ULGÐÍ´¬Óò£Á§¹ÜҺλ¼Æ MARINE TUBULAR TYPE GLASS LEVEL GAUGE
¡ô¸ÅÊö GENERAL
ULGÐÍ´¬Óò£Á§¹ÜҺλ¼ÆÉè¼ÆÐÂÓ±£¬°²×°·½±ã£¬ÊÊÓÃÓÚСÐͲչñÄÚµÍÕ³¶È½éÖʵÄҺλ²âÁ¿¡£
ULG type tubular glass level gauge which has the characteristic of designing novelty £¬installing
conveniently is used to measure low viscosity medium’s level in miniature tank.
¡ô¼¼Êõ²ÎÊý TECHNICAL SPECIFICATION
ÐͺÅModel£ºULG
ÖÐÐľàL(mm)Center to center length£º300-1900mm
×î´ó¹¤×÷ѹÁ¦Max working pressure:0.5MPa
¹¤×÷ζÈWorking temperature£º0-100¡æ
ÊÊÓýéÖÊMedium£ºÓÍ,Ë®OIL,WATER
½Ó¿ÚÐÎʽConnecting type£ºº¸½Óʽ£¨HÐÍ£©Weld type(H type£©·¨À¼Ê½£¨F£©GB573-65 Dn20 PN16
Flange(F)GB573-65 DN20 PN16
²úÆ·ÌØÕ÷ Product characteristic£ºµ±²£Á§¹ÜÒâÍâÆÆÁÑʱ£¬ÄÚÖ÷§ÃÅ¿É×Ô¶¯¹Ø±Õ£¬ÎÞÒºÌåÉøÂ©
When the glass tube breaks accidentally the inside valve can close automatically without liquid leakage
