http://www.gkong.com 2026-10-26 15:55 深圳市正运动技术有限公司
展前资讯
Pre-show News
11月4日至6日,VIAF &VIMF NORTHERN 2026将在越南北宁省京北会展中心(KBCC)举办。正运动技术将亮相944展位,展出运动控制核心产品和“产品+工艺包”解决方案,进一步拓展越南市场。
依托多年海外市场拓展经验,正运动技术已与越南本地合作伙伴建立稳定合作关系。双方整合自主技术与本地化服务资源,携手为当地设备制造商及系统集成商提供技术支持、工艺适配与项目实施服务,推动产品及解决方案在越南实际生产场景中的落地应用。
VIAF &VIMF NORTHERN 2026 will be held from November 4 to 6 at KBCC – Kinh Bac Cultural Center. Zmotion Technology will be at Booth 944, showcasing core motion control products and “Product + Process Package” solutions to further expand the Vietnamese market.
Drawing on years of overseas development experience, Zmotion Technology has established stable partnerships with local Vietnamese collaborators. Together, we leverage proprietary technology and localized service resources to deliver technical support, process adaptation and project implementation services for local manufacturers and system integrators, accelerating the on-site deployment of our products and solutions in Vietnamese production scenarios.
VIAF &VIMF 2026
[ 展会看点 ]
-- Exhibition Points --
核心产品展示
Core Product Showcase
纯国产运动控制实时内核 MotionRT750
Self-Developed Real-Time Motion Control Kernel – MotionRT750
x86/ARM 工控机( IPC )
跨平台运动控制实时内核,自主自研x86/ARM Windows/Linux独占CPU运动控制实时内核。
MotionRT750 is a real-time motion control kernel developed by Zmotion, featuring cross-platform support (x86/ARM, Windows/Linux) and a dedicated CPU core for hard real-time tasks.
Hard real-time (Minimal EtherCAT control cycle:50μs)
ECAT sync cycle:125us for 32 axes;250us for 64 axes;
Sync cycle for multi-PCIe card &multi-ECAT channel:500µs for 254 axes;
1-6 independent masters:configurable with separate EtherCAT communication cycles;
Compatible with third-party IPCs.
⊙ Integrated high-speed I/O control &real-time motion control.
⊙ Enhanced reliability:continues operation upon host PC crash.
⊙ Built-in C-language runtime for real-time computation acceleration.
配合实时内核使用的PCIe EtherCAT运动控制卡
PCIe EtherCAT Motion Control Cards (with Real-Time Kernel)
(1)XPCIE1032H
可选6-64轴运动控制。
motion control for 6-64 axes.
(2)XPCIE2032H
可选6-254轴运动控制,双EtherCAT支持分区并行控制,可设置为高速(125us)与常规通信周期(250us-8ms),支持环网拓扑 冗余 。
motion control for 6-254 axes.Equipped with dual EtherCAT channels for partitioned parallel control;configurable for high-speed (125µs) and standard communication cycles (250µs–8ms).Supports EtherCAT ring redundancy.
(3)XPCIE6032H
可选6-254轴运动控制,EtherCAT支持分区并行控制,支持2路环网拓扑冗余,适用于 具身机器人 、多足机器人、EtherCAT总线设备群协同控制产线。
motion control for 6-254 axes.It features EtherCAT partitioned parallel control with dual-ring redundancy.Ideal for humanoid robots, legged robots and production lines with coordinated EtherCAT device groups.
配合实时内核使用的VPLC7系列机器视觉运动控制一体机
VPLC7XX Machine Vision Motion Controllers (with Real-Time Kernel)
6-64轴运动控制,支持冗余功能,提供一体化开放式IPC形态的实时软控制器/软PLC集成的视觉+运动控制解决方案。
配备多以太网口、串口、IO等接口,可灵活连接传感器、执行器、工业相机等设备,实现多类型信号与数据的快速采集,可满足机器视觉应用的集成需求。
It supports motion control for 6–64 axes with ECAT redundancy, delivering an all-in-one vision and motion control solution based on an open IPC-style real-time soft controller/soft PLC.
Featuring abundant Ethernet, COM and I/O interfaces for sensors, actuators and industrial cameras, it enables rapid multi-signal acquisition and data collection.For Integrated Machine Vision and Motion Control Applications.
典型行业解决方案
Typical Industry Solutions
通用机械手视觉柔性上下料解决方案
General Manipulator Vision-based Flexible Loading/Unloading Solution
(1)使用产品
Hardware Product
VPLC7系列机器视觉运动控制一体机
VPLC7XX series machine vision motion controller
(2)方案优势
Solution Advantages
支持PSO硬件位置比较、视觉飞拍;
提供标准机械手柔性上下料工艺包;
高集成“运动控制+视觉+IO+机械手+通讯”;
多机械手结构柔性供料工艺包,可复用,即插即用;
用户可自定义功能扩展,后期可灵活扩展附加轴;
可视化操作界面,轻松应对高混料小批量换型生产。
Supports PSO (hardware position comparison output), vision fly-shooting;
Provides a standard process package for manipulator flexible loading/unloading;
High integration:motion control + vision control + I/O control + manipulator control + diverse communication protocols;
Reusable, plug-and-play process package for multi-manipulator flexible feeding;
Supports user-defined function expansion for flexible additional-axis extension;
Visual HMI optimized for high-mix low-volume product changeover.
(3)兼容各类型机械手柔性上下料工作站
Compatible with Various Manipulators for Flexible Loading &Unloading
通用视觉点胶解决方案
General Vision-based Dispensing Solution
(1)使用产品
Hardware Product
VPLC7系列机器视觉运动控制一体机
(2)方案优势
Solution Advantages
提供易用的可视化视觉点胶开发调试软件;
支持高速锁存、PWM、多维PSO硬件位置比较输出;
支持局部视野/全景视野采图,自动识别完成点胶作业;
“视觉+运动控制”软硬件高度集成,总拥有成本( TCO )低;
提供标准工艺包,具备点胶工艺参数设置和程序编辑所需功能。
User-friendly software for vision dispensing development and debugging;
Adaptive speed look-ahead, trajectory smoothing, short-segment smoothing;
Supports high-speed latching, PWM and multi-dimensional PSO (hardware position comparison output);
Enables local / global FOV image acquisition, automatic recognition;
All-in-one integration of "vision + motion control"and "hardware + software"for low TCO;
Standard dispensing process package available, supporting parameter configuration and program editing.
(3)兼容不同的在线式/桌面离线式点胶设备
Compatible with Various Desktop Dispensing Equipment (Online / Offline)
同步跟随点胶: 支持XYZ+R轴联动+皮带控制;
静态点胶: 支持XYZ+R轴联动+双Y工位加工,共5轴;
五轴联动点胶: 支持XY1Z+A1C1轴联动+第二工位Y2A2C2,共8轴。
Sync-following dispensing:XYZ+R axis linkage with conveyor belt tracking control;
Static dispensing: XYZ+R axis linkage for dual-Y station processing, 5 axes in total;
5-axis linkage dispensing: XY1Z+A1C1 linkage with secondary station Y2A2C2, 8 axes in total.
展馆指引图
-- Booth Layout Map --
观众预登记
Visitor Pre-registration QR Code
结语
此次亮相VIAF &VIMF NORTHERN 2026展会,是正运动服务越南及东南亚市场的新契机,也为中越工业自动化领域的技术交流与务实合作搭建沟通桥梁。
未来,正运动技术将持续深耕核心技术研发,优化产品矩阵,以更好地适配不同区域智能制造多元化需求,提供更具针对性的定制化解决方案,助力智能制造更快、更准、更智能,以优质产品与专业服务链接更多新行业合作伙伴。
This participate in the VIAF &VIMF NORTHERN 2026 exhibition presents a new opportunity for Zmotion to serve customers in Vietnam and the broader Southeast Asian market. It also creates a platform for technical exchanges and practical industrial automation cooperation between China and Vietnam.
Moving forward, Zmotion Technology will continue to invest in core R&D and refine its product portfolio to address the diverse smart manufacturing demands across regions. We will provide more tailored solutions to support faster, higher-precision and smarter manufacturing. By offering reliable products and professional technical support, we look forward to forging partnerships with more industry partners.
正运动技术专注于运动控制技术研究和通用运动控制软硬件产品的研发,是国家级高新技术企业。正运动技术汇集了来自华为、中兴等公司的优秀人才,在坚持自主创新的同时,积极联合各大高校协同运动控制基础技术的研究。主要业务有:运动控制卡_运动控制器_EtherCAT运动控制卡_EtherCAT控制器_运动控制系统_视觉控制器__运动控制PLC_运动控制_机器人控制器_视觉定位_XPCIe/XPCI系列运动控制卡等等。
