Shimadzu EI-D2003M,Shimadzu EI-D2003M
¾ÍµØ¼ì²âÒDZí²Ù×÷ÔÚ20ÊÀ¼Í50Äê´ú£¬Ö÷ÒªÊÇÔÚ¹¤ÒÕÉ豸ÉÏÖ±½Ó°²×°¹¤ÒµÎ¶ȼơ¢µ¯»É¹ÜѹÁ¦±íºÍ²£Á§¹ÜҺλ¼Æ£¬½øÐÐÏÖ³¡Ä¿²â²ÎÊý£¬È˹¤²Ù×÷·§ÃÅ£¬´Ë·½·¨Ò»Ö±±£ÁôÖÁ½ñ¡£ÀýÈç±±¾©¼ÎÃúÔ°Ð¡ÇøµÄ×ÔÀ´Ë®Á÷Á¿Çл»·ÖÁ÷£¬¾ÍÀûÓÃѹÁ¦±íºÍÊÖ¶¯Çл»·§¸Ä±äÁ÷Ïò¡£¾ÍµØÒDZíÅ̲Ù×÷ÔÚ20ÊÀ¼Í60¡¢70Äê´úÀï³£²ÉÓþ͵ØÒDZíÅ̲Ù×÷¡£¾ÍÊÇÔÚ¹¤ÒÕÉ豸¸½½ü£¬ÉèÖþ͵ØÒDZíÅÌ£¨¹ñ£©£¬½«¼ì²â»òµ÷½ÚÒDZíÖ±½Ó×°ÔÚÒDZíÅÌ£¨¹ñ£©ÉÏ¡£Õã½´óѧ»¯¹¤×Ô¶¯»¯¼°ÒDZíר³öÓÚ1962Ä꽨Á¢µÄʵÑé×°ÖòÉÓþ͵ØÒDZíÅÌ·½Ê½£¬Ôö¼ÓÁ˲ÎÊý¼Ç¼¹¦ÄÜ¡£µ±¹¤ÒÕ×°Öüì²âµã´ïµ½¼¸Ê®¸öʱ£¬Í¨³£ÔÚÉ豸¸½½üÉèÁ¢ÏÖ³¡ÒDZíÅÌ£¨¹ñ£©£¬Îª²Ù×÷·§ÃÅ·½±ã£¬ÔÚ¹¤ÒÕÅä¹ÜʱÓÐÒâ°ÑÐè²Ù×÷µÄ·§Ãż¯Öа²×°ÔÚÏÖ³¡ÒDZíÅÌ£¨¹ñ£©¸½½ü£¬»ò¼Ó³¤·§ÃŵÄÊÖ±ú£¬±ãÓھ͵ؼ¯ÖвÙ×÷£¬¼õÇáÀͶ¯Ç¿¶È¡£¿ÉÒÔ½²Ä¿Ç°Ä³Ð©É豸»ò»ú×é×Ô´øµÄרÓÃÒDZí¹ñÊÇÔÚ´Ë»ù´¡ÉÏ·¢Õ¹¶ø³ÉµÄ¡£ÈçÄÜʵÏ־͵ØÊý×Ö»¯ÒDZí¹ñ£¬½øÐÐ¾ÍµØ¼à¿Ø£¬¶ÀÁ¢Õý³£ÔËÐУ¬ÔÙÀûÓÃͨѶÊÖ¶ÎÓëÉϼ¶¿ØÖÆÊÒ±£³ÖÁªÏµ£¬Ò²ÊÇÒ»ÖÖÁ¼²ß¡£
6SL3210-1KE21-7AC1 SINAMICS G120C 10HP LO Filtered CANopen Siemens
6SL3210-1KE21-7AF1 SINAMICS G120C,7.5KW,3AC,480V,FSB,FIL Siemens
6SL3210-1KE21-7AP1 SINAMICS G120C DP 7,5KW FILA Siemens
6SL3210-1KE21-7UB0 SINAMICS G120C RATED POWER 7,5KW WITH 1 Siemens
6SL3210-1KE21-7UB1 SINAMICS G120C USS/MB 7,5KW UNFIL Siemens
6SL3210-1KE21-7UC0 SINAMICS G120C RATED POWER 7,5KW WITH 1 Siemens
6SL3210-1KE21-7UC1 SINAMICS G120C 10HP LO Unfiltered Siemens
6SL3210-1KE21-7UF1 SINAMICS G120C,7.5KW,3AC,480V,FSB Siemens
6SL3210-1KE21-7UP0 SINAMICS G120C RATED POWER 7,5KW WITH 1 Siemens
6SL3210-1KE21-7UP1 MICS G120C DP 7,5KW UNFIL Siemens
6SL3210-1KE22-6AB0 SINAMICS G120C RATED POWER 11KW Siemens
6SL3210-1KE22-6AB1 SINAMICS G120C 15HP LO Filtered USS/MB Siemens
6SL3210-1KE22-6AC0 SINAMICS G120C RATED POWER 11,0KW WITH Siemens
6SL3210-1KE22-6AC1 SINAMICS G120C 15HP LO Filtered CANopen Siemens
6SL3210-1KE22-6AF1 SINAMICS G120C,11.0KW,3AC,480V,FSC,FIL Siemens
6SL3210-1KE22-6AP1 SINAMICS G120C DP 11.0KW,480V,FSC Siemens
6SL3210-1KE22-6UB0 SINAMICS G120C RATED POWER 11,0KW WITH Siemens
6SL3210-1KE22-6UB1 SINAMICS G120C USS/MB 11,0KW UNFIL Siemens
6SL3210-1KE22-6UC0 SINAMICS G120C RATED POWER 11,0KW WITH Siemens
6SL3210-1KE22-6UC1 SINAMICS G120C 15HP LO Unfiltered Siemens
6SL3210-1KE22-6UF1 SINAMICS G120C,11.0KW,3AC,480V,FSC,UNFIL Siemens
6SL3210-1KE22-6UP0 SINAMICS G120C RATED POWER 11,0KW WITH Siemens
6SL3210-1KE22-6UP1 SINAMICS G120C DP 11,0KW UNFIL Siemens
6SL3210-1KE23-2AB0 SINAMICS G120C RATED POWER 15,0KW WITH Siemens
6SL3210-1KE23-2AB1 SINAMICS G120C 20HP LO Filtered USS/MB Siemens
6SL3210-1KE23-2AC0 SINAMICS G120C RATED POWER 15,0KW WITH Siemens
6SL3210-1KE23-2AC1 SINAMICS G120C 20HP LO Filtered CANopen Siemens
6SL3210-1KE23-2AF1 SINAMICS G120C,15.0KW,3AC,480V,FSC,FIL Siemens
6SL3210-1KE23-2AP0 SINAMICS G120C RATED POWER 15,0KW WITH Siemens
6SL3210-1KE23-2AP1 SINAMICS G120C DP 15,0KW FILA Siemens
6SL3210-1KE23-2UB0 SINAMICS G120C RATED POWER 15,0KW WITH Siemens
6SL3210-1KE23-2UB1 SINAMICS G120C USS/MB 15,0KW UNFIL Siemens
6SL3210-1KE23-2UC0 SINAMICS G120C RATED POWER 15,0KW WITH Siemens
6SL3210-1KE23-2UC1 SINAMICS G120C 20HP LO Unfiltered Siemens
6SL3210-1KE23-2UF1 SINAMICS G120C,15.0KW,3AC,480V,FSC,UNFIL Siemens
6SL3210-1KE23-2UP1 SINAMICS G120C 15KW,3AC,480V,FSC,UNFIL Siemens
6SL3210-1KE23-8AB0 SINAMICS G120C RATED POWER 18,5KW WITH Siemens
6SL3210-1KE23-8AB1 SINAMICS G120C 25HP LO Filtered USS/MB Siemens
6SL3210-1KE23-8AC0 SINAMICS G120C RATED POWER 18,5KW WITH Siemens
6SL3210-1KE23-8AC1 SINAMICS G120C 25HP LO Filtered CANopen Siemens
6SL3210-1KE23-8AF1 SINAMICS G120C,18.5KW,3AC,480V,FSC,FIL Siemens
6SL3210-1KE23-8AP0 SINAMICS G120C RATED POWER 18,5KW WITH Siemens
6SL3210-1KE23-8AP1 SINAMICS G120C 25HP LO Filtered PROFIBUS Siemens
6SL3210-1KE23-8UB0 SINAMICS G120C USS/MB 18.5KW UNFIL Siemens
6SL3210-1KE23-8UB1 SINAMICS G120C USS/MB 18,5KW UNFIL Siemens
6SL3210-1KE23-8UC0 SINAMICS G120C RATED POWER 18,5KW WITH Siemens
6SL3210-1KE23-8UC1 SINAMICS G120C 25HP LO Unfiltered Siemens
6SL3210-1KE23-8UF1 SINAMICS G120C,18.5KW,3AC,480V,FSC Siemens
6SL3210-1KE23-8UP0 SINAMICS G120C RATED POWER 18,5KW WITH Siemens
6SL3210-1KE23-8UP1 SINAMICS G120C DP 18,5KW UNFIL Siemens
6SL3210-1NE11-3AL0 PM230 IP20 A A 380-480V 0.37KW Siemens
6SL3210-1NE11-3UL0 PM230 IP20 A U 380-480V 0.37KW Siemens
6SL3210-1NE11-7AL0 PM230 IP20 A A 380-480V 0.55KW Siemens
6SL3210-1NE11-7UL0 PM230 IP20 A U 380-480V 0.55KW Siemens
6SL3210-1NE12-2AL0 PM230 IP20 A A 380-480V 0.75KW Siemens
6SL3210-1NE12-2UL0 PM230 IP20 A U 380-480V 0.75KW Siemens
6SL3210-1NE13-1AL0 PM230 IP20 A A 380-480V 1.1KW Siemens
6SL3210-1NE13-1UL0 PM230 IP20 A U 380-480V 1.1KW Siemens
6SL3210-1NE14-1AL0 PM230 IP20 A A 380-480V 1.5KW Siemens
6SL3210-1NE14-1UL0 PM230 IP20 A U 380-480V 1.5KW Siemens
6SL3210-1NE15-8AL0 PM230 IP20 A A 380-480V 2.2KW Siemens
6SL3210-1NE15-8UL0 PM230 IP20 A U 380-480V 2.2KW Siemens
6SL3210-1NE17-7AL0 PM230 IP20 A A 380-480V 3KW Siemens
6SL3210-1NE17-7UL0 PM230 IP20 A U 380-480V 3KW Siemens
6SL3210-1NE21-0AL0 PM230 IP20 B A 380-480V 4KW Siemens
6SL3210-1NE21-0UL0 PM230 IP20 B U 380-480V 4KW Siemens
6SL3210-1NE21-3AL0 PM230 IP20 B A 380-480V 5.5KW Siemens
6SL3210-1NE21-3UL0 PM230 IP20 B U 380-480V 5.5KW Siemens
6SL3210-1NE21-8AL0 PM230 IP20 B A 380-480V 7.5KW Siemens
6SL3210-1NE21-8UL0 PM230 IP20 B U 380-480V 7.5KW Siemens
6SL3210-1NE22-6AL0 PM230 IP20 C A 380-480V 11KW Siemens
6SL3210-1NE22-6UL0 PM230 IP20 C U 380-480V 11KW Siemens
6SL3210-1NE23-2AL0 PM230 IP20 C A 380-480V 15KW Siemens
6SL3210-1NE23-2UL0 PM230 IP20 C U 380-480V 15KW Siemens
6SL3210-1NE23-8AL0 PM230 IP20 C A 380-480V 18.5KW Siemens
6SL3210-1NE23-8UL0 PM230 IP20 C U 380-480V 18.5KW Siemens
6SL3210-1NE27-5UL0 MODULE,SINAMICS PM230-IP20-FSD,400V 37KW Siemens
6SL3210-1PE11-8AL0 SINAMICS PM240-2 IP20-FSA-A-400V-0.55KW Siemens
6SL3210-1PE11-8UL0 SINAMICS PM240-2 IP20-FSA-U-400V-0.55KW Siemens
6SL3210-1PE12-3AL0 SINAMICS PM240-2 IP20-FSA-A-400V-0.75KW Siemens
6SL3210-1PE12-3UL0 SINAMICS PM240-2 IP20-FSA-U-400V-0,75KW Siemens
6SL3210-1PE14-3AL0 SINAMICS PM240-2 IP20-FSA-A-400V-1.5KW Siemens
6SL3210-1PE18-0UL0 SINAMICS PM240-2 IP20-FSA-U-400V-3KW Siemens
6SL3210-1SB11-0AA0 SINAMICS Drive Siemens
6SL3210-1SB11-0UA0 SINAMICS Drive Siemens
6SL3210-1SB12-3AA0 SINAMICS Drive Siemens
6SL3210-1SB12-3UA0 SINAMICS Drive Siemens
6SL3210-1SB14-0AA0 SINAMICS Drive Siemens
6SL3210-1SB14-0UA0 SINAMICS Drive Siemens
6SL3210-1SE11-3UA0 SINAMICS Drive Siemens
6SL3210-1SE11-7UA0 SINAMICS Drive Siemens
6SL3210-1SE12-2UA0 SINAMICS Drive Siemens
6SL3210-1SE13-1UA0 SINAMICS Drive Siemens
6SL3210-1SE14-1UA0 SINAMICS Drive Siemens
6SL3210-1SE16-0AA0 SINAMICS Drive Siemens
6SL3210-1SE16-0UA0 SINAMICS Drive Siemens
6SL3210-1SE17-7AA0 SINAMICS Drive Siemens
6SL3210-1SE17-7UA0 SINAMICS Drive Siemens
6SL3210-1SE21-0AA0 SINAMICS Drive Siemens
6SL3210-1SE21-0UA0 SINAMICS Drive Siemens
6SL3210-1SE21-8AA0 SINAMICS Drive Siemens
6SL3210-1SE21-8UA0 SINAMICS Drive Siemens
6SL3210-1SE22-5AA0 SINAMICS Drive Siemens
6SL3210-1SE22-5UA0 SINAMICS Drive Siemens
6SL3210-1SE23-2AA0 SINAMICS Drive Siemens
6SL3210-1SE23-2UA0 SINAMICS Drive Siemens
6SL3210-1SE23-8AA0 SINAMICS Drive Siemens
6SL3210-1SE23-8UA0 SINAMICS Drive Siemens
6SL3210-1SE24-5AA0 SINAMICS Drive Siemens
6SL3210-1SE24-5UA0 SINAMICS Drive Siemens
6SL3210-1SE26-0AA0 SINAMICS Drive Siemens
6SL3210-1SE26-0UA0 SINAMICS Drive Siemens
6SL3210-1SE27-5AA0 SINAMICS Drive Siemens
6SL3210-1SE27-5UA0 SINAMICS Drive Siemens
6SL3210-1SE31-0AA0 SINAMICS Drive Siemens
6SL3210-1SE31-0UA0 SINAMICS Drive Siemens
6SL3210-1SE31-1AA0 SINAMICS Drive Siemens
6SL3210-1SE31-1UA0 SINAMICS Drive Siemens
6SL3210-1SE31-5AA0 SINAMICS Drive Siemens
6SL3210-1SE31-5UA0 SINAMICS Drive Siemens
6SL3210-1SE31-8AA0 SINAMICS PM340,3AC 380-480V,178A Siemens
6SL3210-1SE31-8UA0 SINAMICS Drive Siemens
6SL3210-5BB11-2AV0 SINAMICS V20, 1AC230V 0,12KW FILTER A Siemens
6SL3210-5BB11-2UV0 SINAMICS V20, 1AC230V 0.12KW UNFILTERED Siemens
6SL3210-5BB12-5AV0 SINAMICS V20, 1AC230V 0,25KW FILTER A Siemens
6SL3210-5BB12-5UV0 SINAMICS V20, 1AC230V 0.25KW UNFILTERED Siemens
6SL3210-5BB13-7AV0 SINAMICS V20, 1AC230V 0,37KW FILTER A Siemens
6SL3210-5BB13-7UV0 SINAMICS V20, 1AC230V 0.37KW UNFILTERED Siemens
6SL3210-5BB15-5AV0 SINAMICS V20, 1AC230V 0,55KW FILTER A Siemens
6SL3210-5BB15-5UV0 SINAMICS V20, 1AC230V 0.55KW UNFILTERED Siemens
6SL3210-5BB17-5AV0 SINAMICS V20, 1AC230V 0,75KW FILTER A Siemens
6SL3210-5BB17-5UV0 SINAMICS V20, 1AC230V 0.75KW UNFILTERED Siemens
6SL3210-5BB18-0AV0 SINAMICS V20, 1AC230V 1HP FILTER A Siemens
6SL3210-5BB18-0UV0 SINAMICS V20, 1AC230V 1HP, UNFILTERED Siemens
6SL3210-5BB21-1AV0 SINAMICS V20, 1AC230V 1,1KW FILTER A Siemens
6SL3210-5BB21-1UV0 SINAMICS V20, 1AC230V 1.1KW UNFILTERED Siemens
6SL3210-5BB21-5AV0 SINAMICS V20, 1AC230V 1,5KW FILTER A Siemens
6SL3210-5BB21-5UV0 SINAMICS V20, 1AC230V 1.5KW UNFILTERED Siemens
6SL3210-5BB22-2AV0 SINAMICS V20, 1AC230V 2,2KW FILTER A Siemens
6SL3210-5BB22-2UV0 SINAMICS V20, 1AC230V 2.2KW UNFILTERED Siemens
6SL3210-5BB23-0AV0 SINAMICS V20, 1AC230V 3,0KW FILTER A Siemens
6SL3210-5BB23-0UV0 SINAMICS V20, 1AC230V 3.0KW UNFILTERED Siemens
6SL3210-5BE13-7CV0 SINAMICS V20, 3AC400V 0.37KW FILTER C3 Siemens
6SL3210-5BE13-7UV0 SINAMICS V20, 3AC400V 0.37KW UNFILTERED Siemens
6SL3210-5BE15-5CV0 SINAMICS V20, 3AC400V 0.55KW FILTER C3 Siemens
6SL3210-5BE15-5UV0 SINAMICS V20, 3AC400V 0.55KW UNFILTERED Siemens
6SL3210-5BE17-5CV0 SINAMICS V20, 3AC400V 0.75KW FILTER C3 Siemens
6SL3210-5BE17-5UV0 SINAMICS V20, 3AC400V 0.75KW UNFILTERED Siemens
6SL3210-5BE21-1CV0 SINAMICS V20, 3AC400V 1.1KW FILTER C3 Siemens
6SL3210-5BE21-1UV0 SINAMICS V20, 3AC400V 1.1KW UNFILTERED Siemens
6SL3210-5BE21-5CV0 SINAMICS V20, 3AC400V 1.5KW FILTER C3 Siemens
6SL3210-5BE21-5UV0 SINAMICS V20, 3AC400V 1.5KW UNFILTERED Siemens
6SL3210-5BE22-2CV0 SINAMICS V20, 3AC400V 2,2KW FILTER C3 Siemens
6SL3210-5BE22-2UV0 SINAMICS V20, 3AC400V 2.2KW UNFILTERED Siemens
6SL3210-5BE23-0CV0 SINAMICS V20, 3AC400V 3.0KW FILTER C3 Siemens
6SL3210-5BE23-0UV0 SINAMICS V20, 3AC400V 3.0KW UNFILTERED Siemens
6SL3210-5BE24-0CV0 SINAMICS V20, 3AC400V 4,0KW FILTER C3 Siemens
6SL3210-5BE24-0UV0 SINAMICS V20, 3AC400V 4.0KW UNFILTERED Siemens
6SL3210-5BE25-5CV0 SINAMICS V20, 3AC400V 5.5KW FILTER C3 Siemens
6SL3210-5BE25-5UV0 SINAMICS V20, 3AC400V 5.5KW UNFILTERED Siemens
6SL3210-5BE27-5CV0 SINAMICS V20, 3AC400V 7,5KW FILTER C3 Siemens
6SL3210-5BE27-5UV0 SINAMICS V20, 3AC400V 7.5KW UNFILTERED Siemens
6SL3210-5BE31-1CV0 SINAMICS V20, 3AC400V 11KW FILTER C3 Siemens
6SL3210-5BE31-1UV0 SINAMICS V20, 3AC400V 11KW UNFILTERED Siemens
6SL3210-5BE31-5CV0 SINAMICS V20, 3AC400V 15KW FILTER C3 Siemens
6SL3210-5BE31-5UV0 SINAMICS V20, 3AC400V 15KW UNFILTERED Siemens
6SL3210-5CB12-0AA0 SINAMICS V80 Siemens
6SL3211--0AB1-5-5UA1 DR AC G110 230V 1PU 0.75HP 3.2A AN NOR Siemens
6SL3211-0AB11-2BA1 SINAMICS Drive Siemens
6SL3211-0AB11-2BB1 SINAMICS Drive Siemens
6SL3211-0AB11-2LA1 G110 CPM110 1AC230 0.12KW UF AIN IP20 Siemens
6SL3211-0AB11-2UA1 SINAMICS Drive Siemens
6SL3211-0AB11-2UB1 SINAMICS Drive Siemens
6SL3211-0AB12-5BA1 SINAMICS Drive Siemens
6SL3211-0AB12-5BB1 SINAMICS Drive Siemens
6SL3211-0AB12-5UA1 SINAMICS Drive Siemens
6SL3211-0AB12-5UB1 SINAMICS Drive Siemens
6SL3211-0AB13-7BA1 SINAMICS Drive Siemens
6SL3211-0AB13-7BB1 SINAMICS Drive Siemens
6SL3211-0AB13-7LA1 G110 CPM110 1AC230 0,37KW UF AIN IP20 Siemens
6SL3211-0AB13-7UA1 SINAMICS Drive Siemens
6SL3211-0AB13-7UB1 SINAMICS Drive Siemens
6SL3211-0AB15-5BA0 G110- CPM110 G110- CPM110 AC Drive Siemens
6SL3211-0AB15-5BA1 SINAMICS Drive Siemens
6SL3211-0AB15-5BB1 SINAMICS Drive Siemens
6SL3211-0AB15-5UA1 SINAMICS Drive Siemens
6SL3211-0AB15-5UB1 SINAMICS Drive Siemens
6SL3211-0AB17-5BA1 SINAMICS Drive Siemens
6SL3211-0AB17-5BB1 SINAMICS Drive Siemens
6SL3211-0AB17-5UA1 SINAMICS Drive Siemens
6SL3211-0AB17-5UB1 SINAMICS Drive Siemens
6SL3211-0AB21-1AA1 SINAMICS Drive Siemens
6SL3211-0AB21-1AB1 SINAMICS Drive Siemens
6SL3211-0AB21-1UA1 SINAMICS Drive Siemens
6SL3211-0AB21-1UB1 SINAMICS Drive Siemens
6SL3211-0AB21-5AA1 SINAMICS Drive Siemens
6SL3211-0AB21-5AB1 SINAMICS Drive Siemens
6SL3211-0AB21-5UA1 SINAMICS Drive Siemens
6SL3211-0AB21-5UB1 SINAMICS Drive Siemens
6SL3211-0AB22-2AA1 SINAMICS Drive Siemens
