FP-TB-1
FP-TB-1
¹ØÓÚÂÞ¿ËΤ¶û×Ô¶¯»¯
ÂÞ¿ËΤ¶û×Ô¶¯»¯ÓÐÏÞ¹«Ë¾(NYSE: ROK)ÊÇÈ«Çò×î´óµÄÖÂÁ¦ÓÚ¹¤Òµ×Ô¶¯»¯ÓëÐÅÏ¢»¯µÄ¹«Ë¾¡£ÆäʹÃüÊǰïÖú¿Í»§Ìá¸ßÉú²úÁ¦²¢ÇÒÍÆ¶¯ÊÀ½çµÄ¿É³ÖÐø·¢Õ¹¡£ÂÞ¿ËΤ¶û×Ô¶¯»¯¹«Ë¾ÕûºÏÁ˹¤Òµ×Ô¶¯»¯ÁìÓòµÄÖªÃûÆ·ÅÆ£¬ÆäÖаüÀ¨°¬Â×-²¼ÀµÂÀû£¨Allen-Bradley?£©µÄ¿ØÖƲúÆ·ºÍ¹¤³Ì·þÎñ¼°ÂÞ¿ËΤ¶ûÈí¼þ£¨Rockwell Software?£©¿ª·¢µÄ×Ô¶¯»¯¹ÜÀíÈí¼þ¡£ÂÞ¿ËΤ¶û×Ô¶¯»¯×ܲ¿Î»ÓÚÃÀ¹úÍþ˹¿µÐÇÖÝÃܶûÎÖ»ùÊУ¬ÔÚ80¶à¸ö¹ú¼ÒÉèÓзÖÖ§»ú¹¹£¬ÏÖÓйÍÔ±Ô¼22,000ÈË¡£
´´ÐµĺËÐÄÔÚÓÚÈ˲ŗ—ÕâÒ»¹ÛµãÉîÉîÖ²¸ùÓÚÂÞ¿ËΤ¶û×Ô¶¯»¯µÄÆóÒµ»ùÒò¡£´óÁ¬Èí¼þÑз¢ÖÐÐÄÖаٷÖÖ®ÁùÊ®µÄÔ±¹¤ÓµÓÐ˶ʿ¼°ÒÔÉÏѧλ¡£Í¨¹ýÂÞ¿ËΤ¶û×Ô¶¯»¯´óѧºÏ×÷ÏîÄ¿£¬´óÁ¬Èí¼þÑз¢ÖÐÐÄÓëµ±µØ¶àËù´óѧºÏ×÷ÅàÑø¾«Ó¢È˲š£ÂÞ¿ËΤ¶û×Ô¶¯»¯ÒÑͶ×Ê9°ÙÍòÈËÃñ±Ò£¬ÓëλÓÚÖйú¶«±±µÄ´óÁ¬Àí¹¤´óѧ¡¢´óÁ¬º£Ê´óѧ¼°´óÁ¬Ãñ×åѧԺ´´½¨ÁËÈýËùÁªºÏʵÑéÊÒ¡£
×¢ÊÍ£º
1 ÐÅÏ¢Ô´×Ôǰհ²úÒµÑо¿Ôº (Forward Industry Research Institute) µÄ±¨¸æ“2014-2018 ÄêÖйúÐÂÐͳÇÕò»¯½¨Éè·¾¶ÓëͶ×ÊÕ½ÂԹ滮·ÖÎö±¨¸æ”¡£
2 ÐÅÏ¢ÒÀ¾ÝÖлªÈËÃñ¹²ºÍ¹úǰ¹¤ÒµºÍÐÅÏ¢»¯²¿²¿³¤ÀîÒãÖÐÔÚ“¹Ø×¢ÆøºòÖйú·å»á”Éϵķ¢ÑÔ¡£
GE Fanuc Card IC600YB800B #7802
Star Robot Controller Power Supply ?? #8879
Toshiba Power Block 160L2C43A #37251
New Simpson Current Meter 1357, 0-50 Amperes #40866
Fuji Electric Power Transistor A50L-2001-0232 #26547
New IFM Photoelectric Diffuse Reflection 0F5027, 0FB-FP
Allen Bradley Operating Head for Limit Switch Z-16065 #
NEW Allen Bradley Operating Head for Limit Switch Z-160
Allen Bradley Safety Relay GuardMaster MSR138DP, 440R-M
Cincinnati Milacron Timer Board 3-531-3280A, 35313280A
Schleicher Relay Switch SNT 4053 K #48776
Nemic Lambda Power Supply PS-11-24 #48755
Siemens Input Module 6ES5 430-4UA13 #49887
Circuit Board 9732-PR10A #10064
Allen Bradley Push Button 800MB-X016 #25824
Hydro Norma Hydraulic Valve #12373
Bosch Hydraulic Valve 0 810 001 540, #12375
Bosch Hydraulic Limit Switch 0 810 090 109 #12379
SCI Scanalyzer Module 21984 #32982
Mould-Tek Additive Feed Control AF-II-1" #18295
Numatic Limit Switch 1337 NA7, #19142
Numatic Limit Switch CW 1337 MAT, #19209
Westinghouse Circuit Breaker HFB3020, #12206
Fanuc Output Module A03B-0807-C159, A0A12F #43547
Phoenix Contact 9091158F PC Board #12311
General Electric 185119EMZZ8 Meter #27646
MDI Mercury Contactor 435NO-120A-18 #11808
Heli Coil Plug Tap 2"-12-N G-H6 HS #47443
Allen Bradley Push Button 800MB-X016 #38201
Heli Coil Plug Tap 1 3/4"-6 HS GH4 #47444
Atlas Copco Pneumatic Screwdriver LUM 21 SR10-U #42543
New Manifold PS011-3/8, 1088901 #21814
The Ultimate in Controls (TUC) Keypad # 21892
Lapp-Textima AG Transformer AN 130542 #19174
Circuit Board H1F3F-20PA #5679
Bosch Directional Valve 0 810 090 119 #12439
NEW Flow Control Valve DRV-20 #19168
Bosch Directional Valve 0 810 001 244, #12458
Bosch Directional Valve 0 810 001 520 #12459
Bosch Directional Valve 0 810 001 060, #12464
NEW Swagelok SS-12-RB-6 Stainless Fitting 3/4" Box of 5
GM PC Board GM3021A, #12385
Allen Bradley Circuit Board 960069 #37491
Dell Marking Systems Numatic Control Board #21229
Square D Limit Switch 9007-C54B #33196
Festo Circuit Board L-350740 #12073
Barber Colman Backplane Maco 8000 #30827
New Boy Machines Seal 7561024 #19894
New Lithonia Lighting Luminaire Fitting 107YLA #30878
Bosch Code Reader 8981004750, #7780
NEW Siemens Controller Contactor 42CF15AF #18341
Yuken Throttle & Check Module TC2G-01-4012 #38440
Herfurth Capacity Overload K516A 33-698A #14622
Toko A291F170S1-B1 Display Readout #20698
Towler Power Pack / Supply 110-380 Volt #26046
Towler Power Pack / Supply EX00-101A #26056
IDC Corporation Power Supply Board SH21-PS #43152
AEC Teach Pendant Touch Pad Case Only 1030776 #26760
Ambac Filter MS50-F3-CB2-M #13521
Omron 3G2A3-ID411 I/O Module #26766
Toyozumi Dengen Kiki Transformer TNK-2003A #38335
Ford Motorcraft Lectron E9DF-18C531-AA #30310
Cylinder Division Cylinder CYL-UDC-TW15B #37515
Siemens Display Controller 9BA2302 #7490
P.E.T.S, Pets 851-4 Hot Runner Control Card Ref #8421
Bosch Ignition Coil 0221 604 104 #10785
Harmo Robot Receiver Plug 1022801 #24596
MSC Circuit Board 10224-0001-F, MR-50 #43760
Newbury 1K2-0000-R Control Board #12986
I-T-E Circuit Breaker Q330, 30 Amp #18842
Siemens SITOP Power Supply 6EP1 332-2BA00 #24386
Excelon L73M-3AP-EDN Lubricator #24478
Harmo Robot Receiver Plug 1022589 #23386
Harmo Robot Receiver Plug 1022589 #23385
Harmo Robot Receiver Plug 1022590 #23387
Harmo Robot Receiver Plug 1022590 #23390
Harmo Robot Receiver Plug 1022591 #23388
Harmo Robot Receiver Plug 1022801 #23389
Harmo PC Board 1022588 #23381
NEW Servtek Ring Rider 50358661, 55161378 #33413
New Boy Machines Heater Band 1549313, 460 Volt #20146
New Dadco Pressure Monitor DPM-2 #30910
Intel Pentium MMX Mother Board CPU, #16321
Allen Bradley 700-N9 Relay 150 Volt #20759
Circuit Board 17-1145011 9026 #24045
Circuit Board 17-1145081 #24041
Power Control Board 102-VGA-5-126-0?2 #24014
Allen Bradley Output Module 1771-OX #34176
SOLA Power Supply SLS-15-045 #13048
New General Electric Control Switch 374 78699 #41377
Miller Air Cyliner IPA-61B4N-0050-?25.000 #29360
Cito Products Oil Temperature Alarm OT-1202 #37080
Oiles OA301151 Die Component #13757
Eurogi Terminal Board Circuit Board CEI 2138 #19188
DVT Smart Image Sensor Specialists Series 800 #21306
RJG Tech. T-IMP-2 Transformer/Vol?tage Reduction #24856
RJG Tech. T-IMP-2 Transformer/Vol?tage Reduction #24857
Hokuyo Automatic PR-YGAL2 Reciever #26296
Hokuyo Automatic PR-YGP2 Projector #26297
Rayco Fixture 25-631970-71-D2?-D28 #32489
Allen Bradley Starter 505-AOD #38487
Parker Cylinder 02.00 CJ2HTS19AC #32326
Toshiba Injectvisor Guage 7W20R2-3 #6730
Ex-Cello 89905, 26-1-109 Motor #2249
Festo Pneumatic Valve VL-5/3E-D-1 C #16810
New Allen Bradley 1771-IB Input Module #28937
Martin Flex Coupling F7SH #15548
Boy Machines Seal 7511004 #19901
Graco Sprayer 210744 A5C #38087
New Skinner Solenoid Valve Q53LB2050 #37923
NIB Dayton 4WT46 AC Axial Fan 115CFM #11994
Mean Well Power Supply D-30BC, 0.8 Amp, 115 V #21358
Bosch B 830 304 130 Cylinder, 0-180 Bar Pressure #19144
Toshiba PC Board 22-242, #12307
New Swagelok Tube Fitting SS-Q38-B-810 #40611
New Box of 8 Gleason Finishing Cutters FSP-224 #45293
New Jensen Ball Valve 1/2" CF8M 1000 WOG #39239
Texas Instruments I/O Mounting Base 6MT50-2, #15285
Durakool Mercury Relay BF3-7024, 30 Amp, #19017
Endine OEM Shock Absorber .5MB #40808
