A20B-2901-0660/07AA20B-2901-0660/07A
¢ÛäöÎз¢ÉúÆ÷ ½á¹¹ÀàËÆÓÚÎÐÂÖ½ÚÁ÷×°ÖõÄת×Ó£¬´Ë´¦Ó¦Óý«Æä¹Ì¶¨²»²úÉúÐýת¡£Á÷Ìåͨ¹ýËüʱ½«·¢ÉúäöÎнDz»Ð¡ÓÚ240µÄÇ¿ÁÒäöÎУ¬ÓÃËüÀ´¿¼ºËÐÂÐÍÁ÷Á¿½ÚÁ÷×°ÖöÔäöÎеÄÊÊÓ¦ÄÜÁ¦¡£5¡¢ ½áÂÛ£¨1£©´ÓÖÐÌìÖ®ÈÕµ½Ï¦ÑôÎ÷Ï ¾µäÁ÷Á¿½ÚÁ÷×°ÖÃÎÊÊÀÒÑÓаÙÓàÄêµÄÀúÊ·£¬ÔøÈ¡µÃÕ¼ÓÐ70%×óÓҵĽÚÁ÷×°ÖÃÊг¡µÄ½¾ÈËÒµ¼¨¡£µ«ÆäÖÂÃüµÄÈõµãÊDZØÐè¾ßÓÐ30~40DµÄ°²×°Ö±¹Ü¶Î³¤¶È£¬²Å¿ÉÄܱ£Ö¤Óб1%µÄ׼ȷ¶È¡£¶ÔÓÚ¹æÄ£ÈÕÒæÔö´óµÄÏÖ´ú»¯¹¤Òµ£¬ÍêÈ«ÎÞ·¨Âú×ãÕâô¿Á¿ÌµÄÌõ¼þ£¬Ö»ÄÜÊÇÎÞ¿ÉÄκλ¨ÂäÈ¥ÁË¡£ £¨2£©³õ¶·æÃ¢µ«²¢²»ÍêÃÀ ΪӦ¶Ô¾µäÁ÷Á¿½ÚÁ÷×°ÖõIJ»×㣬¼¸Ê®ÄêÒÔÀ´Ñз¢Á˲»ÉÙÐÂÐÍÁ÷Á¿½ÚÁ÷×°Öã¬ÌرðÊǽüÊ®ÄêÍÆ³öÁËÒÔËõ¶Ì°²×°Ö±¹Ü¶Î³¤¶È¶øÈ·±£×¼È·¶ÈÎªÌØµãµÄ»·ÐÎͨµÀ¡¢¶à¿×¿×°å----µÈ£¬³õ¶·æÃ¢¼´ÓÐÁîÈËÖõÄ¿µÄ±íÏÖ¡£µ«ËüÓë¾µäÁ÷Á¿½ÚÁ÷×°ÖÃÏà±È£¬»¹ÊDZȽÏÖÉÄÛ£¬ÔÚÓ¦ÓÃÖбØÈ»»á²úÉúÕâÑù»òÄÇÑùµÄÎÊÌ⣬Èç¹ûÔÚÌõ¼þÉв»³ÉÊì¾Í²»¹Ëºó¹û£¬¾ÍÒªÈ«Ãæ¡¢´óÁ¦Íƹ㣬±Ø½«ÊÊµÃÆä·´£¬2008ÄêÄÚ×¶·¢ÉúÑÏÖØÊ¹ʺ󣬼´Ô⵽ʯ»¯ÐÐÒµÈ«Ãæ·âɱ*11¡£
6SE7021-0EB87-1FC0 SINEWAVE FILTER Siemens
6SE7021-0EP50 Masterdrives Compact Plus Converter - 4 KW Siemens
6SE7021-0EP50-Z Masterdrive Compact Plus Converter - 4 KW Siemens
6SE7021-0EP60 Masterdrives Compact Plus Converter - 4 KW Siemens
6SE7021-0EP60-Z Masterdrive Compact Plus Converter - 4 KW Siemens
6SE7021-0EP70 Masterdrives Compact Plus Converter - 4 KW Siemens
6SE7021-0EP70-Z Masterdrive Compact Plus Converter - 4 KW Siemens
6SE7021-0ES87-0FB0 Radio Interference Filter Siemens
6SE7021-0ES87-0FB1 FILTER,B1,3AC,380-460V,2.2KWVC/MC Siemens
6SE7021-0ES87-1FF1 REACTOR, 3-PH 380-460V AC, 10.2A 1243 UH Siemens
6SE7021-0TA51 Simovert Masterdrive Inverter - 4 KW Siemens
6SE7021-0TA51-Z Simovert Masterdrive Inverter - 4 KW Siemens
6SE7021-0TA61 Simovert Masterdrive Inverter - 4 KW Siemens
6SE7021-0TA61-Z Simovert Masterdrive Inverter - 4 KW Siemens
6SE7021-0TA71 Simovert Masterdrive Inverter - 4 KW Siemens
6SE7021-0TA71-Z Simovert Masterdrive Inverter - 4 KW Siemens
6SE7021-0TA84-1HF3 SIMOVERT,MD,POWER CONTROLLER,620V Siemens
6SE7021-0TP50 Simovert Control Compact Plus Inverter - 4 KW Siemens
6SE7021-0TP50-Z Simovert Control Compact Plus Inverter - 4 KW Siemens
6SE7021-0TP60 Simovert Control Compact Plus Inverter - 4 KW Siemens
6SE7021-0TP60-Z Simovert Control Compact Plus Inverter - 4 KW Siemens
6SE7021-0TP70 Simovert Control Compact Plus Inverter - 4 KW Siemens
6SE7021-0TP70-Z Simovert Control Compact Plus Inverter - 4 KW Siemens
6SE7021-1FB84-1HF3 MD,MODULE,11A,3-PH,500-575V AC Siemens
6SE7021-1UB84-1HF3 SIMOVERT MD PWR CONT MOD,11A,675-780V DC Siemens
6SE7021-2EP87-0FB0 Siemens Simovert Filtter Siemens
6SE7021-2EP87-0FB1 RFI WITH 2 Prcnt REACTOR, 12A Siemens
6SE7021-3EB51 Simover Masterdrives Converter - 5 KW Siemens
6SE7021-3EB51-1AA1 DR,AC,460V,3PH,5.5KW,13.2A,MC Siemens
6SE7021-3EB51-Z Simover Masterdrives Converter - 5 KW Siemens
6SE7021-3EB61 Simovert Masterdrive Converter - 5 KW Siemens
6SE7021-3EB61-Z Simover Masterdrives Converter - 5 KW Siemens
6SE7021-3EB71 Simover Masterdrives Converter - 5 KW Siemens
6SE7021-3EB71-1AA1 SIMOVERT,DR,AC,460V,3PH,5.5KW,13.2A,VB Siemens
6SE7021-3EB71-Z Simover Masterdrives Converter - 5 KW Siemens
6SE7021-3EB81 MASTERDRIVES 3AC 380V-460V,13.2,AFE,5.5K Siemens
6SE7021-3ES87-1FG0 AFE MAINS CONNECTION MODULE Siemens
6SE7021-3FS87-2DA1 6SE70 BRAKE UNIT 675-810V DC,10KW Siemens
6SE7021-3FS87-2DC0 BRAKE RESISTOR 10KW,62 OHMS Siemens
6SE7021-3TB51 Simovert Masterdrive Inverter - 5.5 KW Siemens
6SE7021-3TB51-1AA1 INV,AC,460V,3PH,5.5KW,13.2A,MC,K80-SAFE Siemens
6SE7021-3TB51-Z Simovert Masterdrive Inverter - 5.5 KW Siemens
6SE7021-3TB61 Simovert Masterdrive Inverter - 5.5 KW Siemens
6SE7021-3TB61-Z Simovert Masterdrive Inverter - 5.5 KW Siemens
6SE7021-3TB71 Simovert Masterdrive Inverter - 5.5 KW Siemens
6SE7021-3TB71-1AA1 SIMOVERT,INV,AC,460V,3PH,5.5KW,13.2A,VB Siemens
6SE7021-3TB71-Z Simovert Masterdrive Inverter - 5.5 KW Siemens
6SE7021-3TB84-1HF3 SIMOVERT MASTERDRIVES POWER CONTROLLER M Siemens
6SE7021-3TP50 Simovert Control Compact Plus Inverter - 5.5 KW Siemens
6SE7021-3TP50-Z Simovert Control Compact Plus Inverter - 5.5 KW Siemens
6SE7021-3TP60 Simovert Control Compact Plus Inverter - 5.5 KW Siemens
6SE7021-3TP60-Z Simovert Control Compact Plus Inverter - 5.5 KW Siemens
6SE7021-3TP70 Simovert Control Compact Plus Inverter - 5.5 KW Siemens
6SE7021-3TP70-Z Simovert Control Compact Plus Inverter - 5.5 KW Siemens
6SE7021-4EP50 Masterdrives Compact Plus Converter - 5.5 KW Siemens
6SE7021-4EP50-Z Masterdrives Compact Plus Converter - 5.5 KW Siemens
6SE7021-4EP60 Masterdrives Compact Plus Converter - 5.5 KW Siemens
6SE7021-4EP60-Z Masterdrives Compact Plus Converter - 5.5 KW Siemens
6SE7021-4EP70 Masterdrives Compact Plus Converter - 5.5 KW Siemens
6SE7021-4EP70-Z Masterdrives Compact Plus Converter - 5.5 KW Siemens
6SE7021-5FB61 DRVMSTR CNV VC 15.1A AC 500-600V AC Siemens
6SE7021-5FB87-1FD0 DV/DT FILTER3AC 380-460V,10.2,17.5A Siemens
6SE7021-5FC87-1FH0 FILTER,SINUS 3, 500-575V AC 15.1A Siemens
6SE7021-5UB61 INV,AC,575V,3PH,7.5KW,15.1A,VB Siemens
6SE7021-6CS87-2DA1 6SE70 BRAKE UNIT 270-310V DC, 5KW Siemens
6SE7021-6ES87-2DA0 Braking Unit Siemens
6SE7021-6ES87-2DA1 Master Drives Braking Unit Siemens
6SE7021-8EB20 Electronic Frequency Converter AC Drive Siemens
6SE7021-8EB51 Simover Masterdrives Converter - 7.5 KW Siemens
6SE7021-8EB51-1AA1 SIMOVERT,DR,AC,460V,3PH,7.5KW,17.5A.MC Siemens
6SE7021-8EB51-Z Simover Masterdrives Converter - 7.5 KW Siemens
6SE7021-8EB61 Simover Masterdrives Converter - 7.5 KW Siemens
6SE7021-8EB61-Z Simover Masterdrives Converter - 7.5 KW Siemens
6SE7021-8EB71 Simover Masterdrives Converter - 7.5 KW Siemens
6SE7021-8EB71-1AA1 SIMOVERT,DR,AC,460V,3PH,7.5KW,17.5A,VB Siemens
6SE7021-8EB71-Z Simover Masterdrives Converter - 7.5 KW Siemens
6SE7021-8EB81 SIMOVERT,DR,AC,460V,3PH,7.5KW,17.5A,VB Siemens
6SE7021-8EB84-1HF3 PWR EL.UNIT PEU 17.5A 3AC 380-460V Siemens
6SE7021-8EB87-1FC0 SINE WAVE FILTER 3PH,380-460V,17.5A Siemens
6SE7021-8EP87-0FB0 Simovert Line Filter - 18A Siemens
6SE7021-8EP87-0FB1 RFI WITH 2 Prcnt REACTOR, 18A Siemens
6SE7021-8ES87-0FB1 RFI,5.5-7.5KW-460/3-4KW-230 Siemens
6SE7021-8ES87-1FE0 OUTPUT REACTOR,3PH,380-460VAC,17.5A, FMA Siemens
6SE7021-8TB51 Simovert Masterdrive Inverter - 7.5 KW Siemens
6SE7021-8TB51-1AA1 SIMOVERT,INV,AC,460V,3PH,7.5KW,17.5A,MC Siemens
6SE7021-8TB51-Z Simovert Masterdrive Inverter - 7.5 KW Siemens
6SE7021-8TB61 Simovert Masterdrive Inverter - 7.5 KW Siemens
6SE7021-8TB61-Z Simovert Masterdrive Inverter - 7.5 KW Siemens
6SE7021-8TB71 Simovert Masterdrive Inverter - 7.5 KW Siemens
6SE7021-8TB71-1AA1 SIMOVERT,INV,AC,460V,3PH,7.5KW,17.5A,VB Siemens
6SE7021-8TB71-Z Simovert Masterdrive Inverter - 7.5 KW Siemens
6SE7021-8TB84-1HF3 POWER ELECTRONIC UNIT PEU 17.5A Siemens
6SE7021-8TP50 Simovert Control Compact Plus Inverter - 7.5 KW Siemens
6SE7021-8TP50-Z Simovert Control Compact Plus Inverter - 7.5 KW Siemens
6SE7021-8TP60 Simovert Control Compact Plus Inverter - 7.5 KW Siemens
6SE7021-8TP60-Z Simovert Control Compact Plus Inverter - 7.5 KW Siemens
6SE7021-8TP70 Simovert Control Compact Plus Inverter - 7.5 KW Siemens
6SE7021-8TP70-Z Simovert Control Compact Plus Inverter - 7.5 KW Siemens
6SE7022-0ES87-2DC0 SIMOVERT DR,BRK RESISTOR 380-460VAC,12KW Siemens
6SE7022-1EC85-1AA0 CNV, RGN,460V,7.5KW,18A Siemens
6SE7022-1EP50 Masterdrive Compact Plus Converter - 7.5 KW Siemens
6SE7022-1EP50-Z Masterdrive Compact Plus Converter - 7.5 KW Siemens
6SE7022-1EP60 Masterdrive Compact Plus Converter - 7.5 KW Siemens
6SE7022-1EP60-Z Masterdrive Compact Plus Converter - 7.5 KW Siemens
6SE7022-1EP70 Masterdrive Compact Plus Converter - 7.5 KW Siemens
6SE7022-1EP70-Z Masterdrive Compact Plus Converter - 7.5 KW Siemens
6SE7022-2FC61 DRVMSTR CNV VC 22A AC 500-600V AC Siemens
6SE7022-2FC87-1FD0 FILTER,DV/DT,11KW,6SE70 Siemens
6SE7022-2FS87-1FE0 SIMOVERT OUTPUT REACTOR Siemens
6SE7022-2UC61 SIMOVERT MDVC INV,675-810V DC,22A,11KW Siemens
6SE7022-5FA87-2DA0 Braking Unit Siemens
6SE7022-6EC20 Simovert Masterdrive Converter - 11 KW Siemens
6SE7022-6EC51 Simover Masterdrives Converter - 11 KW Siemens
6SE7022-6EC51-1AA1 SIMOVERT,DR,AC,460V,3PH,11KW,25.5A,MC Siemens
6SE7022-6EC51-Z Simover Masterdrives Converter - 11 KW Siemens
6SE7022-6EC61 Simover Masterdrives Converter - 11 KW Siemens
6SE7022-6EC61-Z Simover Masterdrives Converter - 11 KW Siemens
6SE7022-6EC71 Simover Masterdrives Converter - 11 KW Siemens
6SE7022-6EC71-1AA1 SIMOVERT,DR,3AC 380V-460V,25.5,AFE,11KW Siemens
6SE7022-6EC71-Z Simover Masterdrives Converter - 11 KW Siemens
6SE7022-6EC81 MASTERDRIVES 3AC 380V-460V,25.5,AFE,11KW Siemens
6SE7022-6EC84-1HF3 PEU7 25,5A 3 AC 380-460V Siemens
6SE7022-6EC87-1FC0 SINE WAVE FILTER,3PH,380-460V,11KW Siemens
6SE7022-6ES87-1FG0 AFE REACTOR,3PH,460V,25.5A,7.5KW W Siemens
6SE7022-6TC51 Simovert Masterdrive Inverter - 11 KW Siemens
6SE7022-6TC51-1AA1 SIMOVERT,INV,AC,460V,3PH,11KW,25.5A,MC Siemens
6SE7022-6TC51-Z Simovert Masterdrive Inverter - 11 KW Siemens
6SE7022-6TC61 Simovert Masterdrive Inverter - 11 KW Siemens
6SE7022-6TC61-Z Simovert Masterdrive Inverter - 11 KW Siemens
6SE7022-6TC71 Simovert Masterdrive Inverter - 11 KW Siemens
6SE7022-6TC71-1AA1 SIMOVERT,INV,AC,460V,3PH,11 KW,25.5A,VB Siemens
6SE7022-6TC71-Z Simovert Masterdrive Inverter - 11 KW Siemens
6SE7022-6TC84-1HF3 PEU7 25,5A DC 510-620V NEU Siemens
6SE7022-6TP50 Simovert Control Compact Plus Inverter - 11 KW Siemens
6SE7022-6TP50-Z Simovert Control Compact Plus Inverter - 11 KW Siemens
6SE7022-6TP60 Simovert Control Compact Plus Inverter - 11 KW Siemens
6SE7022-6TP60-Z Simovert Control Compact Plus Inverter - 11 KW Siemens
6SE7022-6TP70 Simovert Control Compact Plus Inverter - 11 KW Siemens
6SE7022-6TP70-Z Simovert Control Compact Plus Inverter - 11 KW Siemens
6SE7022-7EP50 Masterdrive Compact Plus Converter - 11 KW Siemens
6SE7022-7EP50-Z Masterdrive Compact Plus Converter - 11 KW Siemens
6SE7022-7EP60 Masterdrive Compact Plus Converter - 11 KW Siemens
6SE7022-7EP60-Z Masterdrive Compact Plus Converter - 11 KW Siemens
6SE7022-7EP70 Masterdrive Compact Plus Converter - 11 KW Siemens
6SE7022-7EP70-Z Masterdrive Compact Plus Converter - 11 KW Siemens
6SE7022-7FC85-1AA0 SIMOVERT,DR,RECT,AC,550V,3PH,27A,CP Siemens
6SE7023-0UD61 INV,AC,575V,3PH,18.5KW,29A,VB Siemens
6SE7023-2CS87-2DA1 6SE70 BRAKE UNIT 270-310V DC,10KW Siemens
6SE7023-2CS87-2DC0 MD RES,15KW,1.5KW,10 OHM Siemens
6SE7023-2EA87-2DA0 Braking Unit Siemens
6SE7023-2ES87-2DA1 Masterdrives Braking Unit Siemens
6SE7023-2ES87-2DC0 Breaking Resistor Siemens
6SE7023-4EC20 Simovert Masterdrive Siemens
6SE7023-4EC51 Simover Masterdrives Converter - 15 KW Siemens
6SE7023-4EC51-1AA1 SIMOVERT,DR,AC,460V,3PH,15KW,34A,MC Siemens
6SE7023-4EC51-Z Simover Masterdrives Converter - 15 KW Siemens
6SE7023-4EC61 Simover Masterdrives Converter - 15 KW Siemens
6SE7023-4EC61-Z Simover Masterdrives Converter - 15 KW Siemens
6SE7023-4EC71 Simover Masterdrives Converter - 15 KW Siemens
6SE7023-4EC71-1AA1 SIMOVERT,DR,AC,460V,3PH,15KW,34A,VB Siemens
6SE7023-4EC71-Z Simover Masterdrives Converter - 15 KW Siemens
6SE7023-4EC81 SIMOVERT,DR,AC,460V,3PH,15KW,34A,VB Siemens
6SE7023-4EC84-1HF3 PEU 34A 3 AC 380-460V Siemens
6SE7023-4EP50 Masterdrive Compact Plus Converter - 15 KW Siemens
6SE7023-4EP50-Z Masterdrive Compact Plus Converter - 15 KW Siemens
6SE7023-4EP60 Masterdrive Compact Plus Converter - 15 KW Siemens
6SE7023-4EP60-Z Masterdrive Compact Plus Converter - 15 KW Siemens
6SE7023-4EP70 Masterdrive Compact Plus Converter - 15 KW Siemens
6SE7023-4EP70-Z Masterdrive Compact Plus Converter - 15 KW Siemens
6SE7023-4ES87-0FB1 FILTER,RFI,VC/MC,380-460V,36AMPS, Siemens
6SE7023-4ES87-1FE0 REACTOR,OUT,460V,15KW,IRON Siemens
6SE7023-4FC87-1FD0 FILTER,DV/DT,15KW, Siemens
6SE7023-4FD61 DR,AC,575V,3PH,22KW,34A,VB Siemens
6SE7023-4FD84-1HF3 MD POWER CONTROLLER MOD.34A,500-575V AC Siemens
6SE7023-4FD84-1HF4 POWER CONTROLLER MOD. PEU F 34A,3PH Siemens
6SE7023-4FS87-1FE0 SIMOVERT OUTPUT REACTOR Siemens
6SE7023-4TC51 Simovert Masterdrive Inverter - 15 KW Siemens
6SE7023-4TC51-1AA1 SIMOVERT, DR,INV,AC,460V,3PH,15KW,34A,MC Siemens
6SE7023-4TC51-Z Simovert Masterdrive Inverter - 15 KW Siemens
6SE7023-4TC61 Simovert Masterdrive Inverter - 15 KW Siemens
6SE7023-4TC61-Z Simovert Masterdrive Inverter - 15 KW Siemens
6SE7023-4TC71 Simovert Masterdrive Inverter - 15 KW Siemens
6SE7023-4TC71-1AA1 SIMOVERT,DR,INV,600V,15 KW,34.0A Siemens
6SE7023-4TC71-Z Simovert Masterdrive Inverter - 15 KW Siemens
6SE7023-4TC84-1HF3 PCB,PWR BD,34A,510-620V DC Siemens
6SE7023-4TC84-6HF3 SIMOVERT MD PEU7 POWER SECTION BOARD Siemens
6SE7023-4TP50 Simovert Control Compact Plus Inverter - 15 KW Siemens
6SE7023-4TP60 Simovert Control Compact Plus Inverter - 15 KW Siemens
6SE7023-4TP70 Simovert Control Compact Plus Inverter - 15 KW Siemens
6SE7023-4TP70-Z Simovert Control Compact Plus Inverter - 15 KW Siemens
6SE7023-4UD61 INV,AC,575V,3PH,22KW,34A,VB Siemens
6SE7023-8ED20 Drive Unit Siemens
6SE7023-8ED51 DR,AC,460V,3PH,18.5KW,37.5A,MC Siemens
6SE7023-8ED71 SIMOVERT,DR,AC,460V,3PH,18.5KW,37.5A,MC Siemens
6SE7023-8ED71-1AA1 SIMOVERT,DR,AC,460V,3PH,18.5KW,37.5A,MC Siemens
6SE7023-8EP87-0FB1 RI SUPPRESSION FILTER,380-480V,38 A,3PH Siemens
6SE7023-8TD51 INV,AC,460V,3PH,18.5KW,37.5A,MC Siemens
6SE7023-8TD51-1AA1 SIMOVERT,INV,AC,600V,3PH,18.5KW,37.5A,MC Siemens
6SE7023-8TD61 INV,AC,460V,3PH,18.5W,37.5A,VC Siemens
6SE7023-8TD71 SIMOVERT,INV,AC,460V,3PH,18.5W,37.5A,VC Siemens
