MKS 653B-8-200J-2,MKS 653B-8-200J-2
ºìÍâÈÈÏñÒÇÊÇÒ»¸ö·¢Õ¹Ç°¾°·Ç³£¹ãÀ«µÄÐÂÐ˸߿Ƽ¼²úÆ·£¬ºìÍâÈÈÏñÒǹ㷺ӦÓÃÓÚ¾üÃñÁ½¸öÁìÓò¡£ÔÚÏÖ´úÕ½ÕùÌõ¼þÏ£¬ºìÍâÈÈÏñÒÇÒÑÔÚÎÀÐÇ¡¢µ¼µ¯¡¢·É»úµÈ¾üÊÂÎäÆ÷ÉÏ»ñµÃÁ˹㷺µÄÓ¦Óã»Í¬Ê±£¬Ëæ×Å·ÇÖÆÀäºìÍâÈȳÉÏñ¼¼ÊõµÄ·¢Õ¹£¬ÓÈÆäÊÇËæ×ŲúÒµ»¯¹ý³ÌÖÐÉú²ú³É±¾µÄ´ó·ù¶È½µµÍ£¬ºìÍâÈÈÏñÒÇÒÑÔÚµçÁ¦¡¢Ïû·À¡¢¹¤Òµ¡¢Ò½ÁÆ¡¢°²·ÀµÈ¹úÃñ¾¼ÃµÄ¸÷¸ö²¿Ãŵõ½Á˷dz£¹ã·ºµÄÓ¦Óá£ÊʺϹ¤ÒµÉ豸ÈȹÊÕϲéѰµÄ°²È«¼ì²âÉ豸 £¬¿ÉÒÔ¶ÔÔ˶¯µÄÎïÌå½øÐвâΠ¡£ÊÇĿǰ×î¼ÑµÄÎÞËð¼ì²âÊÖ¶ÎÖ®Ò»£¬ÉîÊÜÒµ½çÖØÊÓ¡£Ïê¼ûͼ5ζȲâÁ¿¼¼ÊõµÄ½øÕ¹¡£²îѹʽÁ÷Á¿¼ÆµÄ½øÕ¹ÎÒÃDz»·ÁÔÙÒÔ²îѹʽÁ÷Á¿¼Æ²úÆ··¢Õ¹ÎªÀýÔÙÀ´»Ø¹ËÒ»ÏÂÕâ¶ÎÀúÊ·£¬Ïê¼ûͼ6Ëùʾ¡£×Ô1738ÄêÈðÊ¿È˵¤Äá¶ûÒÔ²®Å¬Àû·½³ÌΪ»ù´¡£¬ÀûÓòîѹ·¨²âÁ¿Ë®Á÷Á¿ÒÔÀ´£¬´Ë¼¼ÊõÒѺܳÉÊì¡£¸Ã·½·¨Ô¼Õ¼¸÷ÖÖÁ÷Á¿²âÁ¿·½·¨µÄ70£¥¡£ÔÚÕâÂþ³¤µÄ·¢Õ¹½ø³ÌÖУ¬½ÚÁ÷×°ÖÃÒ»Ö±ÑØÓÃÖÁ½ñ¡£×÷Ϊ²îѹʽÁ÷Á¿¼ÆµÄ²îѹ¼ì²â²¿¼þ£¬¼´²îѹ±äËÍÆ÷£¬×î³õ²ÉÓÃUÐÍË«¹Ü²îѹ¼ÆºÍ·ÂËյĻúеʽ¸¡×ÓË®Òø²îѹ¼Æ£¬ºóΪʵÏÖÎÞË®Òø»¯¼ì²â£¬±»Ë«²¨ÎƲîѹ¼ÆËùÈ¡´ú¡£20ÊÀ¼Í50Äê´úµÄµç¸ÐĤºÐʽ²îѹ±äËÍÆ÷£¬ÊÇÀûÓÃѹ²îʹÌúоÔÚÏßȦÄÚÉÏÏÂÒÆ£¬Ðγɵç¸ÐÁ¿·¢Éú±ä»¯£¬Äܽ«²îѹÐźÅת³ÉµçÐźŽøÐÐÔ¶´«¡£60Äê´ú³öÏÖÁËÆø¶¯¡¢µç¶¯Ê½Á¦Æ½ºâʽ²îѹ±äËÍÆ÷¡£70Äê´ú³öÏÖÁËÔÀíÉÏÓдóµÄ´´ÐµÄÎ¢Î»ÒÆÊ½²îѹ±äËÍÆ÷£¬ÉÏÊö¶¼ÒÔÄ£Äâ¼¼ÊõΪÖ÷ÒªÌØÕ÷¡£80Äê´ú£¬ÒòÖÇÄܱäËÍÆ÷µÄ³öÏÖ£¬ÒÔÊýÄ£»ìºÏ¼¼ÊõÎªÌØÕ÷£¬±êÖ¾×ÅÄ£ÄâÒDZíÏòÊý×Ö»¯ÖÇÄÜÒDZíµÄת±ä£¬ÐγÉÒ»Ì廯(¼¯³É)²îѹ±äËÍÆ÷²úÆ·¡£21ÊÀ¼ÍÒÔÀ´£¬ÎÞÏß¡¢¶à±äÁ¿±äËÍÆ÷ºÍÌ«ÑôÄܹ©µç±äËÍÆ÷¾ù·×·×ÉÏÊС£A6X30054564 INV,AC,480V,3PH,0.75KW,2.0A,VCP +OPTS Siemens
A6X30054566 INV,AC,480V,3PH,0.75KW,2.0A,VCP +OPTS Siemens
A6X30054567 INV,AC,480V,3PH,0.75KW,2.0A,VCP +OPTS Siemens
A6X30054568 INV,AC,480V,3PH,4KW,10.2A,VCP +OPTS Siemens
A6X30054730 SPEED CONTROLLER,AC,480V,3PH,0.75KW, Siemens
A6X30054988 DR,AC,460V,3PH,7.5KW,17.5A,VB+OPTION Siemens
A6X30055048 INV,AC,480V,3PH,4KW,10.2A,VCP + OPTS Siemens
A6X30055160 INV,AC,480V,3PH,2.2KW,6.1A,VCP + OPTS Siemens
A6X30055198 INV,AC,650V,3PH,4KW,10.2A,CP Siemens
A6X30055272 SIMOVERT,INV,AC,480V,3PH,4KW,10.2A +OPTS Siemens
A6X30055397 INV,AC,650V,3PH,15KW,34A,CP + OPTS Siemens
A6X30055712 SIMOVERT MASTERDRIVES Siemens
A6X30055802 DR,AC,460V,3PH,30KW,59A,MC +OPTS Siemens
A6X30055803 INV,AC,480V,3PH,1.5KW,4A,SAFE OFF+OPTS Siemens
A6X30055815 INV,AC,460V,3PH,15 KW,34.0A,VB +OPT Siemens
A6X30055868 SIMOVERT MD MC, 460V,3PH,45KW,92A+OPTS Siemens
A6X30055882 DR,AC,460V,3PH,15KW,34A,CP+OPTS Siemens
A6X30055986 INV,AC,460V,3PH,132KW,260A,VCH+OPTS Siemens
A6X30056091 MDVC,COMPACT+,380-480V,3AC,34A,COMM MODU Siemens
A6X30056121 INVERTER,AC,480V,3PH,22KW,47A,MCP2,CP+OP Siemens
A6X30056215 DR,AC,460V,3PH,37.0KW,72.0A,VB + OPTS Siemens
A6X30056745 SIMOVERT,INV,AC,600V,18.5KW,37.5A,VCP+OP Siemens
A6X30056851 INV,AC,460V,3PH,200KW,370A,VCH +OPTS Siemens
A6X30056865 INVERTER,AC,480V,3PH,22KW,47A,VC,CP+OPTS Siemens
A6X30056902 INV,AC,460V,3PH,55KW,124A,VCH +OPTS Siemens
A6X30056903 INV,AC,460V,3PH,132KW,260A,VCH +OPTS Siemens
A6X30056932 INV,AC,460V,3PH,90KW,186A,VCH +OPTS Siemens
A6X30056939 INV,AC,460V,3PH,7.5KW,17.5A,CP + OPTS Siemens
A6X30057462 INV,AC,460V,3PH,2.2KW,6.1A,MC,K80 + OPTS Siemens
A6X30057520 INV,AC,480V,3PH,5.5KW,13.2A,VCP + OPT Siemens
A6X30057540 INV,AC,460V,3PH,3KW,8A,VB+OPTS Siemens
A6X30057551 INV,AC,480V,3PH,7.5KW,17.5A,VCP + OPT Siemens
A6X30057581 INV,AC,460V,3PH,22.KW,47.0A,VB + OPTS Siemens
A6X30057655 SIMOVERT,DR,AC,460V,3PH,11KW,27A,CP+OPTS Siemens
A6X30058000 DR,AC,460V,3PH,3KW,8A,CP + OPTS Siemens
A6X30058196 INV,AC,460V,3PH,2.2KW,6.1A,VB+OPTS Siemens
A6X30058437 INV,AC,460V,3PH,1.5KW,4A,CP + OPTS Siemens
A6X30058503 DR,AC,460V,3PH,3KW,8A,VB + OPT Siemens
A6X30058773 INV,AC,460V,3PH,5.5KW,13.2A,MC +OPTS Siemens
A6X30058774 INV,AC,460V,3PH,22.KW,47.0A,VB +OPTS Siemens
A6X30058775 INV,AC,460V,3PH,37.0W,72.0A,VB + OPT Siemens
A6X30058776 INV,AC,460V,3PH,55KW,124A,VCH +OPTS Siemens
A6X30058777 INV,AC,460V,3PH,110KW,210A,VCH +OPTS Siemens
A6X30059016 INV,AC,460V,3PH,7.5KW,17.5A,CP+OPTS Siemens
A6X30059256 DR,AC,460V,3PH,1.5KW,5A,CP +OPTS Siemens
A6X30059307 DR,AC,460V,3PH,3KW,8A,VB+OPTS Siemens
A6X30059351 SIMOVERT,DR,AC,460V,3PH,11KW,27A,CP+OPTS Siemens
A6X30059538 SIMOVERT MD INV, 650V,250KW,510A+OPTS Siemens
A6X30059588 INV,AC,480V,3PH,4KW,10.2A,VCP + OPTIONS Siemens
A6X30059589 INV,AC,650V,3PH,15KW,34A,VCP +OPTS Siemens
A6X30059607 DR,AC,460V,3PH,250.KW,510A,VCH+OPTS Siemens
A6X30059862 INV,AC,460V,3PH,7.5KW,17.5A,VB +OPTS Siemens
A6X30059892 DR,AC,460V,3PH,4KW,10A,CP + OPTIONS Siemens
A6X30060577 DR,AC,460V,3PH,3KW,8A,CP +OPTS Siemens
A6X30060826 INV,AC,460V,3PH,4KW,10.2A,CP +OPTIONS Siemens
A6X30061132 INV,AC,460V,3PH,15 KW,34.0A,VB +OPT Siemens
A6X30061534 SIMOVERT MD MC,480V,3PH,55.0KW,124A+OPTS Siemens
A6X30062427 SIMOVERT MD MC INV,650V,110KW,218A+OPTS Siemens
A6X30062779 INV,AC,460V,3PH,18.5W,37.5A,VC+OPTS Siemens
A6X30063171 INV,AC,460V,3PH,55KW,124A,VCH+OPTS Siemens
A6X30063172 SIMOVERT,INV,AC,650V,3PH,7.5KW,17.5A+OPT Siemens
A6X30063211 INV,AC,460V,3PH,4KW,10.2A,CP+OPTS Siemens
A6X30063213 INV,AC,460V,3PH,4KW,10.2A,CP+OPTS Siemens
A6X30063265 INV,AC,480V,3PH,0.75KW,2.0A,VCP+OPTS Siemens
A6X30063761 INV,AC,460V,3PH,37KW,72A,MC+OPTS Siemens
A6X30064141 INV,AC,460V,3PH,4KW,10.2A,CP+OPTS Siemens
A6X30064143 MCMD,INV,AC,650V,3PH,2.2KW,6.1A,CP+OPTS Siemens
A6X30065157 INV,AC,460V,3PH,2.2KW,6.1A,CP + OPTS Siemens
A6X30065158 INV,AC,460V,3PH,2.2KW,6.1A,CP + OPTS Siemens
A6X30065228 INV,AC,460V,3PH,2.2KW,6.1A,MC+ OPTS Siemens
A6X30065229 INV,AC,460V,3PH,37KW,72A,MC + OPTS Siemens
A6X30065253 INV,AC,480V,3PH,5.5KW,13.2A,VCP+OPTIONS Siemens
A6X30065303 MD MC,480V,3PH,1.1KW,3A +OPTS Siemens
A6X30065437 MD VC CONV,3PH,480V,200KW,370A +OPT Siemens
A6X30065549 INV,DC,650V,3PH,30KW,59A,MC+OPTIONS Siemens
A6X30065714 DR,AC,380-480V,47A,22KW +OPTS Siemens
A6X30065938 INV,AC,460V,3PH,3KW,8A,VB+OPT Siemens
A6X30066117 INV,AC,460V,3PH,4KW,10.2A,MC +OPTS Siemens
A6X30066344 INV,AC,460V,3PH,55KW,124A,VCH +OPTS Siemens
A6X30066350 INV,AC,460V,3PH,11KW,25.5A,MC+OPTS Siemens
A6X30066381 INV,DC,650V,3PH,30KW,59A,MC,K80-SAFE+OPT Siemens
A6X30066447 INV,AC,460V,3PH,4KW,10.2A,CP +OPTS Siemens
A6X30067469 SIMOVERT MDMC480V,3PH,110KW,210A,60HZ+OP Siemens
A6X30067496 SIMOVERT,DR,INV,650V,47A,MC,OPTS Siemens
A6X30067689 DR,AC,460V,3PH,11 KW,25.5A,VB+OPTS Siemens
A6X30067833 DR,AC,460V,3PH,15KW,34A,CP+G91 Siemens
A6X30067835 DR,AC,460V,3PH,11 KW,25.5A,VB+OPTS Siemens
A6X30068101 INV,AC,460V,3PH,1.5KW,4A,CP+OPTS Siemens
A6X30069151 DR,AC,460V,3PH,5.5KW,13.2A,VCP +OPTS Siemens
A6X30069298 SIMOVERT,DR,AC,460V,3PH,11KW,27A,CP+OPT Siemens
A6X30069441 INV,AC,460V,3PH,2.2KW,6.1A,CP + OPTS Siemens
A6X30069648 INV,AC,480V,3PH,7.5KW,17.5A,VCP+OPTS Siemens
A6X30069649 SIMOVERT,DR,INV,AC,600V,15KW,34A+OPTS Siemens
A6X30069751 INV,AC,480V,3PH,30KW,59A,MCP2,CP+OPTS Siemens
A6X30069915 MD MC PERF2 INV,650V,132KW,262A + OPTS Siemens
A6X30069963 INV,AC,460V,3PH,37KW,72A,MC+OPTS Siemens
A6X30070163 SIMOVERT,DR,AC,460V,3PH,11KW,27A,CP+OPTS Siemens
A6X30070970 INV,AC,460V,3PH,132KW,260A,VCH +OPT Siemens
A6X30071122 INV,DC,460V,3PH,45KW,92A,VCH +OPTS Siemens
A6X30071338 DR,AC,460V,3PH,37.0KW,72.0A,VB +OPT Siemens
A6X30071662 DR,AC,460V,3PH,7.5KW,20.5A,CP+OPT Siemens
A6X30071810 DR,AC,460V,3PH,5.5KW,14A,CP+OPTS Siemens
A6X30071901 INV,AC,460V,3PH,11KW,25.5A,CP+OPTS Siemens
A6X30071947 INV,AC,480V,3PH,15KW,34A,VCP+OPTS Siemens
A6X30071948 1NV,AC,480V,3PH,15KW,34A,VCP+OPTS Siemens
A6X30071999 DR,AC,460V,3PH,4KW,10A,CP +OPTS Siemens
A6X30072017 DR,AC,460V,3PH,4KW,10.2A,MC + OPT G93 Siemens
A6X30072970 INV,AC,480V,3PH,2.2KW,6.1A,VCP+OPTS Siemens
A6X30073031 INV,AC,480V,3PH,7.5KW,17.5A,VCP+OPTS Siemens
A6X30073092 INV,AC,480V,3PH,11KW,25.5A,VCP +OPTS Siemens
A6X30073221 DR,AC,460V,3PH,11 KW,25.5A,VB+OPTS Siemens
A6X30073262 INV,AC,460V,3PH,7.5KW,17.5A,MC+OPTS Siemens
A6X30073263 INV,AC,460V,3PH,5.5KW,13.2A,MC +OPTS Siemens
A6X30073266 INV,AC,480V,3PH,18.5KW,37.5A,VCP +OPTS Siemens
A6X30074182 INV,AC,460V,3PH,37KW,72A,MC +OPTS Siemens
A6X30074892 INV,AC,480V,3PH,7.5KW,17.5A,VCP + OPT Siemens
A6X30074927 INV,AC,460V,3PH,18.5KW,37.5A,CP+OPTS Siemens
A6X30075029 INV,AC,460V,3PH,4KW,10.2A,VB + OPT Siemens
A6X30075374 INV,AC,460V,3PH,132KW,260A,VCH +OPTS Siemens
A6X30076188 SIMOVERT MD MC 650V,90KW,175A+OPTS Siemens
A6X30076567 SIMOVERT,DR,VC,INV,AC,640V,30KW,59A+OPTS Siemens
A6X30077093 DR,AC,460V,3PH,5.5KW,13.2A,VCP +OPTS Siemens
A6X30077192 INV,AC,460V,3PH,18.5KW,37.5A,CP +OPTS Siemens
A6X30078062 SIMOVERT MD MC,480V,3PH,55.0KW,124A+OPTS Siemens
A6X30079289 INV,AC,460V,3PH,1.5KW,4A,CP+OPTS Siemens
A6X30079346 SIMOVERT,DR,INV,600V,47A,MC +OPTS Siemens
A6X30080211 DR,AC,460V,3PH,7.5KW,20.5A,CP+OPT Siemens
A6X30080581 DR,AC,460V,3PH,11KW,27A,CP,P2 +OPTS Siemens
A6X30083120 DR,AC,460V,3PH,45KW,92A,MC+OPTIONS Siemens
A6X30083894 INV,AC,650V,3PH,4KW,10.2A,CP+OPTIONS Siemens
A6X30083896 DR,AC,480V,4KW,10A,CP +OPTS Siemens
A6X30083934 INV,AC,460V,3PH,2.2KW,6.1A,MC +OPTS Siemens
A6X30084781 INV,AC,460V,3PH,4KW,10.2A,MC +OPTS Siemens
A6X30084798 INV,AC,460V,3PH,132KW,260A,VCH +OPTS Siemens
A6X30084881 INV,AC,460V,3PH,1.5KW,4A,CP+OPTS Siemens
A6X30084899 MD MC,480V,3PH,1.1KW,3A +OPT Siemens
A6X30085127 DRIVE,SIMOVERT MASTERDRIVES,3PH,380-460V Siemens
A6X30085367 DR,AC,460V,3PH,18.5KW,37.5A,VB +OPT Siemens
A6X30085617 DR,AC,460V,3PH,7.5KW,20.5A,CP+OPT Siemens
A6X30085660 NV,AC,460V,3PH,2.2KW,6.1A,CP+OPTS Siemens
A6X30085739 DR,AC,460V,3PH,1.5KW,5A,CP +OPTS Siemens
A6X30086646 INV,AC,460V,3PH,3KW,8A,VB+OPT Siemens
A6X30086779 INV,AC,460V,3PH,15KW,34A,MC +OPTS Siemens
A6X30087084 MD VC CONVERTER,COMP+,IP20,3AC,480V+OPT Siemens
A6X30087286 SIMOVERT MD MC, 460V,3PH,45KW,92A+OPTS Siemens
A6X30087592 DR,AC,460V,3PH,3KW,8A,CP +OPTS Siemens
BSM300GA120DN11S 9512 Simovert IGBT-Module Siemens
