1W , Miniature SIP, Single & Dual Output DC/DC Converters
TFEATURES T
● Efficiency up to 82%
● 1000VDC /3000VDC Isolation
● MTBF > 2,000,000 Hours
● Low Cost
● Input 5, 12, 15 and 24VDC
● Output 3.3,5,9,12,15and24
● Temperature Performance -40℃to +85℃
● UL 94V-0 Package Material
● Internal SMD Construction
● Industry Standard Pinout
Block Diagram
Single Output Dual Output
ABSOLUTE MAXIMUM RATINGS
Short-circuit protection |
1Second |
Lead temperature 1.5mm from case for seconds |
300℃ |
Intermal power dissipation |
450mW |
Input voltage Vin, B(F)05types |
7V |
Input voltage vin,B(F)12 types |
15V |
Input voltage vin,B(F)15 types |
18V |
Input voltage vin,B(F) 24 types |
28V |
Model Selection Guide
Model Number
Input Voltage
Input Current
Output
Voltage
Output Current |
Efficiency
Max Load |
No Load |
Max Load |
VDC |
mA(typ) |
mA(typ) |
VDC |
mA(max) |
%(typ) |
B(F)0503LS-1W |
5(4.5~5.5)
236 |
30 |
3.3 |
260 |
73 |
B(F)0505LS-1W |
280 |
5 |
200 |
71 |
B(F)0509LS-1W |
260 |
9 |
110 |
76 |
B(F)0512LS-1W |
258 |
12 |
84 |
78 |
B(F)0515LS-1W |
257 |
15 |
67 |
78 |
B(F)0524LS-1W |
255 |
24 |
42 |
79 |
B(F)1203LS-1W |
12(10.8~13.2) |
97 |
14 |
3.3 |
260 |
74 |
B(F)1205LS-1W |
113 |
5 |
200 |
73 |
B(F)1209LS-1W |
106 |
9 |
110 |
78 |
B(F)1212LS-1W |
105 |
12 |
84 |
80 |
B(F)1215LS-1W |
104 |
15 |
67 |
80 |
B(F)1224LS-1W |
102 |
24 |
42 |
81 |
B(F)1503LS-1W |
15(13.5~16.5) |
78 |
11 |
3.3 |
260 |
74 |
B(F)1505LS-1W |
94 |
5 |
200 |
72 |
B(F)1509LS-1W |
84 |
9 |
110 |
79 |
B(F)1512LS-1W |
84 |
12 |
84 |
79 |
B(F)1515LS-1W |
84 |
15 |
67 |
80 |
B(F)1524LS-1W |
82 |
24 |
42 |
81 |
B(F)2403LS-1W |
24(21.6~26.4) |
49 |
8 |
3.3 |
260 |
73 |
B(F)2405LS-1W |
59 |
5 |
200 |
71 |
B(F)2409LS-1W |
54 |
9 |
110 |
76 |
B(F)2412LS-1W |
54 |
12 |
84 |
78 |
B(F)2415LS-1W |
53 |
15 |
67 |
79 |
B(F)2424LS-1W |
52 |
24 |
42 |
81 |
Input Specifications
Parameter |
Model |
Min |
Typ |
Max |
Unit |
Input voltage |
5 |
4.5 |
5 |
5.5 |
VDC |
12 |
10.8 |
12 |
13.2 |
15 |
13.5 |
15 |
16.5 |
24 |
21.6 |
24 |
26.4 |
Reverse Polarity Input Current |
All models |
0.3 |
A |
Input Filter |
Internal Capacitor |
Output specifications
Parameter |
Conditions |
Min |
Typ |
Max |
Unit |
Output Voltage Accuracy |
±1.0 |
±3.0 |
Output Voltzge Balance |
Dualoutput Balanced Loads |
±0.1 |
±1.0 |
Line Regulation |
For Vin Change of 1% |
±1.2 |
±1.5 |
Load Regulation |
Io=20% to 100% |
8 |
10 |
Ripple﹠Noise(20MHz) |
5~15V Output |
50 |
75 |
mVP-P |
18~24 |
150 |
Over Line,Load﹠Temp |
200 |
mVP-P |
10 |
mVrms |
Over Load |
120 |
Tenperature Coefficient |
±0.01 |
±0.02 |
Output Short Circuit |
1 Second |
General Specifications
Parameter |
Conditions |
Min |
Min |
Typ |
Max |
Unit |
B Series |
F Series |
Isolation Voltage Rated |
60 Seconds |
1000 |
3000 |
VDC |
Isolation Voltage Test |
Flash Tested for
1 Second |
1000 |
3000 |
VAC |
Isolation Resistance |
500VDC |
1000 |
1000 |
MΩ |
Isolation Capacitance |
100KHz,1V |
60 |
100 |
pF |
Switching Frequency |
70 |
70 |
100 |
120 |
KHz |
MTBF |
MIL-HDBK-217F@25℃,Ground benign |
2000 |
2000 |
K Hours |
Environmental Specifications
Paramerter |
Conditions |
Min |
Typ |
Max |
Unit |
Operating Tenoeratuer |
Anbient |
-40 |
+85 |
Operating Tenperature |
Case |
-40 |
+90 |
Storage Temprerature |
-40 |
+125 |
Humidity |
95 |
Cooling |
Free-Air convection |
MECHANICAL DIMENSIONS TUBE OUTLINE DIMENSIONS
B Series F Series
RECOMMENDED FOOTPRINT DETAILS RECOMMENDED FOOTPRINT DETAILS
Pin Connection Physical Characteristics
Case Size : 19.6×6.0×10mm
Pin |
B Series |
F Series |
1 |
+Vin |
+Vin |
2 |
-Vin |
-Vin |
4 |
-Vout |
No Pin |
5 |
No Pin |
-Vout |
6 |
+Vout |
No Pin |
7 |
No Pin |
+Vout |
(5~15V Input) 0.77×0.24×0.394 inches
Case Size : 19.6×7.0×10mm
(18~24DC Input) 0.77×0.26×0.394 inches
Case Material : Non-Conductive Black Plastic
Weight : 2.2g ± 0.2g (5~15V Input)
2.6g ± 0.2g (18~24DC Input)
