²úÆ·ÌØÐÔ
ÊäÈëͨµÀÊýÁ¿Òµ½çÁìÏÈ
A20B-2900-0841/01AA20B-2900-0841/01A
ÿ̨YTMX580¶¼¿ÉÒÔÁ¬½Ó8̨ζȴ«¸ÐÆ÷£¬ÊäÈëͨµÀÊýÁ¿Òµ½çÁìÏÈ¡£¶øÇÒ¿ÉÒԹ㷺½ÓÊÕÈȵçż¡¢Èȵç×è¡¢mV¡¢µç×èºÍ4-20mAµÄÊäÈëÐźÅ*?¡£Ã¿¸öͨµÀ¶¼¿ÉÒÔµ¥¶ÀÅäÖÃÊäÈëÐźŵÄÖÖÀà¡£
ʹÓÃÈý¸öÒÔÄÚµÄͨµÀʱ£¬Ïò¼à¿ØÏµÍ³Êä³öÐźŵÄÖÜÆÚ½öÓÐ1ÃëÖÓ£»Ê¹ÓÃËĸö»ò¸ü¶àµÄͨµÀʱ£¬ÐźÅÊä³öÖÜÆÚÒ²²»¹ý2ÃëÖÓ¡£
µç³Ø×é
YTMX580ÓÉÄÚ²¿µç³Ø¹©µç£¬¿ÉÒÔ±£³Ö³£ÄêÕý³£¹¤×÷״̬¡£ÔÙ¼ÓÉÏÖ§³ÖISA100.11aÎÞÏßͨÐűê×¼µÄÌØÐÔ£¬Ê¹µÃÕâ¿î±äËÍÆ÷°²×°ÆðÀ´·Ç³£·½±ã¡£ÖµµÃÒ»ÌáµÄÊÇ£¬YTMX580ʹÓÃÁËÓëºáºÓµç»úISA100.11a±ê×¼EJX-BϵÁвîѹ/ѹÁ¦±äËÍÆ÷ºÍYTA510ζȱäËÍÆ÷ÏàͬµÄµç³Ø×é¡£Òò´Ë£¬ÒѾʹÓÃÕâЩÎÞÏß²úÆ·µÄÓû§ÔÚ´æ»õÇåµ¥Öнö¼Ç¼ÕâÒ»ÖÖµç³Ø×é¼´¿É¡£
Ö÷ҪĿ±êÊг¡
ʯÓÍÌìÈ»Æø¡¢Ê¯»¯¡¢»¯¹¤¡¢¸ÖÌú¡¢ÔìÖ½¡¢µçÁ¦¡¢Ë®´¦ÀíºÍÆäËûÁ÷³Ì¹¤Òµ
Ó¦ÓÃ
Á÷³Ì¹¤ÒÕÖд¢¹Þ¡¢¸ÉÔﯡ¢¹øÂ¯¡¢·¢¶¯»ú¡¢Ê¯ÓÍÌìÈ»ÆøºÍ»¯¹¤³§µÄÁѽ⯡¢ÕôÁóËþºÍ·´Ó¦¸ªµÈµÄ¸ßÃܶÈζȲâÁ¿¡£
È«Çò¿ØÖÆÏµÍ³Á㲿¼þ½â¾ö·½°¸
£¨Í¼Æ¬Ö»×ö²Î¿¼£¬²»´ú±íʵÎïͼ£¬¼Û¸ñºÍ¾ßÌåÄÚÈÝÇëµçѯ£¬¸ÐлÄúµÄÅäºÏ£©
ÖÙöδï×Ô¶¯»¯£¬×¨ÒµÏúÊÛ¸÷Àà¿É±à³Ì¿ØÖÆÆ÷£¬PLC£¬Ä£ÄâÁ¿ÊäÈëÄ£¿é£¬Ä£ÄâÁ¿Êä³öÄ£¿é£¬µçÔ´Ä£¿é£¬ËÅ·þ£¬±äƵÆ÷£¬Ç¶Èëʽ¿¨¼þ£¬CPU°å¿¨£¬DCS£¬ÈßÓàÈÝ´í¿ØÖÆÏµÍ³µÈ
Allen-Bradley(ÃÀ¹úAB)ϵÁвúÆ·¡·
Schneider(Ê©ÄÍµÂµçÆø)ϵÁвúÆ·¡·
General electric(ͨÓÃµçÆø) →GE←ϵÁвúÆ·¡·
Westinghouse£¨ÃÀ¹úÎ÷ÎÝ£©ÏµÁвúÆ·¡·
ÏúÊÛABB Robots. FANUC Robots¡¢YASKAWA Robots¡¢KUKA Robots¡¢Mitsubishi estinghouse£¨Î÷ÎÝ£©£º OVATIONϵͳ¡¢WDPFϵͳ¡¢MAX1000ϵͳ±¸¼þ
Invensys Foxboro£¨¸£¿Ë˹²¨ÂÞ£©£ºI/A Seriesϵͳ£¬FBM£¨ÏÖ³¡ÊäÈë/Êä³öÄ£¿é£©Ë³Ðò¿ØÖÆ¡¢ÌÝÐÎÂß¼¿ØÖÆ¡¢Ê¹Ê×·Òä´¦Àí¡¢Êýģת»»¡¢ÊäÈë/Êä³öÐźŴ¦Àí¡¢Êý¾ÝͨÐÅ
Invensys Triconex: ÈßÓàÈÝ´í¿ØÖÆÏµÍ³¡¢»ùÓÚÈýÖØÄ£¼þÈßÓࣨTMR£©½á¹¹µÄ×îÏÖ´ú»¯µÄÈÝ´í¿ØÖÆÆ÷
Siemens(Î÷ÃÅ×Ó)£ºSiemens MOORE£¬ Siemens Simatic C1£¬SiemensÊý¿ØÏµÍ³µÈ
Bosch Rexroth£¨²©ÊÀÁ¦Ê¿ÀÖ£©£ºIndramat£¬I/OÄ£¿é,PLC¿ØÖÆÆ÷,Çý¶¯Ä£¿éµÈ
Motorola£¨Ä¦ÍÐÂÞÀ£©£ºMVME 162¡¢MVME 167¡¢MVME1772¡¢MVME177µÈϵÁÐ
D4-06B-1 6-Slot Local or Expansion Base
D4-08B-1 8-Slot Local or Expansion Base
D4-08ND3S Digital Input Module
D4-08TD1 Digital Output Module
D4-16NE3 Digital Input Module
D4-450 CPU Module
653.000.23 Cardfile
653.325.01 CPU Module
653.325.06 EPROM Module
653.353.01 Timer Module
653.385.04 Power Supply
657.400.63 Cardfile
657.425.02 CPU Module
657.426.01 8K RAM Module
657.451.01 Input Module
657.452.01 Output Module
657.485.06 Power Supply Module
680.450.01 Digital Input/Ouput Module
680.450.03 Digital I/O Module
680.451.03 Digital Input Module
NT2430-3 NT2430-3 DC Power Supply
LV43.4311 Landis & Gyr Module
LVF1.4301 LVF14301 Landis & Gyr Module
LVF1.4315 LVF14315 Landis & Gyr Module
LVF2.4601 LVF24601 Landis & Gyr Module
LVF2.4604 LVF24604 Landis & Gyr
LVF2.4713 LVF24713 Landis & Gyr Module
LVF2.4714 LVF24714 Landis & Gyr Module
LVF2.4723 LVF24723 Landis & Gyr Module
022/30c LCA 245/180 Lauer LCA 245/180 Display Replacement Screen
022/31b LCA 245/180 Lauer LCA 245/180 Display Module
LCA 042 Text Display
LCA 180 LCA180 Display Module
LCA020 Terminal Block
LCA245 LCA245 Text Display
LCA245.1 LCA245.1 Text Display
LCA250.1 LCA250 Text Panel
LCA265 Lauer Panel
LCA285 Lauer Text Panel
LCA320.0 Lauer Starline Midi Panel
LCA325.0 Lauer Starline Midi Panel
LCA350.0 Lauer Starline Midi Panel
LCA360 LC360 Text Panel
LCA640.1 LCA640.1 Lauer Terminal
PCS009 201295 PCS 009 Topline Micro Operator Panel
PCS009.m PCS 009 plus Operator Panel with MPI
PCS009.s PCS 009 plus Operator Panel with Serial
PCS009.s-Pero PCS 009 plus Operator Panel with Serial
PCS090 Lauer PCS090 Operator Panel
PCS090-Bosch PCS090 Operator Panel
PCS090.M Operator Panel PCS090 Plus - MPI
PCS090.p Operator Panel PCS090 Plus - Profibus
PCS090.s PCS 090 plus PCS 090 plus Operator Panel with Serial Interfaces
PCS095 PCS 095 Operator Panel - Top Line Mini
PCS095-Bosch PCS 095 Operator Panel - Top Line Mini
PCS095-Pester PCS 095 Operator Panel - Top Line Mini
PCS095-Weber PCS 095 Operator Panel - Top Line Mini
PCS095.m PCSplus MPI Operator Panel PCS095 plus with MPI Interface
PCS095.m-Wolf PCSplus MPI Operator Panel PCS095 plus with MPI Interface
PCS095.p PCS095.p Plus Panel with Profibus-DP
PCS095.s Operator Panel PCS plus with Serial Interface
PCS095.s-Weber Operator Panel PCS plus with Serial Interface
PCS100 PCS 100 Operator Panel
PCS100FZ PCS 100FZ Operator Panel
PCS110 PG110.302.4 251091 PCS 110 Operator Panel
PCS110FZ PCS 110FZ Operator Panel
PCS200 Operator Panel
PCS200FZ PCSFZ12494KO PCS 200FZ Operator Panel
PCS590p PCS 590p Busline Mini Operator Panel
PCS600FZ EuroTerminal Operator Panel
PCS609 Operator Panel
PCS801 PCS 801 EPROM
PCS8010 Interface Module for PCS9000
PCS802 PCS 802 EEPROM,802-07197 PCS 802 EEPROM Memory Pack
PCS807 Profibus DP-Module
PCS810 PCS810-1 Lauer PCS810 Interface Module
PCS810-3 PCS810-3 Module
PCS811 Interbus S Modul
PCS812 S7-MPI Module
PCS891 Interface Panel
PCS900 Operator Panel
PCS9000 Operator Panel
PCS920 Topline Midi Touch Panel
PCS950 PCS950 Operator Panel
