²úÆ·Ãû³Æ£º PCS 810-1
ÐÍ ºÅ£º PCS 810-1
PCS 810-1
PCS 810-1
 “Ê©Ä͵½«ÖúÁ¦ÖйúOEM¿Í»§´Ó‘ÖйúÖÆÔì’×ßÏò‘Öйú´´Ôì’£¬Á촴ʱ´ú¡£”Ê©ÄÍµÂµçÆø¸ß¼¶¸±×ܲᢹ¤ÒµÊÂÒµ²¿ÖйúÇø¸ºÔðÈËÐì¿¥ÈçÊÇ˵¡£
        2014Äê7ÔÂ14ÈÕÖÁ15ÈÕ£¬È«ÇòÄÜЧ¹ÜÀíר¼ÒÊ©ÄÍµÂµçÆøÔÚ¹ãÎ÷¹ðÁÖ¾Ù°ìÁË2014“Á촴ʱ´ú”OEM¿Í»§·å»áôßVIPÂÛ̳£¬Óë350¶àλÖйúOEMÕ½ÂÔºÏ×÷»ï°é¹²»°»úÓöÓëÌôÕ½£¬¹²ÐðÀíÏëÓëÔ¸¾°£¬¹²Ä±´´ÐÂÓë·¢Õ¹¡£·å»áÆÚ¼ä£¬Ê©ÄÍµÂµçÆøÕýÊ½ÍÆ³ö“Á촴ʱ´ú”18¿î´´ÐÂ×Ô¶¯»¯²úÆ·£¬ÎªÖйúOEMÆóÒµÓÂÅÊÈ«ÇòÖÆÔìÒµÖ®áÛÔöÌíÇ¿ÓÐÁ¦µÄÒýÇæ¡£
Ê©ÄÍµÂµçÆøÖ´Ðи±×ܲá¢ÖйúÇø×ܲÃÖ캣£¬Ê©ÄÍµÂµçÆø¸ß¼¶¸±×ܲᢹ¤ÒµÊÂÒµ²¿ÖйúÇø¸ºÔðÈËÐì¿¥¶Ô»°ÖйúOEMÕ½ÂÔºÏ×÷»ï°é
“ÖйúÔ­´´”ʱ´úϵÄOEM
        ·å»áÉÏ£¬Ê©ÄÍµÂµçÆø¸ß¼¶¸±×ܲᢹ¤ÒµÊÂÒµ²¿È«Çò»úÆ÷½â¾ö·½°¸¸ºÔðÈËElie BelbelÎÞ²»×ÔºÀµØ±¨³öÒ»×éÊý¾Ý£ºÊ©ÄÍµÂµçÆøÔÚOEMÊг¡ÒµÎñ±íÏÖϲÈË£¬È«ÇòÊг¡ÔöËÙ´óÓÚÁ½Î»Êý£¬¶øÖйúÊÇǰÕßµÄÁ½±¶¡£ÌرðÊÇÔÚ°ü×°¡¢²ÄÁϼӹ¤¡¢ÎïÁϰáÔË¡¢ÆðÖØ¡¢·ÄÖ¯¡¢±Ã¡¢HVACµÈÊ©Ä͵ÂÖØµã¹Ø×¢ÐÐÒµ£¬Ê©ÄÍµÂµçÆø³ÉΪÁìÅÜÕß¡£
        ÒÔ»úÆ÷×Ô¶¯»¯ÁìÓòΪÀý£¬2008ÖÁ2013Äê¼ä£¬Ê©ÄÍµÂµçÆøÈ«Çò»úÆ÷×Ô¶¯»¯ÒµÎñʵÏÖÈýÁ¬Ìø£¬ÆäÖУ¬ÖйúÊг¡±íÏÖÓÈΪͻ³ö£¬2009ÄêÖÁ2013Äê¼äÒµÎñÁ¿Ò»Â·Æ®ºì£¬ÊµÏÖ8
Western Digital WD Caviar WD2000JB 200 GB IDE 7200 RPM HDD
Mylex Ultra-2 PCI SCSI Raid Controller DAC960PRL
Dell NAS Server 1U / 1P Versa Rail Rack Complete Kit G1197
Fujitsu MHT2060AH 60 GB 4200 RPM IDE 2.5" Hard Drive
Hitachi IC25N060ATMR04-?0 60 GB 4200 RPM IDE 2.5" Hard Drive
Kingston KTH-XW667/2G 2GB (2x1GB) 2RX8 PC2-5300F FB-DIMM Server RAM
Kingston KTH-XW9400K2/4G 4GB (2x2GB) 128X4 PC2-5300 ECC Registered Server RAM
WLG500-3B MINI PCI / ISA Wireless Card
Adaptec 3000S 4-Channel SCSI Raid Controller Card
Maxtor DiamondMax 10 6L080L0 80 GB 7200 RPM IDE Hard Drive
HP 5181-2085 DDP2 Direct Distribution Panel
Maxtor STM3802110A 80 GB 7200 RPM IDE Hard Drive
Bourns 3541H-427-103L Potentiometer Hybritron RES 10Kohm 10% Lin 0.10% 1234M NEW
AMD Opteron 2216 OSA2216GAA6CQ 2.4 GHz Socket F Dual Core CPU
Palit Nvidia 7200GS DDR2 256MB PCI-E DVI VGA Video Card
Dell 2K221 Western Digital WD WD800BB 80 GB 7200 RPM IDE Hard Drive
Seagate ST3146707FC 146GB 10K RPM Fibre Channel Hard Drive
Intel Pentium D 915 2.8 GHz SL9DA LGA 775 CPU
Maxtor MaXLine II 5A320J0 320GB IDE ATA133 Hard Drive NetApp 108-00088 X266A
NetApp Cable P/N:112-00028 A0 Molex P/N 739391101
3Com Modem Dongle (3C-PC-MDM-US-C?BL)
AMD ADO5000IAA5DD Athlon 64 X2 5000+ 2.6 GHz Socket AM2 CPU
Fujitsu MHJ2181AT 18 GB 4200 RPM 2.5" IDE Hard Drive
Seagate ST3120023A 120 GB 7200 RPM IDE Hard Drive
Hewlett Packard HP 360209-011 BF1468A4CC 146 GB 15K Ultra 320 SCSI Drive
Minebea Astrosyn Stepper Motor Type 17PM-K103V (T0925) NEW
NEW! LOT of (4) Budwig Rectangular Thermoplastic Rubber Feet 1"x2"
Tektronix Phaser 740 Color Laser Printer - Black Toner Cartridge 016-1684-00
TYAN 47-0041-160N Motherboard
Seagate ST340016A 40 GB 7200 RPM IDE Hard Drive
Dell 9P516 ST340016A 40 GB 7200 RPM IDE Hard Drive
Intel PRO/1000 GT C80241-002 Desktop Adapter
Tributaries SA201 Single Channel S-Video Compensator
NEW IN BOX Xerox 108R149 Document Feed Head Assembly
Hewlett-Packard HP 1 GHz Terminiation Adapter 16515-63202
IBM 02K6643 ThinkPad Li-Ion Multiple Battery Charger
Sun Half & 1/4-height 3.5" HDD Spud Bracket 540-3923
Cisco Systems 72-22632-01 Serial Cable
Philips HP Agilent SpO2/PLETH M1020A Plug-In Module for M1041A Rack Viridia
Cisco Systems 1400 Series 1417 Router
National Instruments 763061-005 IEEE488 GPIB Cable Type X-2 0.6 Meters
Sun 541-2123-03 2.5" SAS Hard Drive Tray
Stratos Lightwave MHSDC-8-8-1-V SFP Module
Dell PowerEdge 1650 1750 2-Post Rail Rack Mount P/N C1132
Intel Pentium 4 650 3.4 GHz SL8Q5 LGA 775 CPU
Hitachi HUS103014FLF210 146 GB 10K FC Hard Drive
IDT NICStar Reference Design 25Mbps ATM NIC (IDT77916)
SMC SV1100-5FU Solenoid Valve
Cisco Digital Modems Network Module 800-02316-04A0
IBM 26K5262 73GB 2.5" 10K SAS Hard Drive 26K5657
Polycom 2201-08453-002 MIC Pod
Cisco Systems 1-Port T1 CSU/DSU (WIC-1DSU-T1)
CLEAN Belkin Universal Wireless HDTV Adapter TV Streaming Device w/ Orig. Pkg
EMC 038-003-385 2.5M HSSDC-SFP Cable
Fujitsu MHD2032AT 3 GB 4000 RPM 2.5" IDE Hard Drive
Seagate ST340017A 40 GB 7200 RPM IDE Hard Drive
Western Digital WD Caviar WD1200JB 120 GB IDE 7200 RPM Hard Drive
Seagate ST3160023A 160 GB 7200 RPM IDE Hard Drive
NEW Genuine Apple Mac Xserve Fiber Channel Cable w/ SFP GBIC XRAID 591-0208
Maxtor 4D040H2 40 GB 5400 RPM IDE PATA Hard Drive Apple 655T0112 - Tested
Minebea Astrosyn Stepper Motor Type 17PM-K404-T28V (T3531-01) NEW
Minebea Astrosyn Stepper Motor Type 16PY-Q210-02 (T9Y-01) NEW
QLogic QLA2100F/66 Fibre Channel Dual SC Host Bus Adapter PCI
Intel Pentium 4 SL7PL 2.8 GHz Socket 478 CPU
Minebea Astrosyn Brushless Stepper Motor Type 17PM-K404-T28V (T3531-01) NEW
Western Digital WD Caviar WD800LB 80 GB IDE 7200 RPM Hard Drive
NEC DTH-8D-1 Office Business Display Phone
Cisco Systems CP-7906G 7906 IP Phone
AMD Athlon 64 X2 3800+ ADO3800IAA5CS 2.0 GHz Socket AM2 CPU
Hewlett Packard HP EtherTwist 27247-60001 PC Link 16
New! Cole-Parmer EW-06407-42 12ft PTFE Tubing 1/8"OD 1/16"ID Factory Sealed
New Raritan DCIM-PS2 Computer Interface Module
New Raritan P2CIM-PS2 Computer Interface Module
Seagate ST3200822A 200 GB 7200 RPM IDE Hard Drive
Inter-Tel Axxess 8520 550.8520 Grey IP Business Phone
Colder Products CPC LCD22004 1/4 Hose Barb Valved In-Line Coupling Insert NEW
Inmac V.35 Cable 8M/25FT 34 Pin Male Straight 025001
MiTAC 250-Watt ATX Power Supply ( 370-3171 )
Microtest Inc Pair Scanner 8502 Injector Ethernet Network Cable Tester
Sun 370-3176 Seagate ST34342A 4.3 GB IDE 3.5" Hard Drive
Sun 370-3692 Seagate ST34321A 4.3 GB IDE 3.5" Hard Drive
Dell D0743 Hitachi DK23FB-20 20 GB 5400 RPM 2.5" IDE Hard Drive
Dell 87RVD Fujitsu MHM2100AT 10 GB 4200 RPM 2.5" IDE Hard Drive
IBM DJSA-205 5 GB 4200 RPM 2.5" IDE Hard Drive
Dell 0E329 IBM IC25N020ATDA04-?0 20 GB 4200 RPM 2.5" IDE Hard Drive
Dell 5K809 Hitachi DK23DA-20F 20 GB 4200 RPM 2.5" IDE Hard Drive
Dell 6J987 Hitachi IC25N020ATCS04-?0 20 GB 4200 RPM 2.5" IDE Hard Drive
Dell 4C449 IBM DJSA-220 20 GB 4200 RPM 2.5" IDE Hard Drive
QLogic QLA2342 Dual Fiber Channel Port Controller Card 111-00051
Cisco Systems 34-0640-01 Catalyst 5000 Series Power Supply
3COM 3C562B EtherLink III LAN + 28.8 Modem Dongle
Dell 31YMK 10GB Notebook IDE Drive ( IBM DJSA-210 )
3Com 3C996B-T Gigabit Server PCI-X Adapter Card
Picolight PL-XXL-SC-S45-2?2 GBIC
Pulsar Microwave 8-Way Splitter P8-H8-454/1B
ABB S201-K15 Miniature Circuit Breaker
Altera PLE3-12 Master Programming Unit with PLED600
RF Cable 00-990626-26 Cable
WinFast L2300V 8MB 3DLabs Permidia 2V PCI video card
NANOTEC 0.95A Phasemotor Stepper Motor ST4209S1006-KFU?T
Cisco 2M (M)/DB15(M) DTE 72-0682 High Density Applique & Interface Cable V.35
Lot of 2 - New Tektronix Phaser 3-Color Transfer Rolls 016-0906-01
ViaTV VC105 Set-Top Conferencing Video Phone
Toshiba MK1214GAP 12 GB 4200 RPM 2.5" IDE Hard Drive
3M D Ribbon Socket Metal Faced, 3549-2002
Hewlett-Packard HP J3193B 100Base-FX Fiber Optic Transceiver Plug-in
CoolJAG 1U Solid Copper Socket 604/603 Heastsink & Fan 2RC/180
Nortel Meridian M3902 Platinum Phone
Cisco Systems WIC-1B-U-V2 WAN Interface Card
Intel T2400 Core Duo 1.8 GHz Socket M CPU
Swagelok Check Valve SPRING KIT 302-4C-K2-1 R9HC5C691B NEW/SEALED In Packaging
Dell R1944 PowerEdge 650 Server Front Bezel Faceplate w/ 1 - Key
Condor SA-121AOU-2 12VDC 1A Class 2 Power Supply Adapter NEW 12V
Cinch / 18 circuit Terminal Block
Sun 501-3136 Ultra 256mb (2 x 128mb) Memory Modules Kit
Nortel Networks NTDU91 Silver Bezel Business Phone
Nortel Networks NTDU91 Black Business Phone
Cisco Systems SM25-T1 for Cisco 2524/2525
Panduit Fiber-Duct FiberRunner TRC2BL 2" Bend Radius
Toshiba T3100SX Automobile Power Adapter
Hitachi DK32EJ-14FC 146 GB Fibre Channel Hard Drive
SMC Cylinder NCDQ2B20-50DC 145 PSI 1.0 MPa
Sun Netra T1 I/O Board 501-5488
Sharp 4 Inch LCD Color Display & Cable 4L-U4E
Digi Fiber Twist Duplexer Model MIL 140 Converter
SPI Sparkle FSP200-50PLA 200 Watt Switching Power Supply
Adaptec AAA-131U2/2MB SCSI Raid Controller Card
Samsung 1GB (4x256MB) DDR-266 PC2100 Memory
Intel Pentium 4 550J 3.4 GHz SL7PY LGA 775 CPU
Intel Pentium D 3.4 GHz SL9QB LGA 775 CPU
JDSU 52P6537 1000Base-SX Wavelength 850nm SFP 2GB
Avaya 4610SW IP Phone
PanaFlo 60x60x25mm Box Fan 12-Volts DC FBA06A12V
Compaq Armada 4100 & 4200 Series Laptop Power Supply
Vexta Stepping Motor PK244-03A-C41 12V 0.4A
Palit ATI HD2400 PRO Sonic DDR2 256MB PCI-E Video Card
Palit Nvidia 7200GS DDR2 256MB PCI-E DVI Video Card LP
Dell PowerEdge 2650 2-Post Rack Mounting Complete Kit 1W224
Extron SW2 AR 250MHz Analog Video Switch
Intel Core 2 Duo E6300 SL9TA 1.86 GHz Dual Core LGA 775 CPU
Intel Pentium 4 3.6 GHz SL7Q2 LGA 775 CPU
Intel Core 2 Duo E6300 SLA5E 1.86 GHz Dual Core LGA 775 CPU
DVE DV-51AR 5VDC 1A Regulated 15W Power Supply Adapter DV51AR (New In Box)
Merry-King 10-13.5V 1.5max 15Wmax Power Supply Adapter AD1512C (New In Box)
Seagate ST3146807FC 146 GB 10K 40-Pin Fibre Channel Hard Drive
SOHOWare 1-port Print Server for Windows & NetWare
New! Sun Microsystems 8MB X3668A Frame Buffer PCI Card
Diego Class 2 Transformer KRM-093027 Adapter Input AC 120 127mA 7V 1A NEW IN BOX
(2) Sunon KDE1208PTB1-6 DC12V 2.6W (OC) Brushless Cooling Fan w/Molex Connectors
Cisco Systems NM-1HSSI High Speed Serial Network Module
Intel Pentium III 1000 MHz SL52R Socket 370 CPU
AMD Athlon 64 X2 3800+ ADA3800IAA5CU 2.0 GHz Socket AM2 CPU
Intel Core 2 Duo E6300 1.86 GHz Socket 775 CPU
Delta Electronics DPS-129AB A 130 Watt Power Supply
SuperMicro RR1U-E8 Riser Card
New ICY DOCK MB882SP-1S-2B 2.5" to 3.5" SSD & SATA HDD Converter Mounting Kit
AMD 8222 SE Opteron OSY8222GAA6CY 3 GHz Dual Core Socket F CPU
Intel Xeon SL6RR 3.06 GHz Socket 604 CPU
Intel 80486 A8048DX-33 33 MHz CPU
(2) Sanyo Denki 109P0412H302 DC 12V 0.195A Brushless Fine Ace Fan (NEW)
Cisco Systems WIC-1BU Interface Card
Asoka PL-9720-USB PlugLink USB Wall Mount - Single Pack
Agilent HFCT-5611 1000Base-LX 1300nm Transceiver GBIC
New/Out of Box Delta BFB1012H 12VDC Brushless Blower Fan
General Devices C-230-S-120 CC 2300 Slide C-230
Altera Max 7000S EPM7256SRC208-1?3
APC Smart Slot AP9608 Call-UPS II Remote Mgt. Device
Agilent Technologies QFBR-5697 1000Base-SX 850nm GBIC
SuperMicro RSC-R1UU-UAX Left Slot PCI-X Riser Card
New Passive Copper Heat Sink CPU Cooler with Hardware
HP JetDirect Card for Token Ring DB9 & RJ45 ( J2555A )
Orion Fans 92x92x25mm AC Cooling Fan OA92AP-11-1
Genuine Sharp F0-35TD Maintenance Cartridge
Bussmann Low-Peak Dual-Element Time-Delay Fuse LPS-RK-25SP
AMD Sempron 3000+ 1.8 GHz Processor SDA3000AI02BX
Intel Core Duo T2400 1.83 GHz SL8VQ Socket M CPU
Intel Celeron SL5XU 1100 MHz Socket 370 CPU
Intel Core 2 Duo T7300 2 GHz SLAMD Socket P CPU
AMD Opteron Model 848 OSA848CEP5AM 2.2 GHz Socket 940 CPU
New Genuine HP C4196A Transfer Kit for Color LaserJet
AMD Opteron Model 854 OSA854FAA5BM 2.8 GHz Socket 940 CPU
SUNNY Switching Power Adapter 5V SYS1196-0605-W2 (NEW)
Sun Serial Mouse Extension Cable 530-2154-01
Tektronix Phaseer 740 Color Laser Printer Hi-Capacity Yellow Toner 016-1659-00
Genuine Tektronix 016-1658-00 Magenta Laser Toner Cartridge
Dell 4-Drive SAS/SATA Backplane for 2U PowerEdge WM766
New STLab C-153 USB 2.0 1394a PCMCIA Cardbus
New! Rockwell GPS Module TU00-D200-401 TU00-D205-015
New Sunon KD1208PTB3-6 12V DC 1.4W Brushless Fan
ITT Cannon Sealectro 051-328-3188-22?0 RA Coax Adapter AU 9223
ITT Cannon Sealectro 051-028-0000-22?0 SMB Plug Right Angle Cabled
ITT Cannon Sealectro 050-024-0000-22?0 Conn 0-12.4GHz Crimp ST Cable Mount Gold
±¶Ôö³¤¡£
¹«Ë¾Ãû³Æ£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ÏúÊÛ²¿
µç »°£º 0592 5321698 / ÕÅÃÀ·ï
ÊÖ»ú£º 18020776791
µØ Ö·£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ ÏÃÃÅ˼Ã÷Çøºþ±õ¶«Â·ºþ¹â´óÏÃ18Â¥ABµ¥Ôª
ÓÊ ±à£º 361004
Ö÷ Ò³£º http://www.zxdadsqc.com/
  • HP PGM3410R
  • Shimadzu EI-D2003M
  • Panasonic MGM-32262S
  • 653B-8-200J-2
  • SGDM-50ADA
  • 1264C62G19,1264C62G19
  • Reliance O-60053
  • CR115A19
  • Square 9998HG1£¬Square 9998HG1
  • CM902WX
