YSZKÐÍ´¬ÓÃѹÁ¦´«¸ÐÆ÷MARINE PRESSURE TRANSMITTER
¡ô¸ÅÊö GENERAL
YSZKÐÍѹÁ¦´«¸ÐÆ÷ÓÉÀ©É¢¹èѹÁ¦¸ÐÓ¦Æ÷ºÍÐźÅת»»µç·×é³É,¾ßÓвâÁ¿¾«¶È¸ß¡¢Îȶ¨¿É¿¿¡¢Ìå»ýС°²×°·½±ãµÈÌØµã.ÓÃÓÚ½¢´¬¼°ÆäËü¹¤ÒµÉ豸ÖвâÁ¿¸÷ÖÖÒºÌå\ÆøÌå½éÖʵÄѹÁ¦¡£
YSZK type electric pressure sensor consist of diffuse silicon pressure inductor and signal transform circuit,which the characteristics of high measuring precision,dependable stability,small cubage,convenience installation.it is to measure pressure of kinds of medium of liquids,gas in ship and other industrial equipment,
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
µçÔ´µçѹ Power voltage:DC24V
Êä³öÐźŠOutput signal:DC24V 4-20mA(¶þÏßÖÆ)
²âÁ¿¾«¶È Measuring accuracy:0.5%
¹¤×÷ÎÂ¶È Working temp:-20¡æ¡«70¡æ
¿¹¹ýÔØÄÜÁ¦ Over load:2.5±¶Á¿³Ì,250% above max range
½Ó¿ÚÂÝÎÆ³ß´ç Press connection size:M20*1.5¡¢G 1/4” G 1/2”
·À»¤µÈ¼¶ Protection:IP66
·À±¬±êÖ¾ Explosion proof:ExiaIICT6 Ga/Gb
¡ô²âÁ¿·¶Î§ MEASURING RANGE
ÐÎʽType
²âÁ¿·¶Î§Measure range(MPa)
±íѹÐÍGauge type
-0.1¡«0.1¡¢-0.1¡«0¡¢0¡«0.10¡¢0¡«0.16¡¢0¡«0.25¡¢0¡«0.40¡¢0¡«0.60¡¢0¡«1.0¡¢0¡«1.6¡¢0¡«2.5¡¢0¡«4.0¡¢0¡«6.0¡¢0¡«10¡¢0¡«16¡¢0¡«25¡¢0¡«40¡¢0¡«60
¾øÑ¹ÐÍAbs.type
²îѹÐÍSeal type
0¡«0.01¡¢0¡«0.02¡¢0¡«0.05¡¢0¡«0.10¡¢0¡«0.20¡¢0¡«0.50¡¢0¡«1.0¡¢0¡«2.0
