R880-03F
R880-03F
ÂÞ¿ËΤ¶û×Ô¶¯»¯ÔÚÖйú
ÔÚÖйú£¬ÂÞ¿ËΤ¶û×Ô¶¯»¯ÓµÓг¬¹ý2,200Ãû¹ÍÔ±£¬²¢ÉèÓÐ37¸öÏúÊÛ»ú¹¹£¨°üÀ¨Ïã¸ÛºĮ́ÍåµØÇø£©¡£Ä¿Ç°ÒѳÉÁ¢5¸öÅàѵÖÐÐÄ£¬1¸öÑз¢ÖÐÐÄ£¬´óÁ¬Èí¼þ¿ª·¢ÖÐÐÄ£¬ÉîÛÚ¡¢ÉϺ£ºÍ±±¾©OEMÓ¦Óÿª·¢ÖÐÐÄ£¬Èý¸öÉú²ú»ùµØ¡£¹«Ë¾Óë´óÖлªÇø12 ¼ÒÊÚȨÇþµÀ»ï°é¼°59ËùÖØµã´óѧ¿ªÕ¹ÁË»ý¼«µÄºÏ×÷£¬¹²Í¬ÎªÖÆÔìÒµÌṩ¹ã·ºµÄÊÀ½çÒ»Á÷µÄ²úÆ·Óë½â¾ö·½°¸¡¢·þÎñÖ§³Ö¼°¼¼ÊõÅàѵ¡£
“Listen Think Solve”£¨ÇãÌý¡¢ÇãÐÄ¡¢ÇãÁ¦£©
“Listen Think Solve”£¨ÇãÌý¡¢ÇãÐÄ¡¢ÇãÁ¦£©£¬Ö¼ÔÚ¸üºÃµØ±íÃ÷ÂÞ¿ËΤ¶û×Ô¶¯»¯ÖÂÁ¦ÓÚÇãÌý¿Í»§ËùÐ裬ÒÔ×îºÃµÄ×Ô¶¯»¯¼¼Êõ¾Ñ飬¹¤Òµ¿ØÖÆÓëÐÅÏ¢½â¾ö·½°¸È«Á¦½â¾ö¿Í»§µÄÎÊÌ⣬Ϊ¿Í»§³É¹¦ºÍÔö³¤Ìṩ°ïÖú¡£
NEW Parametrics Driver Board 600215, 600215L #3084
Red Lion Controls Speed Reader DT3A400 #31431
Hoffman Elbow Enclosure C-CS2EHDLG #42108
Square D Transformer T100D2 KVA .100, #12791
Allen Bradley Stack Light 855T-G24TL #38787
SCI Control Board 180-2382 Circuit Card #14894
New MIller Field WCR Kit 136583 #30834
New Miller Electric Field WCR Kit 59145-506 #30835
PLC Direct Input Module D3-16NE3 #31578
Pepperl & Fuchs Proximity Switch NBN40-L2-E2-V1 #2330
Keyence Photoelectric Amplifier FS2-62, #21314
Conery Pump Float 2900-B1S4P1C1-1?5 #44712
AEG Contactor E-NR910-302-719?-00 #35258
NEW MB Manufacturing Pillow Block Bearing TBC 25 #33840
New Allen Bradley Pilot Light Push Button 800MR-PT16 #3
Turck Sensor 46033 #21619
NEW Balluff Proximity Sensor BES-M12EG-PSC80?F-S04G #201
NEW Colonial Full Block Ball Valve V07101N #22131
Numatics Universal Cylinder UTND-040-040-T1 #13886
Rexroth Valve 2518-1-9110-1 24 VDC #40859
Siemens Digital Output Module 6ES5-451-8MA11 #17038
Allen Bradley Input Module 1762-IA8, Series A #47704
Allen Bradley Circuit Board A77153-212-5 #51096
Westinghouse 40 Amp Circuit Breaker FDB3040L #46693
Square D Starter 8536-SCO-3S #44284
Siemens Diagnostic Repeater 6ES7 972-0AB01-0XA0 #47481
Westinghouse 100 Amp Circuit Breaker HFD3100L #46729
Siemens Input Module 6ES7321-1BL00-0?AA0 #40790
National Controls Timer Delay K1K-10-661 #46380
Fanuc Circuit Board A20B-1007-0890/?03A #48367
New Banner Photoelectric Sensor SM2A31RQD #34438
Federal Signal Rotating Safety Light Red *NEW* Series A
Joslyn Clark Contactor 7000-7140-11 #34663
Electromatic Relay RA4890-D12, 20 Amp #47806
Siemens Profisafe Module 6ES7 138-4FA03-0AB0, Simatic S
PPE Heater Band M-5802-9, 425 Watt, 240 volt #33591
PPE Heater Band M-1337-8, 800 Watt, 240 Volt #33592
IMS Heater Band HBP12500, 350 Watt, 240 Volt #33593
PPE Heater Band 40978B, 625 Watt, 240 Volt #33594
New Compact Cylinder SHH118X1 #44049
Allen Bradley Pushbutton 800MR-QBL24S Green #30423
New Miller Fuse 143359 #30312
New E&E EE Self Aligning Coupler EAC-750-F #29364
Lot of 8 Omron Relay Socket 2350K #15162
New In Box Quality Filter QH9600A03B08 #29266
NEW Banner Engineering Fiber Cable BTA23S #43619
ITE Siemens BQ3B100 Circuit Breaker #12255
Ford Rotunda Coil Sensor Tester 007-00072 #30314
New A & N Corporation Hybrid Adapter QF50X50VCR #41612
General Electric Safety Switch TH3361 #41596
Siemens Motor Starter 3RV1021-0FA10 #45558
Continental Industries Relay RSAA-660-30-3DO #30094
New Sola Electric Power Supply 83-12-218-2 #30276
Allen Bradley Switch Selector 800MR-16HX2BS #18451
Allen Bradley Switch Selector 800MR-16HX2BS #18449
Allen Bradley Switch Selector 800MR-16HX2BS #18454
NEW Siemens Optical Sensor & Display 3RG7300-1PH00 #261
New Parker Fluid Connector 1J743-20-20 #29710
Watlow Controls Temperatule Controller 965A-3DA0-0000,
Power One F24-12-A Power Supply 24 Vdc #25985
EMI Nozzle Tip 39441, 8 2" Thread, 5 3/8" #26822
Hewlett Packard Ethernet Adapter Card J2573-80001 #4347
Yaskawa AC Magnetic Contactor HP-20GF1T/10 #36774
SCI Circuit Board 080-2441 180-2441 Rev C / B #25089
New Parker Flow Meter HFR902W3PVXFS8F?IFK #41386
Allen Bradley Programming Terminal 1201-HA1 #34571
Allen Bradley Oiltight Limit Switch 802T-A #37294
New Stainless Steel Flange 25MW1-400-006 #40065
Allen Bradley Memory Module 1764-MM1 #41945
New Eaton Vickers Filter V0211B1R03 #32301
Powertran Transformer A080T500 #34994
New Turck Elecktonik Proximity Switch BI2-G12-RZ33X #34
New in Box Clarostat Wirewound Resistor 62JA-IK #26228
New Swagelok Coupling Welded VCR Fitting SS-4-WVCR-6-DM.?..
New Red Lion Controls Miniture Counter Cub20000 #43253
Allen Bradley Limit Switch 802T-APU #43336
Control King Hot Runner Control Card 2010-15 #18319
Dwyer Photohelic Pressure Gage 3025C #33971
NEW 3/8" Parker Roller Cam Valve CW1337 #3120
Hedland E-Z View Flow Meter H625-010 #39752
Fanuc Input Module IC693MDL645D 16 Point #7091
New Telemecanique Mini Switch MS05S03-00 #43523
Micro Switch Heavy Duty Limit Switch LSV3K #32398
New Balluff Inductive Sensor BES 516-360-G-S4-H #45373
New Thomson Ball Bushing A243848 #29755
Quality Ball Valve 1000 WOG #40559
New Hy-Lok Union Elbow CLA-16-S316 #39238
Milwaukee Cylinder B9145 H71SR 3000 PSI #32692
Siemens Motor Starter 3RV1021-1HA10 #45542
Saftronic Allen Bradley 459221-0071 Circuit Bd #7178
Siemens Motor Starter 3RV1421-1FA10 #45550
Super Clamp C Clamp No. 44-X #37395
New Van Dorn Demag Filter 329432 #32740
New Allen Bradley Programming Terminal 1201-HA2 #28960
New Hoffmane Wire Way Straight Section F-66L12 #30624
Allen Bradley Oiltight Limit Switch 802T-A, Series D #4
Sick Optic Safety Relay UE 43-2MF3D2 #34385
New Allen Bradley Processor Cable 1771-CO #28903
SCI PC Board 080-2441 Solid Controls Inc #14636
Ford Rotunda Customer Flight Recorder 90-93-0001 #30238
Industrial Nozzle Tip EMI 5 1/4 x 1 1/2 #22440
Industrial Nozzle Tip 11.25" long #25008
NEW Industrial Nozzle Tip 2.25" Nozzle Length #26823
Allen Bradley 702-COD3 Starter #12197
New Stainless Steel Flexible Tubing 321-4-X-12-B2 #4122
Allen Bradley Pushbutton 800T-QTH24A Series T #22074
Siemens Starter Motor Protector 3VU1300-1MJ00 #34744
NIB Siemens 3TH8253-0A Contactor #26251
Bender Residual Current Monitor RCM470LY-11 #10907
Sola Regulated Power Supply SLS-15-015 #35766
IFM Photoelectric Sensor OG029 #53319
Siemens Heavy Duty Switch F351 #41593
Siemens Heavy Duty Switch F351 #41594
Siemens ITE Heavy Duty Vacu Break Switch F351 #21056
Lutze Power Supply DRA60-24A #53436
Cognix I/O Module 800-5888-2 #48773
Warner Electric Clutch/Brake Control CBC-801-2 #460
Parker Module VM15-PM #46480
Swagelok Valve 25MW2-555-000 #45417
New Allen Bradley Rechargeable Battery 1775-BH #28953
