Product Overview
A690E-I2 is equipped onboard ATI Radeon X1270, provides
the excellent graphic performance. Dual View function is also
supported via VGA, HDMI and LVDS. It is the outstanding solution
for primary Digital Signage application. For slim chassis, A690EIS
also has a remarkable cooler option particularly for 1U chassis.
Specifications
System
CPU Socekt AM2 support Athlon64/FX/X2
Sempron / Turion 64(TDP max up to 65W)
Chipset M690E+SB600
System memory 2 x 200pin DDR2 533/667 SO-DIMM max up to 4GB
BIOS Award 8Mb Flash ROM
Watchdog Timer Reset: 1~255 sec
H/W Monitor CPU voltage
CPU & System Temperature
CPU & System fan speed
CPU fan speed control
Expansion 1 x PCI slot
Display
Chipset ATI Radeon X1270 graphics engine
Display Memory Shared system memory up to 512MB video memory
Resolution VGA: Max. up to 2048 x 1536
HDMI: Max. up to 1920 x 1080
LVDS: Dual-channel, 24bit
I/O
MIO 1 x IDE, 2 x SATA II, 2 x RS-232,
1 x PS/2 Keyboard/ Mouse
Ethernet 1 x Realtek RTL8111C for PCI-e Gigabit LAN
Audio Realtek ALC662 suppot 5.1CH Audio
USB 10 x USB 2.0 ports(4 via pin-header)
Power Type ATX
Temperature 0¡ãC ~ 55¡ãC, Operating
Humidity 10% ~ 90%, Operating
Size(L x W) 170mm x 170mm (6.69¡± x 6.69¡±)
Mechianical & Environmental
Packing
IDE Cable x 1
SATA Cable x 1
I/O Bracket x 1
CD Driver x 1
Features
AMD Socket AM2 support Athlon 64, Athlon 64 x 2, Sempron
Special CPU cooler(up to 35W) for 1U chassis solution
Onboard ATI Radeon X1270 supply excellent graphics solution
for Digital Signage market
2 x DDR2 533/667 SO-DIMM up to 4GB
Dual view support via VGA/HDMI/ 24bit LVDS
PCI slot expansion
One Gigabit LAN, 2 x COM, 10 x USB 2.0, 2 x SATA II,
5.1CH HD Audio integrated
