ULB-3ÐÍ´¬ÓÃ˫ɫ²£Á§°åҺλ¼Æ MARINE FLAT TYPE GLASS LEVEL GAUGE
¡ô¸ÅÊö GENERAL
ULB-3ÐÍ´¬ÓÃ˫ɫ²£Á§°åҺλ¼ÆÊÊÓÃÓÚ½¢´¬¼°ÆäËü¹¤ÒµÉ豸ÖжԲչñÄÚ½éÖʵÄҺλ½øÐвâÁ¿¡£
ULB-3 type marine flat type glass level gauge is used to measure level of the tank in ship and other industrial instrument .
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
ÖÐÐľ೤¶ÈL£¨¿ÉÑ¡£©Center to center length L(mm)(²£Á§°åÊýÁ¿£¨¿é£©Glass plate No)
ULB-3A L=360(1¿é£©L=650(2¿é£©L=940(3¿é£©L=1230(4¿é£©
ULB-3B L=1520(5¿é£©L=1810(6¿é£©L=2100(7¿é£©L=2390(8¿é£©L=2680(9¿é£©L=2970(10¿é£©
L=3260(11¿é£©L=3550(12¿é£©L=3840(13¿é£©L=4130(14¿é£©L=4420(15¿é£©L=4710(16¿é£©
¹«³ÆÑ¹Á¦ Nominal pressure£º0.2MPa
ÊÔÑéѹÁ¦ Test pressure:0.5MPa
¹¤×÷ÎÂ¶È Working temoerature:0-80¡æ
ÊÊÓýéÖÊsuitable medium£ºË®»òÉÁµã´óÓÚ65°µÄÓÍwater or oil flash point is greater than 65 degrees
²ÄÁÏMaterial Science:×Ô±Õ·§-ͺϽð,Ö÷Ìå-304/Q235A,²£Á§°å-Åð¹è²£Á§ Self-ciosing Valve-copper alloy,Body-304/Q235A,Glass plate-Boron sililcon glass
