Specifications System CPU Intel Pineview Atom D510 (1.67GHz) processor onboard Chipset Intel 82801GBM I/O Controller Hub 8 (ICH8-M) System memory 1 x 200pin DDR2 667/533 SO-DIMM max. up to 2GB BIOS AMI 8Mb Flash ROM Watchdog Timer Reset: 1~65535 level H/W Monitor CPU voltage / CPU & System Temperature Expansion 1 x CF card slot I/O MIO 1 x IDE, 2 x SATAII, 1x P/S 2 K/B or Mouse, 1 x RS232; 1x RS232/422/485 Ethernet 2 x Realtek RTL8111DL for PCI-E Gigabit LAN Audio Realtek ALC662 suppot 5.1CH Audio USB 6 x USB 2.0 ports (4 via pin-header) Digital I/O 4 input; 4 output Display Chipset Intel Graphics Media Accelerator (GMA) 3150 Display Memory Shared system memory up to 384MB video memory Resolution VGA: Max upto 2048 x 1536 LVDS: 18bit, single channel Mechianical & Environmental Power Type 12V DC-in 60W DC power onboard Operating Temperature 00C~600C Operating Humidity 10%~90% Size(L x W) 146mm x 105mm (5.75¡± x 4.13¡±) Packing White Box W/ SATA Cable x 1; CD Driver x 1 Ordering Information Model Name Part No. Description IPV8M-PA Atom D510(1.67GHz) CPU onboard 3.5¡± SBC with 12V DC-in 60W DC power, VGA/18bit LVDS, Dual Gigabit LAN, CF card slot, 2 *COM , 6 *USB, HD audio Intel Atom D510 dual core (Pineview-D) CPU onboard 3.5¡± SBC supports Dual View, 2 COM, 2 Gigabit LAN , CF slot, 12V DC-in 60W power IIPV8M--PA Features 1048698; Intel Pineview Atom D510 (1.67GHz) processor onboard 1048698; 12V DC-in 60W power onboard 1048698; Dual View support via VGA and 18bit LVDS 1048698; CF card expansion slot 1048698; Dual Gigabit LAN, 2 x COM, 2 x SATAII, 6 x USB 2.0, 5.1CH HD Audio integrated
