PCD6.A400
PCD6.A400
“Ê©Ä͵½«ÖúÁ¦ÖйúOEM¿Í»§´Ó‘ÖйúÖÆÔì’×ßÏò‘Öйú´´Ôì’£¬Á촴ʱ´ú¡£”Ê©ÄÍµÂµçÆø¸ß¼¶¸±×ܲᢹ¤ÒµÊÂÒµ²¿ÖйúÇø¸ºÔðÈËÐì¿¥ÈçÊÇ˵¡£
2014Äê7ÔÂ14ÈÕÖÁ15ÈÕ£¬È«ÇòÄÜЧ¹ÜÀíר¼ÒÊ©ÄÍµÂµçÆøÔÚ¹ãÎ÷¹ðÁÖ¾Ù°ìÁË2014“Á촴ʱ´ú”OEM¿Í»§·å»áôßVIPÂÛ̳£¬Óë350¶àλÖйúOEMÕ½ÂÔºÏ×÷»ï°é¹²»°»úÓöÓëÌôÕ½£¬¹²ÐðÀíÏëÓëÔ¸¾°£¬¹²Ä±´´ÐÂÓë·¢Õ¹¡£·å»áÆÚ¼ä£¬Ê©ÄÍµÂµçÆøÕýÊ½ÍÆ³ö“Á촴ʱ´ú”18¿î´´ÐÂ×Ô¶¯»¯²úÆ·£¬ÎªÖйúOEMÆóÒµÓÂÅÊÈ«ÇòÖÆÔìÒµÖ®áÛÔöÌíÇ¿ÓÐÁ¦µÄÒýÇæ¡£
Ê©ÄÍµÂµçÆøÖ´Ðи±×ܲá¢ÖйúÇø×ܲÃÖ캣£¬Ê©ÄÍµÂµçÆø¸ß¼¶¸±×ܲᢹ¤ÒµÊÂÒµ²¿ÖйúÇø¸ºÔðÈËÐì¿¥¶Ô»°ÖйúOEMÕ½ÂÔºÏ×÷»ï°é
“ÖйúÔ´´”ʱ´úϵÄOEM
·å»áÉÏ£¬Ê©ÄÍµÂµçÆø¸ß¼¶¸±×ܲᢹ¤ÒµÊÂÒµ²¿È«Çò»úÆ÷½â¾ö·½°¸¸ºÔðÈËElie BelbelÎÞ²»×ÔºÀµØ±¨³öÒ»×éÊý¾Ý£ºÊ©ÄÍµÂµçÆøÔÚOEMÊг¡ÒµÎñ±íÏÖϲÈË£¬È«ÇòÊг¡ÔöËÙ´óÓÚÁ½Î»Êý£¬¶øÖйúÊÇǰÕßµÄÁ½±¶¡£ÌرðÊÇÔÚ°ü×°¡¢²ÄÁϼӹ¤¡¢ÎïÁϰáÔË¡¢ÆðÖØ¡¢·ÄÖ¯¡¢±Ã¡¢HVAC&RµÈ
Kobold Flow Meter DR-1272 #39792
Impervitran Industrial Control Transformer B500PU7JK #3
Armstrong C Clamp 106 7" Throat #37396
Russellstoll Connector Ever-Lok 8683U-1CT, 20 Amp, 125
Rexroth Valve DFBH30Z1GB1.01 #44552
Endine Shock Absorber #40809
Scantech Corp Fluxscanner Sensor 750-06 #30594
Econolim Current Limiting Fuse LCL 800, 600 Volt #3868
NEW Hayward YS10150S PVC Line Y-Strainer #7055
NEW Advance Electric Core & Coil HID Capacitor Kit 7C55
Prestolite Contactor HB407KF360BA #38498
Magcomp Transformer 120765-7-02 MC-1874 #36676
New Honeywell Proximity Switch 973AA3HM-A7T-L #34538
Dingman Voltage Stabilizer 5DAX-250-8-P #30634
New Swagelok Brass Bellows Sealed Valve B-4HK4 #41169
Sola Electric Power Supply SLS-12-068T #44599
Mosier Norgren F74G-4AN-AD1 Lubricator #10512
New Vesta Works Polish Blades FSP-448 #45236
JH Williams Heavy Service C Clamp CC-4A #37385
JH Williams C Clamp No. 6 #37398
JH Williams C Clamp No. 6 #37394
Desta Co Power Clamp 807-R #10172
Allen Bradley Analog Output Module 1771-OFC #34944
Allen Bradley Analog Output Module 1771-OFC #34945
Lucifer Solenoid Valve Coil 48 1865A5 F #33903
Lucifer Solenoid Valve Coil F 484990 P33 #33904
SCI Circuit Board 080-2470 180-2470 #25099
Powertran Transformer A036P250 #33952
Antunes Controls Gas Pressure Switch RLGP-G #42083
New Allen Bradley Fiber Optic Link 1403-CF003 #28943
Foster Transformer 301550-C #26041
Siemens Circuit Breaker B390H, 90 Amp, 240 Volt #42593
Wicke Topthane Caster 200 x 50, 7.5" Diam Rubber #28985
Square D Circuit Breaker FA26030AB 600 Volt #42340
Control Technology Thumbwheel Module 2204 #32439
Square D Circuit Breaker FAL34030 30 Amp #32146
SCI Circuit Board 180-2472, 080-2472-1 #37813
Kobold Flow Meter DR-1269 #39798
Allen Bradley Fuse Board 120880 #36194
Kobold Flow Meter ND13445 #39799
New Bimba Cylinder FO-095-2FCMT #29355
ATB Motor AF 71/4B-7 .25KW #15624
Speedaire Pneumatic Air Cylinder 6X372 #27398
A & N Corporation Stainless Steel Flange 25MW-180-002 #
Mercury 335NO-120A Contactor #11805
Mitsubishi Transistor Module CM75DY-24H #37313
Standard Power Supply SPW24-1.2 SPW2412 Acme #7522
Gould / Shawmut Current Limiting Fuse 400 Amp #31483
EGS Transformer T1500, 1.5 KVA #38755
SCI Circuit Board 21858-2, 51688 Rev E #33111
New Wika Gauge 9832381 0-160 #39142
New Swagelok Industrial Pressure Gauge PGI-63C-PC30-LA?O
New Swagelok Valve B-4HK4 #39264
SCI Circuit Board 080-2370 Rev D, 180-2370 Rev.D #3663
SCI Control Board 080-2370, 180-2370, #14919
SCI Circuit Board 080-2370 180-2370 Rev E F / G #25160
SCI Circuit Board 080-2370 180-2370 Rev E/G #25157
SCI Circuit Board 080-2370 180-2370 Rev E / H #25152
SCI Circuit Board 080-2370 180-2370 Rev G E / H #25162
SCI Circuit Board 080-2370 180-2370 Rev E / D #25153
SCI Circuit Board 080-2370, 180-2370 #24087
Optimation OM-9001-2 Communicatons Master #16256
Cramer Timer C11A03, 72 Min, 10 Amp, #22028
Turck Proximity Switch Ni35U-CK40-AP6X?2-H141 10-30 VDC
New STM Sensor GLS40ZS/S90-P:1?M #40375
Cincinnati Milacron 3-531-3779A PC Board, 35313779A #65
Sesotec Amplifier DV-10 #49363
Sesotec Amplifier DV-10 #49366
Allen Bradley Circuit Board A77153-209-52 #51098
Omron Timer H3CR-F8, 0-30 seconds #36488
Rexroth Pneumatic Valve 2518-1-9130-1 #40884
Standard Power Inc. Power Supply SLS 32-15 #35772
Sola Electric Power Supply SDN 5-24-100 #46502
Allen Bradley PC Board Series A N8 A191 #10529
Sola Electric Power Supply SDN 5-24-100P, 2.2/1.0 Amp #
Omron Limit Switch WL D2-TH #26819
Woodhead / Harrison Cable 774030C04F150 #29795
New Harrison / Woodhead Cable 774030C04F150 #29796
ASCO Red Hat General Purpose Valve 8215G33 #22371
Hydro Norma Valve Z2S6A-40 #13433
Vickers Gate Vent Breather BR110 #28743
Roller Conveyor Rollers: 32" L x 5 3/4" W, Approx. 32
GE Fanuc Programmable Controller IC692CPU211B #5021
Keyence Corp Photoelectric Connector PZ-V33P #5320
Schleicher Safety Relay SNO 2010-120 #51492
Allen Bradley Photoelectric Sensor Series B 42SRU-6412
Sharp 10 Slot Backplane ZW-508KB #53514
Asco Piston Valve 8290A005, 3/4", 240 PSI #53097
Electro Corp Sensor Head 4923A1500 43330
Fuji Electric 30 Amp Circuit Breaker H53B-30 #4675
Ê©Ä͵ÂÖØµã¹Ø×¢ÐÐÒµ£¬Ê©ÄÍµÂµçÆø³ÉΪÁìÅÜÕß¡£
