Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú GM45¸ßÇå¹ã¸æ»ú¹¤¿ØÖ÷°å
²úÆ·Ãû³Æ£º GM45¸ßÇå¹ã¸æ»ú¹¤¿ØÖ÷°å
ÐÍ ºÅ£º BIGM45-IP
Æ· ÅÆ£º 4042
Intel Mobile Socket P Mini-ITX Motherboard Supports
Dual HDMI, Dual Gigabit LAN, PCI slot and Mini PCI-Ex1
BIGM45-IP
Features
l               Mobile Socket P support Intel Core 2 Duo Mobile Penryn/
Core 2 Extreme / Celeron M (575/585) CPU
l       2 x 200pin DDR2 800/667 SO-DIMM up to 4GB
l       Dual view support via 24bit LVDS/VGA/HDMI
l       1 x PCI slot and 1 x Mini PCI-Ex1 slot
l       1 x LPC interface for extra 4 COM ports add-on card expand
l       Dual Gigabit LAN(INTEL LAN), 2 x COM, 8 x USB 2.0,
2 x SATAII, 1 x Printer port, 5.1CH HD Audio integrated
Product Overview
The BIGM45-IP is an industrial embedded motherboard based on the Mini-ITX form factor, Intel Centrino2 Montevina mobile platform with embedded GM45 Express chipset and 45nm Penryn Core2 Duo/Quad mobile processor. With the Intel latest mobile computing technology and dual HDMI display output feature, the BIGM45-IP offers the advanced digital processing capacity on the embedded computing solution.
Specifications
System
CPU
Intel Soceket P support Core 2 Duo Mobile Penryn/Core 2 Extreme / Celeron M
Chipset
Intel GM45 + ICH9M
System memory
2 x 200pin DDR2 800/667 SO-DIMM max.
up to 4GB
BIOS
AMI 8Mb Flash ROM
Watchdog Timer
Reset: 1~65535 sec
H/W Monitor
CPU voltage / CPU & System Temperature
CPU & System fan speed
CPU fan speed control
Expansion
1 x PCI slot
I/O
MIO
1 x IDE (2.0pitch), 2 x SATAII, PS/2 K/B&M/S,
1 x printer por; 2 x RS232 (1 via box-header)
Ethernet
2 x Realtek RTL8111DL for PCIe Gigabit LAN
Audio
Realtek ALC662 suppot 5.1CH Audio
USB
8 x USB 2.0 ports (4 via box-header)
Digital I/O
4 input; 4 output
Display
Chipset
Intel® Gen 5.0 integrated graphics engine
Video Memory
Intel® DVMT 5.0 supports up to 1024 MB video memory
Resolution
VGA: Max. upto 2048 x 1563
LVDS: Dual-channel, 24bit
HDMI: CEA modes 480i/p, 576i/p, 720p, 1080i/p and PC modes though dot clock
Mechianical & Environmental
Power Type
ATX
Operating Temperature
0~60 degree
Operating Humidity
10%~90%
Size(L x W)
170mm x 170mm (6.69¡± x 6.69¡±)
Weight
0.5 Kg
Packing List
IDE Cable x 1, SATA Cable x 1, I/O Bracket x 1, CD Driver x 1
Subject to change without notice
Ordering Information
Model Name
Part No.
Description
BIGM45-IP
Industrial Motherboard in Mini-ITX form factor with Socket P supports Intel Core 2 Duo Mobile Penryn/Core 2 Extreme / Celeron M processor, Intel GM45 + ICH9M chipset, VGA, 24bit LVDS, Dual HDMI, Dual Gigabit LAN, USB 2.0, 5.1CH, PCI, Mini PCI-E
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÓ³µÂµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 33303661 / ÑÏ˼À«
ÊÖ»ú£º 13713974070
µØ Ö·£º ÉîÛÚÊи£ÌïÇøÉîÄÏ´óµÀÖñ×ÓÁÖÇóÊÇ´óÏö«×ù1110
ÓÊ ±à£º 518040
Ö÷ Ò³£º http://www.biostar.cn
  • ӳ̩G41¹¤¿ØÖ÷°å
  • ӳ̩G41A¹¤¿ØÖ÷°å
  • ӳ̩D525¹¤¿ØÖ÷°å
  • GM45¸ßÇå¹ã¸æ»ú¹¤¿ØÖ÷°å
  • Ë«ºËÁ趯D510¹¤¿ØÖ÷°å
  • ӳ̩AMD¹¤¿ØÖ÷°å
  • ӳ̩Eden 1.6G¹¤¿ØÖ÷°å
  • ӳ̩945GME¹¤¿ØÖ÷°å
  • ӳ̩ATOM N330¹¤¿ØÖ÷°å
  • ӳ̩D510Ë«ºË3.5´ç¹¤¿ØÖ÷°å
