Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Panasonic MGM-32262S
²úÆ·Ãû³Æ£º Panasonic MGM-32262S
ÐÍ ºÅ£º Panasonic MGM-32262S
Panasonic MGM-32262S,Panasonic MGM-32262S
²îѹ±äËÍÆ÷´«µÝµÄÄ£ÄâÐźţ¬Ò²ÓɶàÖÖµçÆøÐźÅ0~10mv¡¢0~10mA¡¢0~20mAµÈÊä³ö£¬·¢Õ¹µ½²ÉÓùú¼Êͳһ±ê×¼4~20mAÐźţ¬»ò´øHARAЭÒéÊä³ö£¬½øÈëÊý×Öʽºó£¬ÓжàÖÖ×ÜÏßЭÒé¹²´æµÄÏÖÏó£¬ÔÚÖÚ¶àµÄÏÖ³¡×ÜÏßЭÒéÖУ¬ÓÉÕã½­ÖпØÁìÏÎÖÆ¶¨µÄEPAЭÒéÒÑÄÉÈë¹ú¼Ê±ê×¼£¬ÕýÔÚÍÆ¹ãÓ¦Óã¬Îª¹úÈËÓ®µÃ»°ÓïȨ£¬ÕâÊÇÒ»¸öÁ¼ºÃµÄ¿ª¶Ë£¬Ä¿Ç°ÕýÔÚ»ý¼«ÍƹãÓ¦ÓÃÖУ¬²îѹ±äËÍÆ÷µÄ¼ì²âÐźŴ«ÊäµÄÑݱäÈçͼ7Ëùʾ¡£Á÷³Ì¹¤Òµ¿ØÖƲÙ×÷µÄÑݱäÈËÀàÔÚͬ×ÔÈ»½øÐг¤ÆÚµÄ¼è¿à¶·ÕùÖУ¬»ýÀÛÁ˷ḻµÄ¾­Ñé½Ìѵ£¬ÓÐÁË·ÉÔ¾µÄ·¢Õ¹¡£ÔÚÊÖ¹¤×÷·»Ê±´ú£¬ÈËÀàÓÃÊÖ¹¤²Ù×÷·½·¨ÖÆÔì»úÆ÷£¬ºóÀ´½øÈëÒÔ½ðÊô£¨Ö÷ÒªÊÇÌú£©Îª²ÄÁÏ¡¢ÓûúÆ÷½øÐÐÉú²ú¼Ó¹¤µÄ»úе»¯Ê±´ú£¬Õâ¾ÍÊǵÚÒ»´Î¼¼Êõ¸ïÃü¡£ËæºóÊǵڶþ´Î¼¼Êõ¸ïÃüµÄµçÆøÊ±´úºÍµÚÈý´Î¼¼Êõ¸ïÃüµÄµç×Óʱ´ú£¬ÏÖÔÚÓÖÔÚÔÍÄðеļ¼Êõ¸ïÃü£¬ÓÃÒ»ÖÖʱ÷ÖµÄ˵·¨¾ÍÊÇÐÅϢʱ´ú£¬»ò֪ʶ¾­¼ÃÉç»áµÈµÈ¡£×Û¹ÛÕâÈý´Î¼¼Êõ¸ïÃü£¬²»ÄÑ·¢ÏÖ£¬ÓÉÓÚ¹¤ÒÕÁ÷³ÌµÄ¸Ä½øºÍÉú²ú¹æÄ£µÄÀ©´ó£¬ÒÇÆ÷ÒDZíÓë×Ô¶¯»¯¼¼ÊõµÄ·¢Õ¹¶ÔÁ÷³Ì¹¤ÒµµÄ²Ù×÷ÑݱäÆðמö¶¨ÐÔ×÷Óá£Ò»µ©Á˽âÕâÖÖ×ÜÌåµÄÀúÊ·±³¾°£¬¾ÍÄÜÀí½â£¬ÔÚÐÂÖйú³ÉÁ¢60ÄêÀ´Á÷³Ì¹¤Òµ¿ØÖƲÙ×÷·½Ê½µÄÑݱä¹ì¼£ÖУ¬ÒÇÆ÷ÒDZíÓë×Ô¶¯»¯¼¼ÊõµÄ·¢Õ¹Í¬ÑùÆðµ½²»¿ÉÌæ´úµÄ×÷Óá£60ÄêÀ´¿ØÖƲÙ×÷·½Ê½µÄÑݱäÈçͼ8Ëùʾ¡£6SL3420-2TE13-0AA0        SINAMICS Drive    Siemens
6SL3420-2TE13-0AA1        MOMO.COMP.400V2X3A 6SL3420-2TE13-0AA1SIN    Siemens
6SL3420-2TE15-0AA0        SINAMICS Drive    Siemens
6SL3420-2TE15-0AA1        MOMO.COMP.400V2X5A 6SL3420-2TE15-0AA1SIN    Siemens
6SL3430-6TE21-6AA0        SINAMICS Drive    Siemens
6SL3430-6TE21-6AA1        SINAMICS S120,SMART LINE,3AC,480V,60Hz    Siemens
6SL3462-1CC00-0AA0        SINAMICS Drive    Siemens
6SL3462-8SC00-0AA0        SINAMICS Drive    Siemens
6SL3501-0BE08-6AA0        Braking Resistor    Siemens
6SL3501-0BE12-1AA0        Braking Resistor    Siemens
6SL3501-0BE14-1AA0        Braking Resistor    Siemens
6SL3511-0PE17-5AM0        SINAMICS G110D,PM250D,FSA,500V,FLT,0.75K    Siemens
6SL3511-0PE21-5AM0        SINAMICS G110D,PM250D,FSA,400V,FLT,1.5KW    Siemens
6SL3511-0PE24-0AM0        SINAMICS G110D,500V,4.0KW,3AC,500V,FSB    Siemens
6SL3511-0PE27-5AM0        SINAMICS G110D,PM250D,FSA,400V,FLT,7.5KW    Siemens
6SL3511-1PE17-5AM0        G110D AC Drive    Siemens
6SL3511-1PE21-5AM0        SINAMICS G110D-IP65-FSA-A-ASI-REP 1,5KW    Siemens
6SL3511-1PE23-0AM0        SINAMICS G110D-IP65-FSA-A-ASI-REP 3,0KW    Siemens
6SL3511-1PE24-0AM0        SINAMICS G110D-IP65-FSB-A-ASI-REP 4,0KW    Siemens
6SL3511-1PE25-5AM0        SINAMICS G110D-IP65-FSC-A-ASI-REP 5,0KW    Siemens
6SL3511-1PE27-5AM0        SINAMICS G110D-IP65-FSC-A-ASI-REP 7,5KW    Siemens
6SL3525-0PE17-5AA1        SINAMICS PM250D_FSA_400V_ 0.75 KW    Siemens
6SL3525-0PE21-5AA1        SINAMICS PM250D_FSA_400V_ 1.5 KW    Siemens
6SL3525-0PE23-0AA0    PM250D    PM250D Power Module    Siemens
6SL3525-0PE23-0AA1        SINAMICS PM250D_FSB_400V_3 KW    Siemens
6SL3525-0PE24-0AA0    PM250D    PM250D Power Module    Siemens
6SL3525-0PE24-0AA1        SINAMICS PM250D_FSC_400V_4 KW    Siemens
6SL3525-0PE25-5AA1        SINAMICS PM250D_FSC_400V_5.5 KW    Siemens
6SL3525-0PE27-5AA1        SINAMICS PM250D_FSC_400V_7.5 KW    Siemens
6SL3532-6DF71-0RA1        S120M AH 36, 1,0NM, FITTED KEY, IP54    Siemens
6SL3532-6DF71-0RG1        S120M AH 36, 1,00NM, PLAIN SHAFT, IP54,    Siemens
6SL3544-0FB20-1FA0        SINAMICS G120D CONTROL UNIT CU240D-2 PN    Siemens
6SL3544-0FB20-1PA0        SINAMICS CU240D 6 DI/1 F-DI, 2 DO    Siemens
6SL3544-0FB21-1FA0        SINAMICS CU240D 6 DI/3 F-DI, 2 DO    Siemens
6SL3544-0FB21-1FB0        SINAMICS CU240D 6 DI/3 F-DI, 2 DO    Siemens
6SL3544-0FB21-1PA0        SINAMICS CU240D 6 DI/3 F-DI, 2 DO    Siemens
6SL3546-0FB21-1FA0        SINAMICS CU250-2 6 DI/3 F-DI, 2 DO    Siemens
6SL3546-0FB21-1FB0        SINAMICS CU250-2 6 DI/3 F-DI, 2 DO    Siemens
6SL3546-0FB21-1PA0        SINAMICS CU250-2 6 DI/3 F-DI, 2 DO    Siemens
6SL3555-0AA00-6AB0        S120M DRIVE CLIQ EXTENSION    Siemens
6SL3555-0PA00-2AA0        SINAMICS Drive    Siemens
6SL3555-0PL00-2AA0        Local/Remote Switch    Siemens
6SL3555-0PM00-0AA0        Card Reader    Siemens
6SL3555-2BC10-0AA0        S120M ADAPTER MODULE 600 (AM600)    Siemens
6SL3563-4RA00-0GA0        Connector Kit    Siemens
6SL3563-4UA00-0GA0        Connector Kit    Siemens
6SL3760-0BG00-0AA0        FUSE SMALL 142.6185 10A 58V    Siemens
A5E00292714        MicromasterStarter6SL3072-0AA00-0AG0(Z5)    Siemens
A5E32293720        CompactFlash 6SL3054-0EG01-1BA0-Z Z=F04    Siemens
A6X30023548        SINAMICS COMPACT FLASH CARD + OPT    Siemens
A6X30024993        SINAMICS COMPACTFLASH 6SL3054-0CF01-1AA0    Siemens
A6X30026037        CIRCUIT BOARD,PRECHARGE,18P RECTIFIER    Siemens
A6X30028507        SINAMICS COMPACT FLASHCARD PERF EXT 1    Siemens
A6X30028508        SINAMICS COMPACT FLASHCARD PERF EXT 1    Siemens
A6X30044851        SINAMICS S120 COMPACT FC,V2.06,WOP,F03    Siemens
A6X30045514        SINAMICS MMC WITH V4.1,SAFETY LIC    Siemens
A6X30047492        SINAMICS S120 COMPACTFLASH CARD,V2.6,F03    Siemens
A6X30047602        SINAMICS S120 COMPACT FC,V2.06,WOP,F01    Siemens
A6X30047603        SINAMICS S120 COMPACT FC,V2.06,WOP,F04    Siemens
A6X30047604        SINAMICS S120 COMPACT FC,V2.06,WOP,F02    Siemens
A6X30047821        SINAMICS S120 COMPACTFLASH CARD,V2.6,F02    Siemens
A6X30049621        SINAMICS S120 COMPACTFLASH CARD,V2.6,F01    Siemens
A6X30052307        MULTIMEDIACARD EMPTY, 64MF, F01 OPT    Siemens
A6X30054569        SINAMICS G130, 250HP W150 - Kit    Siemens
A6X30054570        SINAMICS G130, 300HP W150 - Kit    Siemens
A6X30056868        SINAMICS G150 CONV,3AC,480V,132KW + OPTS    Siemens
A6X30059805        COMPACT FC,SINAM S120,W/O LIC V4.03+OPTS    Siemens
A6X30059887        SINAMICS S120 COMPACTFLSH CARD,V4.03 F01    Siemens
A6X30059961        COMPACT FC,SINAMICS S120 ,W LIC. V4.3+OP    Siemens
A6X30061213        COMPACT FC,SINAMIC S120,WOLIC V4.03SP+OP    Siemens
A6X30061533        COMPACT FC,SINAMICS S120,W LIC,V4.3 SP2    Siemens
A6X30064069        COMPACT FC,SINAMICS S120,LIC,V4.03 F04    Siemens
A6X30064404        COMPACT FC,SINAMICS S120 ,LIC,V4.03 F03    Siemens
A6X30066226        COMPACT FC,SINAMICS S120 +OPTS    Siemens
A6X30067087        COMPACT FC,SINAMIC S120,W/ LIC.V4.04,F05    Siemens
A6X30067164        COMPACT FC,SINAMICS S120 +OPTS    Siemens
A6X30067209        MODULE,MULTIMEDIA CARD,64MB,W/CERT OF LI    Siemens
A6X30067660        COMPACT FC,SINAMICS S120,W LIC,V4.3 SP2    Siemens
A6X30068766        COMPACT FC,SINAMIC S120,W/ LIC.V4.04,F04    Siemens
A6X30068767        COMPACT FC,SINAMIC S120,W/ LIC.V4.04,F01    Siemens
A6X30070987        COMPACT FC,SINAMIC S120,W/ LIC.V4.04,F02    Siemens
A6X30072429        COMPACT FC,SINAMICS S120,W/O,LIC V4.03 +    Siemens
A6X30072430        ALM GCT,132kW,CF Card,KIT    Siemens
A6X30072730        SINAMICS COMPACT FLASH CARD + OPT    Siemens
A6X30073114        SINAMICS G150,3AC,300HP,370A+OPTS    Siemens
A6X30074726        COMPACT FC,SINAMIC S120,W/ LIC.V4.04,F01    Siemens
A6X30074857        COMPACT FC,SINAMICS S120,W/LIC V4.05+F02    Siemens
A6X30074858        COMPACT FC,SINAMICS S120,W/LIC V4.05+F03    Siemens
A6X30074859        COMPACT FC,SINAMICS S120,W/LIC V4.05+F04    Siemens
A6X30077194        COMPACT FC,SINAMICS S120, W/ LIC. V4.05    Siemens
A6X30079979        COMPACT FC,SINAMICS S120, W/ LIC. V4.05    Siemens
A6X30083804        COMPACT FC,SINAMICS S120 ,LIC,V4.03 F02    Siemens
A6X30084372        COMPACT FC,SINAMICS S120, W/ LIC. V4.05    Siemens
A6X30087287        SD-CARD EMPTY, 512 MB, 1SL    Siemens
A6X30087963        MEM,COMPACT FC,SINAMICS S120,W/LIC,V4.05    Siemens
A6X30089030        COMPACT FC,SINAMICS S120,W/ 5 LIC. V4.06    Siemens
6EP8090-0AA00        SINAUT RTU Power Supply    Siemens
6NG4207-8PS02        Siemens Module    Siemens
6NG4241-8PS    VES    VES Module    Siemens
6NG4245-8PS01    8-FW TIM    Transmission Processor Module    Siemens
6NG4251-8PS07    AER    AER Module    Siemens
6NG4253-8PS01    BAM    BAM Module    Siemens
6NH1800-8AA        SINAUT Communication Module    Siemens
6NH1801-0B        Memory Module    Siemens
6NH1801-0E        ST 1 TIM    Siemens
6NH1801-8CC        TIM 11    Siemens
6NH1802-0BA        SINAUT ST1 TIM Module    Siemens
6NH1802-0BC        Sinaut Module ST1 TIM    Siemens
6NH1802-0EA        SINAUT TIM 11 Module    Siemens
6NH1802-5BA        TIM11 Module    Siemens
6NH1804-0AA01-2BB2        Memory Module    Siemens
6NH1804-0AA01-3BB2    TIM011B    Memory Module ST1 TIM    Siemens
6NH1804-0AA01-3CB2    TIM011B    Memory Module ST1 TIM    Siemens
6NH1804-2BB01-3BB2    TIM011BSL    SINAUT Transmission Module    Siemens
6NH7701-0AR        SINAUT ST7, CC 701-0A,TEST CABLE 6M    Siemens
6NH7701-4AL        CABLE CC701-4A TIM 3V SINAUT ST7 (1.5M)    Siemens
6NH7701-4BN        CABLE TIM3/4 RADIO MD SINAUT ST7 (2.5M)    Siemens
6NH7701-4DL        CABLE CC 701-4D TIM 3V SINAUT ST7 (1.5M)    Siemens
6NH7701-5AN        CABLE CC701-5A TIM 3V SINAUT ST7 (2.5M)    Siemens
6NH7760-0AA        +-NAUT ST7, R-ADAPT    Siemens
6NH7800-3AA40        SINAUT ST7    Siemens
6NH7800-3BA00        SINAUT ST7, TIM 3V-IE    Siemens
6NH7800-3CA00        SINAUT ST7, TIM 3V-IE ADVANCED    Siemens
6NH7800-4AA20    TIM 42    Sinuat ST7 TIM 42 Communications Processor    Siemens
6NH7800-4AA50        MODULE TIM4R MPI EXT MOD/RAD SINAUT ST7    Siemens
6NH7800-4AD50        SINAUT ST7, TIM 4R D    Siemens
6NH7800-4AD90        MODULE TIM4RD MPI EX MOD/RA SINAUT ST7    Siemens
6NH7800-4BA00        SINAUT ST7, TIM 4R-IE COMM PROCESSOR    Siemens
6NH7803-3BA00-0AA0        MODULE TIM 3V-IE DNP3,S7-300,RJ45    Siemens
6NH7803-4BA00-0AA0        MODULE TIM 4R-IE DNP3,S7-300&400,RS485    Siemens
6NH7810-0AA20        Sinuat ST7 MD2 Modem    Siemens
6NH7810-0AA30        MODEM MD3 DIALING ALG TELNET SINAUT ST7    Siemens
6NH7997-0CA50-0GA0        SOFTWARE,SINAUT ST7 V5.0 UPGRADE 09/2009    Siemens
6NH7997-0CA53-0AA0        SOFTWARE, SINAUT ES V5.3    Siemens
6NH7997-0CA53-0GA0        SOFTWARE,SINAUT ES V5.3 UPGRADE    Siemens
6NH7997-7CA31-0AA1        SOFTWARE, SINAUT SW ST7CC V3.1 S    Siemens
6NH7997-7CA31-0AA2        SOFTWARE, SINAUT SW ST7CC V3.1 M    Siemens
6NH7997-7CA31-0AA3        SOFTWARE, SINAUT SW ST7CC V3.1 L    Siemens
6NH7997-7CA31-2GA1        SINAUT SW ST7CC V3.1 S UPGR V2.4...V2.7    Siemens
6NH7997-7CA31-2GA2        SINAUT SW ST7CC V3.1 M UPGR V2.4...V2.7    Siemens
6NH7997-7CA31-2GA3        SINAUT SW ST7CC V3.1 L UPGR V2.4...V2.7    Siemens
6NH7997-8CA31-0AA0        SOFTWARE, SINAUT SW ST7CC V3.1 RED    Siemens
6NH7997-8CA31-2GA0        SINAUT SW ST7CC V3.1 RED UPGR V2.4..V2.7    Siemens
6NH9701-0AD        SINAUT MD720-3 GSM MODEM    Siemens
6NH9720-3AA00        SINAUT MD720-3 GSM/GPRS MODEM    Siemens
6NH9805-1LB    MDB1200-01, 6NH9805-1LB MOA-MP    SINAUT MOA-MP Module    Siemens
6NH9806-1AB        SINAUT Module MOA-F2    Siemens
6NH9807-1FB        SINAUT Interface Module    Siemens
6NH9807-1LB        Sinaut MOA-MDM Modem Adapter    Siemens
6NH9810-2A        SINAUT MODEM MD 100    Siemens
6NH9810-2F    MD124    SINAUT ST1 MD124 Module    Siemens
6NH9810-2T    MD125    SINAUT Modem MD 125    Siemens
6NH9821-0BB00        SINAUT ST1, OPM,4PCS    Siemens
6NH9821-0BC11        HARDWARE LTOP1 WALL BOX SINAUT ST1    Siemens
6NH9821-0BC12        HARDWARE LTOP2 WALL BOX SINAUT ST1    Siemens
6NH9831-2AA        SINAUT ST7, DCF IND-BS    Siemens
6NH9860-1AA00        SINAUT ANT 794-4MR ANTENNA GSM QUADBAND    Siemens
6NH9870-1AA00        ANT 794-3M ANTENNA    Siemens
6NH9910-0AA10-0AA3        SINAUT MICRO SC 8    Siemens
6NH9910-0AA10-0AA6        SINAUT MICRO SC 64    Siemens
6NH9910-0AA10-0AA8        SINAUT MICRO SC 256    Siemens
6NH9910-0AA20-0AA0        TELECONTROL SERVER BASIC 8    Siemens
6NH9910-0AA20-0AB0        TELECONTROL SERVER BASIC 64    Siemens
6NH9910-0AA20-0AC0        TELECONTROL SERVER BASIC 256    Siemens
6NH9910-0AA20-0AD0        TELECONTROL SERVER BASIC 1000    Siemens
6NH9910-0AA20-0AE0        TELECONTROL SERVER BASIC 5000    Siemens
¹«Ë¾Ãû³Æ£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ÏúÊÛ²¿
µç »°£º 0592 5321698 / ÕÅÃÀ·ï
ÊÖ»ú£º 18020776791
µØ Ö·£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ ÏÃÃÅ˼Ã÷Çøºþ±õ¶«Â·ºþ¹â´óÏÃ18Â¥ABµ¥Ôª
ÓÊ ±à£º 361004
Ö÷ Ò³£º http://www.zxdadsqc.com/
  • HP PGM3410R
  • Shimadzu EI-D2003M
  • Panasonic MGM-32262S
  • 653B-8-200J-2
  • SGDM-50ADA
  • 1264C62G19,1264C62G19
  • Reliance O-60053
  • CR115A19
  • Square 9998HG1£¬Square 9998HG1
  • CM902WX
