MVC-1000A1/MVC-1000D1显微硬度计造型新颖、美观、而且它具有良好的可靠性,可操作性和直观性。内置硬度计 |
算器,可通过输入压痕对角线长度,直接在LCD屏幕上显示硬度值。 |
该机采用高倍率光学测量系统,目镜鼓轮一次读数。可测定钢、有色金属、IC薄片、薄塑料、金属薄片、涂层、 |
表面覆层、层压金属、热处理碳化层和淬火硬化层的深度与硬度梯度。 |
The MVC-1000A1 type counts to show the degree of hardness accounts the shape novel and |
beautiful,and it have the good and dependable,maneuverability with keep the view.the inside places |
the degree of hardness calculator,can pass the importation press the diagonal line length,direct |
the manifestation degree of hardness is worth in LCD holding the act. |
That machine adopts the high magnification optics the diagraph the system,the eyes drum round |
is a to read the number.Can measurese the steel,have the color metals,the thin slice of IC,thin |
plastics,metals thin slice and draw the layer,surface layer,layer press the metals,heat handles |
the carbonization layer hardens the depth of the layer with the fire of and degree of hardness |
steps degree. |
MVC-1000A1显微硬度计(手动转塔)技术参数: |
技术规格 |
Main technical parameters |
显微硬度标尺:HV0.01,HV0.025,HV0.05,HV0.1,HV0.3,HV0.5,HV1 |
Vickers scales:HV0.01,HV0.025,HV0.05,HV0.1,HV0.3,HV0.5, HV1 |
显示:保持时间(秒),硬度值 |
Display: dwell time(s),Hardness |
试验力(gf):10,25,50,100,200,300,500,1000 |
Test force(gf):10,25,50,100,200,300,500,1000 |
加载控制:自动(加载/保持/卸载) |
Load control:automatic(loading/dwell/unload) |
试验力保持时间(s):5~60 |
Total test force dwell time(S):5~60 |
试验力选择:外置式选力旋钮,试验力自动显示在LCD屏上 |
Test force selection:External force election knob |
the test showed strength in LCD screen |
物镜:10×,40× |
Objective magnification:10×,40× |
目镜放大倍数:10× |
Eyepiece magnification:10× |
总放大倍数(μm):100×(观察), 400×(测量) |
Total magnification:100×(Observation), 400×(measurement) |
测量范围(μm):200 |
Measuring range(μm):200 |
分辨率(μm):0.5 |
Resolution(μm):0.5 |
XY试台 尺寸(mm):100×100 |
XY stage Dimensions(mm):100×100 |
行程范围(mm):25×25 |
Travel range(mm):25×25 |
最小读数(mm):0.01 |
Minimum reading: 0.01 |
试件最大高度(mm):85(2.55") |
Max height of speciments(mm):85(2.55") |
试件最大宽度(mm):120(3.35")(从压头中心线至机壁距离) |
Distance from indeneter''s center to outerwall(mm):120 |
电源电压:AC220V/50HZ |
Power supply:AC220V/50HZ |
外形尺寸(mm):490×310×515 |
Dimensions(mm):490×310×515 |
重量(kg):35 |
Weight(kg):35 |
