BWU1568 AS-i 3.0
BWU1568 AS-i 3.0
“ÖйúѸËÙ·¢Õ¹µÄ³ÇÕò»¯½ø³ÌÔÐÓýמ޴óµÄÏû·ÑÆ·ÐèÇó¡£µ½2025Ä꣬ȫÇòǰ600´óÖÐÐͳÇÊе±ÖУ¬½«ÓÐ225¸öÔÚÖйú1¡£ÕâÒâζ×ŶԻù´¡ÉèÊ©ºÍ×ÔÈ»×ÊÔ´¸ü¶àµÄÐèÇó£¬È»¶øÖйú¹¤ÒµÄܺÄռȫÉç»á×ÜÄܺĵÄ70%ÒÔÉÏ2£¬ËùÒÔÁíÒ»·½Ã棬ÖйúؽÐèÌá¸ß¹¤ÒµÁìÓòµÄÄÜԴЧÂÊ¡£Ãæ¶ÔÕâЩ´óÇ÷ÊÆºÍÌôÕ½£¬½ö¿¿ÊµÏÖÉú²ú¹ý³ÌµÄ×Ô¶¯»¯ºÍÌáÉý»úÆ÷µÄÉú²úЧÂÊ»¹Ô¶Ô¶²»¹»£¬±£³Ö¾ºÕùÁ¦»¹ÔÚÓÚ´òÆÆÆóÒµ¸÷ÖÖÐÅÏ¢¹ÂµºµÄÏÖ×´¡£Èç½ñ£¬Éú²úÆóÒµÐèÒª×öµÄÊǽ«Õû¸öÉú²ú³µ¼äµÄÖÇÄÜÉ豸¡¢»úÆ÷¼°Éú²ú¹ý³ÌÁ¬½ÓÆðÀ´£»½¨Á¢Õû¸öÉú²ú³µ¼äÓëÆóÒµÆäÓಿ·ÖµÄÁªÏµ£»²¢´òͨÆóÒµÓëÍⲿÕû¸ö¹©Ó¦Á´µÄÁ¬½Ó¡£ÕâÒâζ×ÅÆóÒµÐèÒª´Ó×Ô¶¯»¯²ãÃæÌáÉýµ½ÐÅÏ¢»¯²ãÃæ£¬´Ó¾Ö²¿ÖªÊ¶µÄÔËÓÃת±äΪȫÇòÐͬºÏ×÷£¬ÒÔ¼°½«¿ª·Åʽϵͳת±äΪ¿ª·ÅÇÒ°²È«µÄϵͳÀ´½µµÍ·çÏÕ¡£ÕâÒ»Ô¸¾°ÎÒÃdzÆÖ®Îª‘»¥ÁªÆóÒµ’£¬”Nosbusch ÏÈÉú²¹³äµÀ¡£
¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï¡ï
ʵÏÖ“»¥ÁªÆóÒµ”µÄºËÐÄÊÇʵÏÖ¿ØÖÆÓëÐÅÏ¢¼¼ÊõµÄÈںϡ£´óÁ¬Èí¼þÑз¢ÖÐÐÄ×ÅÖØÑо¿ÈçºÎ¼ÓÇ¿¿ØÖÆÓëÐÅϢϵͳ¼äµÄ¼¯³É£¬ÎªÂÞ¿ËΤ¶û×Ô¶¯»¯»¥ÁªÆóÒµÕ½ÂÔÌṩÁËÓÐÁ¦Ö§³Ö¡£Í¨¹ý½áºÏ¿ÉÊÓ»¯ÓëÐÅÏ¢Èí¼þ£¬ÏµÍ³Äܹ»ÒԷḻµÄͼÐνçÃæÌṩÓÐÕë¶ÔÐԵĿØÖƺÍÐÅÏ¢£¬²¢¿ÉÌṩ´Ó¹¤³§¼¶µ½ÆóÒµ¼¶µÄʵʱ¼°ÀúÊ·Êý¾Ý·ÃÎÊ£¬ÒÔ´ËÌáÉýÉú²úЧÂÊ£¬ÖúÁ¦¾ö²ßÖÆ¶¨¡£ÂÞ¿ËΤ¶û×Ô¶¯»¯µÄºËÐÄ¿ÉÊÓ»¯Èí¼þ FactoryTalk View µÄ¿ª·¢¹¤×÷ÕýÊÇÓÉ´óÁ¬Èí¼þÑз¢ÖÐÐÄÍê³É¡£¸ÃÈí¼þ¹ãÊܿͻ§»¶Ó£¬Æ¾½èÆäÒ»Á÷µÄÆ·Öʺ͹¦ÄÜ£¬ÔøÈÙ»ñ¶àÏîÒµÄÚȨÍþ½±Ïî¡£
Allen Bradley Starter 509-COD, Size 2 Ser. B #31981
Fuji Electric Power Filter FHF-TA/5/250-S #22029
Cincinnati Milacron 3 351 3610A Back Plane Board #26959
Merlin (ISB) Light Curtain Control M4030-CT #11450
New GPIB Interface Board 194656A-01, Rev 1.0 #29380
Profibus Base Module / Terminal Block ZSB-1.5/16-S/S/?+/
Nordson Circuit Board 185680F #29399
New MPCS Circuit Board 170856 #30165
Nova PC Board 021-5231-004, #12300
Melsec AY11A High Speed Counter Controller #8008
Allen Bradley X-379485 Power Supply/Transfor?mer #27844
Vickers Check Valve C5G 815 S8 #30361
MPCS PC Board 197607, 182303 #30162
Sew Eurodrive Circuit Board 8224838.1C #42596
Sew Eurodrive Circuit Board 8225850.16.14 #42600
Sew Eurodrive Circuit Board 8225850.16.19 #42601
Sew Eurodrive Circuit Board 82335.1B #42602
Sew Eurodrive Circuit Board 82335.1E #42603
Sew Eurodrive Circuit Board 8227772.13.14 #42605
Quartech Circuit Board 600P46H03 #42660
Square D Service Panel QOC342MF #43032
New Circuit Board 123566 #30164
Mitsubishi Circuit Board J2B-C11C, J2-F04 #42053
Dynisco Pressure Transducer PT130-3M #13001
Allen Bradley Circuit Board 74102-484-51 #35843
Allen Bradley Circuit Board 9004-3192 #35845
Allen Bradley Circuit Board 9004-3193 #35847
Block Power Supply PT13/2/18 #17494
Modicon AS-M680-108 Memory Card #7604
Mould-Tek Additive Feed Control, AF Series #18371
Payne Engineering Power Control 18D-2-10, 10 Amps, 240
Allen Bradley Circuit Board 74102-405-53 Rev. 03 #35865
Allen Bradley Circuit Board 74102-405-53 Rev. 01 #35870
Allen Bradley Circuit Board 74102-405 / 74102-404-02A #
Allen Bradley Circuit Board 191890 Rev .08 #35872
IDC Corporation Digital Display SH21-D #43151
SCI Circuit Board 21963-7 #35905
Star Automation PC Board PS402 #43145
Square D Input Module CIM-101 Class 8030 #11100
Hydro Line Hydraulic Cylinder R5A-2X7.5 #31353
Electric Cylinder Linear Servo Cylinder RH205A-12-MF3-N?
Westinghouse Starter A200K2CACM Size 2 #20764
Federal Circuit Board EPC 1677 Rev. F #42555
Square D HIM-151 Input Module Class 8030 #11106
Fuji Electric Contactor 2NC4H0 #37457
Crane 14 NCZ Butterfly Valve #17077
Siemens HNF363 Heavy Duty Safety Switch #18787
Crane / Monarch Butterfly Valve 21F-BRB #29674
Intel Circuit Board 30531 142933-001 Rev A #15406
Pico Circuit Board PICO 4 #25114
Power Miser Control Board FPW-01 #24896
Mark II Automation PC Board 0000790-01 #24919
Emerson Flux Vector Drive Keypad #31491
Seco AC Flux Vector Drive SV3000 Keypad #20691
Star Circuit Board 5043-PR04D #5677
Circuit Board FBUS-05 #24893
Circuit Board Relay04 #24898
Circuit Board Relay05 #24929
Idec Circuit Board PCB5014B #43233
New Applied Robotics Electrical Module 0505-D84A #30017
New Applied Robotics Electrical Module 0506-D13A #30019
New Applied Robotics Electrical Module 03IM-R-E-HIKVAE?2
New Applied Robotics Electrical Module DIM-R-E-37.05-S?6
New Applied Robotics Electrical Module DIM-T-E-37.05-S?6
Everex Systems Circuit Board EV138 #5764
Harmo Circuit Board PCB-E100I/F V2 #43226
Circuit Board ED461, SS 15V-0 #43231
Hydro-Line Cylinder R5A-2X18 #30935
Allen Bradley Circuit Board 74102-405-54 #35928
DeStaCo Pneumatic Actuator 82G8N-423E43-11?190A-P3 #2942
Nordson Commuication Board 227119B #31875
Hydro Line Cylinder LR5V-1.50X8.50-?B #44622
Ingersoll Rand Spindle Drive Mod139 #48139
IFM Efector PB0224 Pressure Sensor #21203
Nibco Butterfly Valve WD2000 #29542
Hyundai Circuit Board HYM532200AM-70F?MA #26262
Eaton Corporation Cylinder 0246-N34M #44751
Indramat Circuit Board 109-0730-3B43-0?2 #43679
T Valve & Pneumatic Cyc 2" Plastic Material #13512
TDK Circuit Board PCU-P035 #43809
MSC Circuit Board SCP-C, 10284-0000-F, REV A #43819
Fast Heat Power Supply 580-501 #37482
Elva Power Supply INV30A #31769
Harmo PC Board PCB-E100I/F Circuit Board #22020
NIB Condor Power Supply HB-3/OVP-A+ #23409
Technifor Circuit Board CN1-12/3, MF-3/14/30 PC Board #
Sharp Back Plane JW-28KB Circuit Board #23247
Sharp Module JW-21MA, 3.5 KW #23261
Technifor Circuit Board CN1-12/3, MF-3/12/31 #34183
New Britain Vinyl Tip 300 Ton #15033
Merlin (ISB) MA4030-C Light Curtain Control #11449
T-Valve #2654
Universal Dynamics PCB-068 8 Digit Display Card #7175
Bosch Sensor 3842174360 #7777
Hengstler Screw Tachometer E516-14S-63 #8679
Westinghouse A200M1CACD Contactor Starter #7783
Boy 9401213 84 Cylinder #19147
Armstrong C Clamp No. 110 11" Throat #37392
Pneutronics Circuit Board 990-004767-001 #45674
Armstrong C Clamp 78-110 #37393
Moeller Base Module / Terminal Block ZSB-1.5/16-S/S/?+/+
Teach Pendant Touch Panel N314-5006 #36205
NEW Bielomatik 9118450 Display Screen #13402
Hunkar Labs Linear Transducer Stroke - 7 1/2, 26003 #37
General Electric Motor 5KCP39PGC39OS, 460 Volt #44513
Hunkar Labs Linear Transducer Stroke 11 1/4, 26011 #375
Quantem 3-A21-RZ007 Temperature Controller #24938
Fanuc Interface Module A03B-0801-C401 #8346
GE Fanuc Rack IC600YR511A Series Six #7791
Rexroth Hydraulic Valve 319 927/OF, #6082
Signal Systems Control BF-9518 Fire Alram #11194
Harmo PC Board PCB-E051B #22067
Harmo PC Board PCB-E052 #22068
Hengstler Screw Tachometer E516-14S-61 #8680
Allen Bradley Circuit Board 142393-01 #44107
Armstrong C Clamp 110, Throat: 11", #37391
Parker Cylinder 02.50 CJ2HLUV19AC 5.000 #32357
Neles Jamesbury Ball Valve 5150 312236MT #37691
NEW Uticor 76535 Bidirectional Adaptor RS-232C #17301
Yuken Check Valve MSB-03-Y-40 #38416
