1264C62G19,1264C62G19
20ÊÀ¼Í40Äê´úÒÔÀ´£¬´ÓÒDZíµÄ²âÁ¿£¨´«¸Ð±äËÍ£©¡¢¿ØÖÆ£¨ÔËËã)¡¢ÏÔʾ£¨¼Ç¼)ºÍÖ´ÐÐËÄ´ó¹¦ÄܵÄÑݱäÀ´¿´£º×î³õ£¬ÔÚ×ÔÁ¦Ê½µ÷½ÚÆ÷ÖÐ4ÖÖ¹¦Äܸ߶ȼ¯ÖУ»40Äê´úºóÆÚ£¬³öÏÖÁË»ùµØÊ½µ÷½ÚÒÇ±í£¬°ÑÖ´Ðй¦ÄÜ·ÖÀë³öÈ¥£¬¶øÆø¶¯¡¢µç¶¯µ¥Ôª×éºÏÒDZíÔò°ÑÁíÍâ3ÖÖ¹¦ÄÜÒ²³¹µ×·ÖɢΪ¸÷¸öµ¥Ôª£»80Äê´úºóÆÚ£¬ÓÉÓÚ¼ÆËã»ú¼¼ÊõµÄÒýÈ룬ÓÖ°Ñ¿ØÖÆ£¨ÔËË㣩ºÍÏÔʾ£¨¼Ç¼)¹¦ÄÜ·Ö±ð¼¯ÖÐÓÚ¿ØÖÆÕ¾ºÍ²Ù×÷Õ¾£»Èç½ñ£¬ÓÉÓÚÏÖ³¡×ÜÏߺÍÎÞÏß¼¼ÊõµÄÍÆ¹ãÓ¦Ó㬸÷¹¦ÄÜÖØÐÂ×éºÏ¼¯³ÉÓÚ±äËÍÆ÷»òÖ´Ðлú¹¹ÖУ¬ËƺõÓֻص½ÁË»ùµØÊ½µ÷½ÚÒDZíµÄ½á¹¹¡£Õæ¿Éν“·Ö¾Ã±ØºÏ£¬ºÏ¾Ã±Ø·Ö”£¬´Ó¼¼Êõ½Ç¶È¶øÑÔ£¬ÕâÊÇÖܶø¸´Ê¼µØ³ÊÂÝÐýʽÉÏÉý¡£¹¤Òµ×Ô¶¯»¯ÒÇ±í·¢Õ¹¹ì¼£Í¬Ñù·ûºó¼¼ÊõϵͳµÄSÇúÏß½ø»¯·¨Ôò¡£µäÐ͵ÄSÇúÏßÊÇÃèÊöÒ»¸ö¼¼ÊõϵͳµÄÍêÕûÉúÃüÖÜÆÚ¡£
6SY7000-0AE34 THYRISTOR MDLE W/ACCESSRIES REPLACEMENT Siemens
6SY7000-0AE42 MASTERDRIVES WR CONDUCTOR BARS Siemens
6SY7000-0AE45 WR CONDUCTOR BARS (CU) B7 Siemens
6SY7000-0AE51 MC COMPACT PLUS CONNECTOR KIT Siemens
6SY7000-0AE57 FUSE LINK FNQ-R-8/10, 0.8 A, 600V Siemens
6SY7000-0AE60 DC LINK CAPACITORS,6000 UF, 800V Siemens
6SY7000-0AE63 SIMOVERT MD ZK-BATTERY 10MF/800V (AL)B7 Siemens
6SY7000-0AE71 IGBT TRANSISTOR MOD,200A,1200V Siemens
6SY7000-0AE72 RADIAL FAN AY 250/B7 FOR SIZE G Siemens
6SY7000-0AE74 DC FUSE LINK 63A Siemens
6SY7000-0AE75 SIMOVERT MD KOMPAKT +DC LINK FUSE 100A Siemens
6SY7000-0AE77 MD DESIGN KOMPAKT+ DC-FUSE 25A Siemens
6SY7000-0AE78 OPEN AND CLOSED-LOOP CONTROL MODULE Siemens
6SY7000-0AE80 FAN,MD KOMPAKT,TY 614 Siemens
6SY7000-0AE81 SIMOVERT MASTERDRIVES DESIGN KOMPAKT PLU Siemens
6SY7000-0AE82 MD,SIMOVERT,KOMP+, 614A (SPAREPARTONLY) Siemens
6SY7000-0AE83 MD,SIMOVERT,COMP, 8414 (SPAREPARTONLY) Siemens
6SY7000-0AE84 SIMOVERT MD DESIGN KOMPAKT+ FAN 414 A Siemens
6SY7000-0AE85 MC MODULE, CUCP02 KOMPAKT+(SPAREPARTONLY Siemens
6SY7000-0AE86 SIMOVERT MASTERDRIVES KOMPAKT+ FAN 414B Siemens
6SY7000-0AE87 MD,SIMOVERT,KOMP+, 614B(SPAREPARTONLY) Siemens
6SY7000-0AE88 MD,SIMOVERT,COMP, 8414B (SPAREPARTONLY) Siemens
6SY7000-0AF04 FAN, CPL. F. B1,24V DC,SPARE PART Siemens
6SY7000-0AF06 MDVC FRAME SIZE COMP+,CUVP02 PAINTED Siemens
6SY7000-0AF10 TRANS NPN IGBT,BSM200GA170DN2S,1.7KV Siemens
6SY7000-0AF11 IGBT-TRANS MOD BSM300GA170 DN2S,300A Siemens
6SY7000-0AF12 SIMOVERT MD,IGBT-TRANS,DN2S,400A,1200V Siemens
6SY7000-0AK02 SIMOVERT MD WR CONDUCTOR BARS (CU) B7 Siemens
6SY7000-0AK04 DC FUSE LINK,160A,700V Siemens
6SY7000-0AK05 DC FUSE LINK,200A,700V Siemens
6SY7000-0AK40 EBV MODULE MD VECTOR CONTROL Siemens
A1Z01245024 6SE70321EG60Z,AC DR,210A,480V Siemens
A1Z02233026 6SE70260TD61-Z,L33+G93 Siemens
A1Z03145005 6SE70321EG601AA1-Z,SMVRT,MD,MC Siemens
A1Z03147005 6SE70326EG601AA1-Z,HEIDLEBERG Siemens
A1Z05111003 MASTERDRIVE,6SE70130EP50-Z Siemens
A1Z05111006 MD MC,480V,3PH,1.1KW,3A + OPTS Siemens
A1Z05113022 6SE70150EP50-Z,1.5KW Siemens
A1Z05113032 6SE70150EP50-Z,AC:1.5KW Siemens
A1Z05119004 6SE70210EP50-Z,SMOVRT MD MC Siemens
A1Z05123001 6SE70221EP50-Z,SMVRT MD MC Siemens
A1Z05123004 6SE70221EP50-Z,SMOVRT MD MC Siemens
A1Z05215034 6SE70161EA51-Z F01+K11+K01+G91+C23+G44 Siemens
A1Z05223029 6SE70218EB51-Z F01+K11+K01+G91+C23+C15 Siemens
A1Z05227034 6SE70234EC51-Z F01+K11+K01+G91+C23+G44 Siemens
A1Z06119016 INV,AC,460V,3PH,4KW,10.2A,CP +OPTS Siemens
A1Z06123001 6SE70218TP50-Z, Siemens
A1Z06219028 6SE70210TA51-Z,K11+K01+G91+C13+G44+L33 Siemens
A1Z06219030 6SE70210TA51-Z, Siemens
A1Z06223011 6SE70218TB51-Z, SMOVRT MD MC Siemens
A1Z06225011 6SE70226TC51-Z,HEIDELBERG Siemens
A1Z06227008 6SE70234TC51,SMOVRT MD MC Siemens
A1Z06231030 6SE70247TD51-Z, Siemens
A1Z06233011 6SE70260TD51-Z,SMOVRT MD MC Siemens
A1Z06233019 6SE70260TD51-Z, SMOVRT MD MC Siemens
A1Z06235011 6SE70272TD51-Z,SMOVRT MD MC Siemens
A1Z06235019 6SE70272TD51-Z,SMOVRT MD MC Siemens
A1Z06337031 6SE70310TE50-Z, Siemens
A1Z06339013 6SE70312TF50-Z,SMOVRT MD MC Siemens
A1Z08343013 6SE70321TG501AA1-Z,SMOVRT MD MC Siemens
A6X10001237 INV,AC,460V,3PH,2.2KW,6.1A,CP,Z+F01 Siemens
A6X10001239 DR,AC,460V,3PH,4KW,10A,CP,W/TECH OPT Siemens
A6X10001241 INV,AC,460V,3PH,4KW,10.2A,CPW/TECH OPT Siemens
A6X10001242 DR,AC,460V,3PH,5.5KW,14A,TECH OPT INC Siemens
A6X10001243 INV,AC,460V,PH,11KW,25.5A,MC,W/TECH OPT Siemens
A6X10001316 INV,AC,480V,3PH,0.75KW,2.0A,VCP,SAFE OFF Siemens
A6X10001317 SIMOVERT MASTERDRIVES MOTION CONTROL COM Siemens
A6X10001318 INV,AC,460V,3PH,4KW,10.2A,W/SAFE OFF OPT Siemens
A6X10001319 INV,AC,510-650V,4KW,50/60HZ,10.2A W/SOFF Siemens
A6X10001320 SIMOVERT MASTERDRIVES MOTION CONTROL INV Siemens
A6X10001321 DR,AC,460V,3PH,5.5KW,14A,CP,K80 OPTION Siemens
A6X10001322 INV,AC,460V,3PH,7.5KW,17.5A,W/SAFE OFF O Siemens
A6X10001323 INV,AC,510-650V,7.5KW,17.5A,W/SAFEOFF Siemens
A6X10001324 DR,AC,460V,3PH,7.5KW,20.5A,W/SAFE OFF OP Siemens
A6X10001325 INV,AC,510-650V,11KW,25.5A,W/SAFEOFF Siemens
A6X10001326 INV,AC,480V,3PH,11KW,25.5A,VCP,SAFE OFF Siemens
A6X10001327 DRIVES,SIMOVERT, MASTER,CONVERTER,CMPT Siemens
A6X10001329 MC CONVTR COMPACT 15KW,SAFE OFF(K80) Siemens
A6X10001332 INV,AC,460V,3PH,45KW,92A,VCH,Z="SAFEOFF" Siemens
A6X10001333 INV CHASIS,VECTOR,75KW,"SAFE OFF" Siemens
A6X10001352 DR,AC,480V,3PH,1.5KW,5.0A,VCP Siemens
A6X10001358 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001360 DR,AC,460V,3PH,3KW,8A,VB Siemens
A6X10001361 MD VC CONVERTER,COMP+,IP20,3AC,480V+L20 Siemens
A6X10001366 DR,AC,460V,3PH,4KW,10A,VCP Siemens
A6X10001367 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001370 DR,AC,460V,3PH,5.5KW,13.2A,VCP Siemens
A6X10001371 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001375 DR,AC,480V,3PH,8KW,20.5A,VCP Siemens
A6X10001377 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001380 DR,AC,480V,3PH,11KW,27A,VCP Siemens
A6X10001382 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001388 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001389 DR,AC,460V,3PH,18.5KW,37.5A,VB Siemens
A6X10001393 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001399 DR,AC,460V,3PH,45.0KW,92.0A,VCH Siemens
A6X10001401 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001407 DR,AC,460V,3PH,90.0KW,186 A,VCH Siemens
A6X10001408 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001410 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001412 DR,AC,460V,3PH,132KW,260A,VCH Siemens
A6X10001413 DR,AC,460V,3PH,160KW,315A,VCH Siemens
A6X10001417 INV,VECTOR,124AMPS,15KW Siemens
A6X10001421 INV,AC,460V,3PH,4KW,10.2A,VB Siemens
A6X10001423 INV,DC,510-650V,17,5A W/O DC LINKS Siemens
A6X10001424 INV,VECTOR,34 AMPS,15KW Siemens
A6X10001425 INV,DC,510-650V,47A,W/O DC LINKS,22KW Siemens
A6X10001854 INV,AC,510-650V,92A,MC,SAFESTP Siemens
A6X10001855 INV,AC,460V,3PH,37.0W,72.0A,VB Siemens
A6X10001873 INV,AC,480V,3PH,1.5KW,4A,VCP,W/SAFE OFF Siemens
A6X10001874 INV,AC,480V,3PH,5.5KW,13.2A,VCP Siemens
A6X10001875 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001877 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001878 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X10001879 INV,AC,575V,3PH,37KW,61A,L30 Siemens
A6X10001880 INV,AC,575V,3PH,55KW,79A,VCH,L30 Siemens
A6X10001881 INV,AC,575V,3PH,132KW,192A,L30 Siemens
A6X10001882 INV,AC,575V,3PH,160KW,225A,VCH,L30 Siemens
A6X10001883 INV,AC,575V,3PH,2KW,4.5A,VB,L33 Siemens
A6X10001884 INV,AC,575V,3PH,5.5KW,11A,VB,L33 Siemens
A6X10001885 INV,AC,575V,3PH,7.5KW,15.1A,VB,L33 Siemens
A6X10001886 INV,AC,575V,3PH,11KW,22A,VB,L33 Siemens
A6X10001887 INV,AC,575V,3PH,18.5KW,29A,VB,L33 Siemens
A6X10001888 INV,AC,575V,3PH,22KW,34A,VB,L33 Siemens
A6X10001889 INV,AC,575V,3PH,30KW,46.5A,VB,L33 Siemens
A6X10002132 DR,AC,460V,3PH,11KW,27A,CP,P2,W/F01 Siemens
A6X10002136 MC COMP+CONV 3AC 380-480V 50/60HZ 47A Siemens
A6X10002170 6SE70310EE50-Z G61+C43+K11+K01+K80+M20 Siemens
A6X10002171 DRV AY MOTION CTL COMP+CONV25.5A380-460V Siemens
A6X10002172 SIMOVERT MASTERDRIVES, COMPACT UNIT Siemens
A6X10002186 INV,AC,460V,3PH110KW,218A,MC,W/SAFE OFF Siemens
A6X10002188 CNV,RGN ,460V,132KW,267A,+M20 Siemens
A6X10002189 CNV,RGN,480VAC,200KW,398A,Z=M20 ENCLOS Siemens
A6X10002311 6SE70260ED61-Z, 30KW,59A,Z=L20+K80 Siemens
A6X10002312 INV,AC,460V,3PH,55KW,124A,Z=K80+L30 Siemens
A6X10002327 INV,AC,460V,3PH,18.5W,37.5A,VC Siemens
A6X10012721 DR,AC,460V,3PH,7.5KW,17.5A,VB +OPTS Siemens
A6X10012723 INV TO BE SUPPLIED W/G93=CBP2(SLOT C) & Siemens
A6X10012729 MASTER DRIVE,380V TO 480VAC,50/60HZ,34A, Siemens
A6X10012734 INV,AC,460V,3PH,37.0W,72.0A,VB + OPT Siemens
A6X10012735 CONVERTER,3PH480VOLTS,45 KW, AMPS Siemens
A6X10012738 MD VC INV, 650V,250KW,510A + OPTS Siemens
A6X10021533 INV,AC,460V,3PH,4KW,10.2A,CP + OPTS Siemens
A6X10021537 DR,AC,460V,3PH,15KW,34A,VB+OPT Siemens
A6X10024967 DR,AC,460V,3PH,3KW,8A,CP + OPT G91 Siemens
A6X30000597 SIMOVERT MASTERDRIVES VECTOR CONTROL CON Siemens
A6X30000643 MASTERDRIVE VC Inverter 146A 75KW 650VDC Siemens
A6X30000651 INVERTER,MSTRDR,510..650V DC,59A,(G91) Siemens
A6X30000768 MSTRDR,3P,480VAC,270A,,PROT=1P20,(M20) Siemens
A6X30000810 DR,3P,480VAC,72A,(C43F01G44G91K01K11K80) Siemens
A6X30000811 INV,650VDC,25.5A,11KW,(D78,G93) Siemens
A6X30000821 INV,AC,480V,3PH,15KW,34A,VCP(K80) Siemens
A6X30000822 INV,AC,600V,18.5KW,37.5A,VCP(K80) Siemens
A6X30000823 INV,AC,480V,3PH,7.5KW,17.5A,VCP(K80) Siemens
A6X30000828 DR,AC,460V,3PH,45.0KW,92.0A,VCH(K80) Siemens
A6X30000829 DR,COMP-UNIT,480VAC,72A,37KW,(K80) Siemens
A6X30000843 SIMOVERT,DR,P3,480VAC,59A,30KW(K80) Siemens
A6X30000857 INV,AC,460V,3PH,7.5KW,17.5A,CP(F01) Siemens
A6X30000884 SIMOVERT MASTERDRIVES MOTION CONTROL CON Siemens
A6X30000913 DR,AC,460V,7.5KW,20.5A,CP Siemens
A6X30000915 INV,AC,560V,7.5KW,17.5A,CP Siemens
A6X30000922 INV,AC,460V,3PH,45KW,92A,MC Siemens
A6X30000923 SIMOVERT MD VECTOR INV, 650V,250KW,510A Siemens
A6X30000924 INV,AC,460V,3PH,160KW,315A,VCH Siemens
A6X30000925 INV,AC,460V,3PH,55KW,124A,VCH Siemens
A6X30000926 INV,AC,460V,3PH,45KW,92A,VCH Siemens
A6X30000931 MASTERDRIVES MOTION,460V,3PH,1.1KW,3A,CP Siemens
A6X30000941 INV,AC,460V,3PH,45KW,92A,VCH Siemens
A6X30000942 INV,AC,460V,3PH,75KW,146A,VCH Siemens
A6X30000963 INV,AC,460V,3PH,18.5KW,37.5A,CP,K80 Siemens
A6X30001057 SIMOVERT MDMC CON 480V AC, ENC Siemens
A6X30001064 SIMOVERT MD MC 480V AC, 60HZ Siemens
A6X30001079 INV,AC,460V,3PH,110KW,210A,VCH Siemens
A6X30001086 DR,AC,460V,3PH,3KW,8A,CP Siemens
A6X30001093 DR VECTOR CONTROL CONV,IP20 3AC,460V Siemens
A6X30001162 SIMOVERT MD MC PERF 2 INV IP20 650V Siemens
A6X30001163 SIMOVERT MD MC PERF 2 CON IP20 480V Siemens
A6X30001242 SIMOVERT MD VEC CON INV IP20,650V,2.2KW Siemens
A6X30001272 SIMOVERT MASTERDRIVES Siemens
A6X30001342 MD MC,480V,3PH,1.1KW,3A,SW MOD,SAFE-OFF Siemens
A6X30001345 INV,AC,650V,3PH,4KW,10.2A,CP Siemens
A6X30001346 MD,MC,INV,650V,47A,WATER COOLED,ENC Siemens
A6X30001399 S'VRT-MST,CHASIS,MC:INV,132KW,620VDC Siemens
A6X30001420 S'VRT-MST,CHASSIS,MC:INV,110KW,620VDC Siemens
A6X30001431 S'VRT-MST,MC,COMP, MC, INV,15KW,620VDC Siemens
A6X30001432 S'VRT-MST,VC,CHAS:INV,132.0KW,620VDC Siemens
A6X30001433 S'VRT-MST,VC,CHAS:INV,110.0KW,620VDC Siemens
A6X30001434 S'VRT-MST,VC,CHAS:INV,90.0KW,620VDC Siemens
A6X30001437 USE PART # 6SE70218TB61 Siemens
A6X30001438 S'VRT-MST;VC;COMP:INV;15.0KW;620VDC Siemens
A6X30001439 S'VRT-MST;VC;COMP:INV;4.0KW;620VDC Siemens
A6X30001440 INV,AC,460V,3PH,4KW,10.2A,VB Siemens
A6X30001441 INV,AC,460V,3PH,55KW,124A,MC Siemens
A6X30001442 INV,AC,460V,3PH,15KW,34A,MC Siemens
A6X30001450 INV,AC,460V,3PH,1.5KW,4A,CP Siemens
A6X30001470 DR,AC,460V,3PH,5.5KW,14A,CP,ENC,SAFE OFF Siemens
A6X30001521 SIMOVERT,DR,AC,460V,3PH,11KW,27A,CP Siemens
A6X30001531 MDMC,AC,460V,3PH,4KW,10A,CP,SAFE OFF Siemens
A6X30001533 DR,AC,460V,3PH,3KW,8A,CP,SFTWR MOD Siemens
A6X30001557 MDMC,INV,AC,460V,3PH,5.5KW,13.2A,CP Siemens
