Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Ë«ºËÁ趯D510¹¤¿ØÖ÷°å
²úÆ·Ãû³Æ£º Ë«ºËÁ趯D510¹¤¿ØÖ÷°å
ÐÍ ºÅ£º BIPV8M-IAE
Æ· ÅÆ£º 4042
Intel Pineview Atom D510 (1.67GHz) processor onboard
_ 6 x COM (five for RS232 / two rear + three internal pin header,
one rear for RS232/422/485; all with 5V/12V switch by
jumper select)
_ One DDR2 667/533 SO-DIMM up to 2GB
_ Dual View support via VGA and LVDS
_ PCI & Mini PCI-E slot expansion
_ Dual Gigabit LAN, 2 x SATA, 8 x USB 2.0, 1 x Printer port
5.1CH HD Audio integrated
Specifications
System
CPU Intel Pineview Atom D510 (1.67GHz) processor onboard
Chipset Intel 82801GBM I/O Controller Hub 8 (ICH8-M)
System memory 1 x 200pin DDR2 667/533 SO-DIMM max. up to 2GB
BIOS AMI 8Mb Flash ROM
Watchdog Timer Reset: 1~65535 level
H/W Monitor CPU voltage / CPU & System Temperature
CPU fan speed
Expansion 1 x PCI slot; 1 x Mini PCI-E connecotr
I/O
MIO 1 x IDE(2.0pitch), 2 x SATAII, 1 x LPT
5 x RS232; 1x RS232/422/485,
Ethernet 2 x Realtek RTL8111DL for Dual Gigabit LAN
Audio Realtek ALC662 suppot 5.1CH Audio
USB 8 x USB 2.0 ports (4 via box-header)
Digital I/O 4 input; 4 output
Display
Chipset Intel Graphics Media Accelerator (GMA) 3150
Display Memory Shared system memory up to 384MB video memory
Resolution VGA: Max upto 2048 x 1536
LVDS: 18bit, single channel
Mechianical & Environmental
Power Type ATX
Operating Temperature 00C~600C
Operating Humidity 10%~90%
Size(L x W) 170mm x 170mm (6.69¡± x 6.69¡±)
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÓ³µÂµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 33303661 / ÑÏ˼À«
ÊÖ»ú£º 13713974070
µØ Ö·£º ÉîÛÚÊи£ÌïÇøÉîÄÏ´óµÀÖñ×ÓÁÖÇóÊÇ´óÏö«×ù1110
ÓÊ ±à£º 518040
Ö÷ Ò³£º http://www.biostar.cn
  • ӳ̩G41¹¤¿ØÖ÷°å
  • ӳ̩G41A¹¤¿ØÖ÷°å
  • ӳ̩D525¹¤¿ØÖ÷°å
  • GM45¸ßÇå¹ã¸æ»ú¹¤¿ØÖ÷°å
  • Ë«ºËÁ趯D510¹¤¿ØÖ÷°å
  • ӳ̩AMD¹¤¿ØÖ÷°å
  • ӳ̩Eden 1.6G¹¤¿ØÖ÷°å
  • ӳ̩945GME¹¤¿ØÖ÷°å
  • ӳ̩ATOM N330¹¤¿ØÖ÷°å
  • ӳ̩D510Ë«ºË3.5´ç¹¤¿ØÖ÷°å
