdz£¸´ÔӵIJâÁ¿Ìõ¼þ¡£
SXRD90 series sensors are 26 g hf radar level meter, 4-20 ma analog output, maximum distance measurement can reach 70 meters. Antenna is further optimization, new type of fast microprocessors can undertake higher rate of signal analysis and processing, make the instrument Table can be used for such as: the reaction kettle or solid bin very complicated measurement conditions.
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
ÐͺÅModel
SXRD91
SXRD92
SXRD93
SXRD94
SXRD95
SXRD96
²âÁ¿·¶Î§Measuring range
20m
30m
70m
35m
20m
¾«¶ÈAccuracy
±3mm
±2mm
±15mm
±3mm
±2mm
Á¬½Ó·½Ê½connection method
ÂÝÎÆ/·¨À¼ Thread/flange: G1 1/2”/ DN40-DN250
·¨À¼ flange
¹¤×÷ζÈWorking temperature
-60¡«120¡æ
-60¡«250¡æ
-60¡«150¡æ
¹¤×÷ѹÁ¦working Pressure
-0.3¡«0.3MPa
-0.1¡«4MPa
³£Ñ¹ Atmospheric pressure
ƵÂÊ·¶Î§ Frequencyrange
26GHz
Êä³öÐźÅoutput signal
DC24V 4¡«20mA/HART(Á½Ïß/ËÄÏß)(two line/four line)
·À»¤Protection
IP67
·À±¬explosive-proof
ExiaIICT6 Ga
Ó¦ÓÃapplication
ÒºÌå,¹ÌÌå·ÛÁÏ
Liquid, solid
powder
ÒºÌå
Liquid
¹ÌÌå·ÛÁÏ,½éµç
³£Êý½ÏµÍµÄÒºÌå
Solid powder, low
dielectric constant
of the liquid
ÒºÌå
Liquid
¸¯Ê´ÐÔÒºÌå
corrosive liquid
½éµç³£ÊýµÍ»ò±í
Ãæ²¨¶¯ÒºÌå
Low dielectric
constant liquid
or liquid surface
