6EC1-470-0A6EC1-470-0A
È«ÃæìÉýµÄ¹¦ÄܱíÏÖÈÃÄúÔÚÏÖ³¡³ö¾¡·çÍ·¡£¾ÞÁ¿µÄÀúÊ·Êý¾Ý¿ÉÒÔ´æ´¢ÒÔ¼°ÏÔʾÖÁÇ÷ÊÆÍ¼£¬ÉõÖÁ¿ÉÒÔÖ±½ÓÊäÈëʱ¼ä¶Î½øÐв鿴¡£¾¯±¨ÐÅÏ¢²»½ö¿ÉÒÔ¼´Ê±ÏÔʾÓÚÆÁÄ»ÉÏ£¬»¹¿ÉÒÔÖ±½Ó·¢Ë͵½´òÓ¡»úÊä³ö»òÕß·¢ËÍÓʼþÉõÖÁ¶ÌÐÅ֪ͨÏà¹ØÈËÔ±¡£Áé»îµÄ±¨¸æ¹¦ÄÜ¿ÉÒÔËæÊ±ËæµØµÄ½«ÐèÒªµÄ±¨±íÒÔexcelÎļþµÄÐÎʽ´¢´æÆðÀ´¡£Åä·½ÒÑ¾È«ÃæÖ§³ÖÖÐÎÄ£¬²»½öÅä·½Ãû³Æ¿ÉÒÔʹÓÃÖÐÎÄ£¬Á¬Åä·½ÄÚÈݶ¼¿ÉÒÔÓɺº×Ö×é³É¡£Ç¿´óµÄ²Ù×÷¼Ç¼¹¦ÄÜ£¨ÓֳƵç×ÓÇ©Ãû£©¿ÉÒÔ½«²Ù×÷ÈËÔ±½øÐеÄÈκβÙ×÷ÖÒʵ¼Ç¼£¬±ãÓÚÈÕºóµÄ×·Ëݲéѯ¡£Ô¶³Ì·ÃÎÊ¡¢FTP¡¢Web ServerµÈÍøÂ繦ÄÜÈ«²¿Ö§³Ö£¬ÈÃÄúµÄÈË»ú²Ù×÷¿ÉÒÔͨ¹ýÍøÂçÑÓÉìÖÁÈκεط½¡£
ÓÉWinceºÍ.NET ¹¹³ÉµÄ¿ª·Åƽ̨£¬¿ÉÒÔÈÃÓû§È¥ÍØÕ¹ÈË»úµÄʹÓã¬Ò²¿ÉÒÔ½«×Ô¼º¹æ»®µÄÆäËüÓ¦ÓóÌÐò½»ÓÉÈË»úÖ´ÐС£¶øÇÒÇ¿´óµÄC#½Å±¾¿ÉÒÔÈÃÓû§ÍêÈ«Å׿ªÈí¼þÔÓеÄÏÞÖÆ£¬ÈÎÆ¾×Ô¼º¶ÔC#µÄÕÆ¿Ø¾¡Ç鿪¿ÑÈË»úµÄ¹¦ÄܱíÏÖÖ®½®¡£
PWX 8000ϵÁвúÆ·µÄÍÆ³ö£¬ÊÇHITECH¶Ô¹¤¿ØÁìÓòµÄÓÖÒ»¿¸¶¦Ö®×÷£¬ÒÔÈÈÇéÇãערҵ֮ÐÄ£¬·îÏ×ÇÉ˼¾«¹¤Ö®Õ鯷£¬ÊÍ·¢È«ÐµĹ¤Òµ´¥¿ØÌåÑé¡£HITECH PWX8000ϵÁÐÊÆ±Ø»áÔÚ¹úÄÚÈË»ú½çÃæÊг¡ÔÙÏÆ²¨À½£¬×ÝÇéÒýÁ칤ҵ´¥¿Ø¼¼Êõ³±Á÷¡£
6ES7312-5BD00-0AB0 CPU312C CPU 312C Compact Siemens
6ES7312-5BD01-0AB0 CPU312C CPU 312C Compact with MPI Siemens
6ES7312-5BE03-0AB0 CPU312C Simatic S7-300 CPU 312C Compact Siemens
6ES7312-5BF04-0AB0 CPU 312C CPU312C Processor Module Siemens
6ES7313-1AD00-0AB0 CPU 313 CPU 313 Processor Module Siemens
6ES7313-1AD01-0AB0 CPU 313 CPU 313 Processor Module Siemens
6ES7313-1AD02-0AB0 CPU 313 CPU 313 Processor Module Siemens
6ES7313-1AD03-0AB0 CPU 313 CPU 313 Processor Module Siemens
6ES7313-5BE00-0AB0 CPU 313C CPU 313C Module Siemens
6ES7313-5BE01-0AB0 CPU 313C CPU 313C Compact CPU Siemens
6ES7313-5BE03-0AB0 CPU 313C CPU 313C Compact CPU Siemens
6ES7313-5BF03-0AB0 CPU 313C Compact CPU313C Siemens
6ES7313-5BG04-0AB0 CPU 313C Compact CPU with MPI Siemens
6ES7313-6BE00-0AB0 CPU313C-2 PTP CPU313C-2 PTP Compact CPU Module with MPI Siemens
6ES7313-6BE01-0AB0 CPU313C-2 PTP CPU313C-2 PTP Compact CPU Module with MPI Siemens
6ES7313-6BF03-0AB0 CPU313C-2 PTP CPU313C-2 PTP Compact CPU Module with MPI Siemens
6ES7313-6BG04-0AB0 CPU 313C-2 PtP CPU313C-2 PtP Processor Module Siemens
6ES7313-6CE00-0AB0 CPU313C-2DP CPU 313C-2DP Siemens
6ES7313-6CE01-0AB0 CPU313C-2DP CPU 313C-2 DP Compact CPU Siemens
6ES7313-6CF01-0AB0 CPU 313C-2 DP CPU 313C-2 DP Compact CPU with MPI Siemens
6ES7313-6CF03-0AB0 CPU 313C-2 DP CPU 313C-2 DP Compact CPU with MPI Siemens
6ES7313-6CG04-0AB0 CPU 313C-2 DP CPU 313C-2 DP Processor Module Siemens
6ES7314-1AE01-0AB0 CPU 314 Simatic S7-300 CPU 314 Siemens
6ES7314-1AE02-0AB0 CPU 314 Simatic S7-300 CPU 314 Siemens
6ES7314-1AE03-0AB0 CPU 314 Simatic S7-300 CPU 314 Siemens
6ES7314-1AE04-0AB0 CPU 314 Simatic S7-300 CPU 314 Siemens
6ES7314-1AF10-0AB0 CPU 314 Simatic S7-300 CPU 314 Siemens
6ES7314-1AF11-0AB0 CPU314 CPU314 Processor Module Siemens
6ES7314-1AG13-0AB0 CPU314 CPU314 Processor Module Siemens
6ES7314-1AG14-0AB0 CPU314 CPU314 Processor Module Siemens
6ES7314-5AE00-0AB0 CPU314 IFM CPU314 IFM Module Siemens
6ES7314-5AE01-0AB0 CPU314 IFM CPU314 IFM Module Siemens
6ES7314-5AE02-0AB0 CPU314 IFM S7-300 CPU314 IFM Siemens
6ES7314-5AE03-0AB0 CPU314 IFM S7-300 CPU314 IFM Siemens
6ES7314-5AE10-0AB0 CPU314 IFM CPU314 IFM Module Siemens
6ES7314-6BF00-0AB0 CPU314C-2PTP CPU314C-2PTP Siemens
6ES7314-6BF01-0AB0 CPU 314C-2 PTP CPU 314C-2 PTP Compact CPU With MPI Siemens
6ES7314-6BF02-0AB0 CPU314C-2PTP CPU314C-2PTP Siemens
6ES7314-6BG03-0AB0 CPU 314C-2 PTP CPU 314C-2 PTP Compact CPU With MPI Siemens
6ES7314-6BH04-0AB0 CPU314C-2PTP CPU314C-2PTP Processor Module Siemens
6ES7314-6CF00-0AB0 CPU314C-2DP CPU314C-2DP Siemens
6ES7314-6CF01-0AB0 CPU314C-2DP CPU314C-2DP Processor Module Siemens
6ES7314-6CF02-0AB0 CPU314C-2DP CPU314C-2DP Processor Module Siemens
6ES7314-6CG03-0AB0 CPU314C-2DP CPU 314C-2DP Compact CPU with MPI Siemens
6ES7314-6CH04-0AB0 CPU 314C-2 DP CPU314C-2 DP Processor Siemens
6ES7314-6EH04-0AB0 CPU 314C-2PN/DP CPU 314C-2PN/DP Compact CPU Siemens
6ES7315-1AF00-0AB0 CPU315 Simatic S7-300 CPU 315 Siemens
6ES7315-1AF01-0AB0 CPU315-1 Simatic S7-300 CPU 315 Siemens
6ES7315-1AF02-0AB0 CPU315-1 S7-300 CPU315-1 24VDC Siemens
6ES7315-1AF03-0AB0 CPU315-1 Simatic S7-300 CPU 315 Siemens
6ES7315-2AF00-0AB0 CPU 315-2 DP Simatic S7-300 CPU 315-2DP Siemens
6ES7315-2AF01-0AB0 CPU 315-2DP Simatic S7-300 CPU 315-2DP Siemens
6ES7315-2AF02-0AB0 CPU 315-2DP Simatic S7-300 CPU 315-2DP Siemens
6ES7315-2AF03-0AB0 CPU 315-2DP CPU 315-2DP Processor Module Siemens
6ES7315-2AF83-0AB0 CPU315-2DP CPU315-2DP Processor Siemens
6ES7315-2AG10-0AB0 CPU 315-2DP Simatic S7-300 CPU 315-2DP Siemens
6ES7315-2AH14-0AB0 CPU 315-2DP Simatic S7-300 CPU 315-2DP Siemens
6ES7315-2EG10-0AB0 CPU315-2 PN/DP CPU 315-2 PN/DP Central Processor Siemens
6ES7315-2EH13-0AB0 CPU 315-2 PN/DP CPU 315-2 PN/DP Processor Siemens
6ES7315-2EH14-0AB0 CPU 315-2 PN/DP CPU 315-2 PN/DP Processor Siemens
6ES7315-2FH13-0AB0 CPU315-2 Central Processing Unit Siemens
6ES7315-2FJ14-0AB0 CPU315F-2 PN/DP CPU315F-2 PN/DP Central Processing Unit Siemens
6ES7315-6FF00-0AB0 CPU315F-2DP Failsafe Controller Siemens
6ES7315-6FF01-0AB0 CPU315F-2DP CPU 315F Failsafe Processor Module Siemens
6ES7315-6FF04-0AB0 CPU315F-2DP CPU 315F-2DP Failsafe Processor Module Siemens
6ES7315-6TH13-0AB0 CPU 315T-2 DP CPU 315T-2 DP Central Processor Siemens
6ES7316-1AG00-0AB0 CPU 316-1 CPU 316-1 Processor Module Siemens
6ES7316-2AG00-0AB0 CPU316-2DP CPU 316-2DP Processor Module Siemens
6ES7317-2AJ10-0AB0 CPU317-2DP CPU317-2DP Processor Module Siemens
6ES7317-2AK14-0AB0 CPU317-2 DP CPU317-2 DP Central Processing Unit Siemens
6ES7317-2EJ10-0AB0 CPU317-2 PN/DP CPU317-2 PN/DP Processor Module Siemens
6ES7317-2EK13-0AB0 CPU 317-2 PN/DP CPU317-2 PN/DP Central Processor Siemens
6ES7317-2EK14-0AB0 CPU 317-2 PN/DP CPU317-2 PN/DP Central Processor Siemens
6ES7317-2FK13-0AB0 CPU317F-2 PN/DP CPU317F-2 PN/DP Processor Module Siemens
6ES7317-2FK14-0AB0 CPU317F-2 PN/DP CPU317F-2 PN/DP Processor Module Siemens
6ES7317-6FF00-0AB0 CPU 317F-2DP Processor CPU 317F-2DP Siemens
6ES7317-6FF04-0AB0 CPU 317F-2 DP Siemens
6ES7317-6TF14-0AB0 TCPU317TF-2 DP, 1,5 MB Siemens
6ES7317-6TJ10-0AB0 CPU 317T-2 DP CPU317T-2 DP Central Processing Unit Siemens
6ES7317-6TK13-0AB0 CPU317T-2 DP, 1024KB Siemens
6ES7317-7TK10-0AB0 CPU317T-3 PN/DP, 1024KB Siemens
6ES7317-7UL10-0AB0 CONTROLLER CPU317TF-3 PN/DP,1.5MB,2P Siemens
6ES7318-2AJ00-0AB0 CPU 318-2DP CPU 318-2DP Processor Module Siemens
6ES7318-3EL00-0AB0 CPU 319-3 PN/DP CPU 319-3 PN/DP Central Processor Siemens
6ES7318-3EL01-0AB0 CPU 319-3 PN/DP CPU 319-3 PN/DP Central Processor Siemens
6ES7318-3FL00-0AB0 CPU319F-3 PN/DP CPU319F-3 PN/DP Processor Siemens
6ES7318-3FL01-0AB0 CPU319F-3 PN/DP CPU319F-3 PN/DP Central Processor Module Siemens
6ES7321-1BH00-0AA0 SM321 SM321 Digital Input Module Siemens
6ES7321-1BH01-0AA0 SM321 SM321 Digital Input Module Siemens
6ES7321-1BH02-0AA0 SM321 SM321 Digital Input Module Siemens
6ES7321-1BH10-0AA0 SM321 Digital Input Module Siemens
6ES7321-1BH50-0AA0 SM321 Digital Input Module Siemens
6ES7321-1BL00-0AA0 SM321 Digital Input Module Siemens
6ES7321-1BP00-0AA0 SM321 Digital Input Module Siemens
6ES7321-1CH00-0AA0 SM321 Digital Input Module Siemens
6ES7321-1CH20-0AA0 SM321 Digital Input Module Siemens
6ES7321-1EH01-0AA0 SM321 Digital Input Module - 120 Vac Siemens
6ES7321-1EL00-0AA0 SM321 Digital Input Module Siemens
6ES7321-1FF01-0AA0 SM321 Digital Input Module Siemens
6ES7321-1FF10-0AA0 SM321 Digital Input Module Siemens
6ES7321-1FH00-0AA0 SM321 Digital Input Module Siemens
6ES7321-7BH00-0AB0 SM321 Digital Input Module Siemens
6ES7321-7BH01-0AB0 SM321 Digital Input Module Siemens
6ES7321-7RD00-0AB0 SM321 Digital Input Module Siemens
6ES7321-7TH00-0AB0 SM321 Digital Intput Module Siemens
6ES7322-1BF01-0AA0 SM322 Digital Output Module Siemens
6ES7322-1BH00-0AA0 SM322 Digital Output Module Siemens
6ES7322-1BH01-0AA0 SM322 SM322 Digital Output Module Siemens
6ES7322-1BH10-0AA0 SM322 Digital Output Module - High Speed Siemens
6ES7322-1BH81-0AA0 SM322 Digital Output Module Siemens
6ES7322-1BL00-0AA0 SM322 Digital Output Module Siemens
6ES7322-1BP00-0AA0 SM322 Digital Output Module Siemens
6ES7322-1BP50-0AA0 SM322 Digital Output Module Siemens
6ES7322-1CF00-0AA0 SM322 Digital Output Module Siemens
6ES7322-1EH00-0AA0 SM322 SM322 Digital Output Module Siemens
6ES7322-1EH01-0AA0 SM322 Digital Output Module Siemens
6ES7322-1FF00-0AA0 SM322 SM322 Digital Ouput Module Siemens
6ES7322-1FF01-0AA0 SM322 Digital Output Module Siemens
6ES7322-1FH00-0AA0 SM322 SM322 Digital Ouput Module Siemens
6ES7322-1FL00-0AA0 SM322 Digital Output Module Siemens
6ES7322-1HF01-0AA0 SM322 Digital Output Module - Relay Siemens
6ES7322-1HF10-0AA0 SM322 Digital Output Module - Relay Siemens
6ES7322-1HH00-0AA0 SM322 Digital Output Module - Relay Siemens
6ES7322-1HH01-0AA0 SM322 Digital Output Module - Relay Siemens
6ES7322-5FF00-0AB0 SM322 Digital Output Module Siemens
6ES7322-5GH00-0AB0 SM322 Digital Output Module Siemens
6ES7322-5HF00-0AB0 SM322 Digital Output Module Siemens
6ES7322-5RD00-0AB0 SM322 Digital Output Module Siemens
6ES7322-5SD00-0AB0 SM322 Digital Output Module Siemens
6ES7322-8BF00-0AB0 SM322 SM322 Digital Output Module Siemens
6ES7322-8BH00-0AB0 SM322 Digital Output Module Siemens
6ES7322-8BH01-0AB0 SM322 Digital Output Module Siemens
6ES7323-1BH00-0AA0 SM 323 SM 323 Digital I/O Module Siemens
6ES7323-1BH01-0AA0 SM323 Digital Input/Output Module Siemens
6ES7323-1BL00-0AA0 SM 323 Digital I/O Module Siemens
6ES7326-1BK00-0AB0 SM326 SM326 Digital Input Module - Failsafe Siemens
6ES7326-1BK01-0AB0 SM326 SM326 Digital Input Module - Failsafe Siemens
6ES7326-1BK02-0AB0 SM326 SM326 Digital Input Module - Failsafe Siemens
6ES7326-1RF00-0AB0 SM326 Digital Input Module - Failsafe Siemens
6ES7326-2BF00-0AB0 SM326 SM326 Digital Output Module - Failsafe Siemens
6ES7326-2BF01-0AB0 SM326 SM326 Digital Output Module - Failsafe Siemens
6ES7326-2BF10-0AB0 SM326 SM326 Digital Output Module - Failsafe Siemens
6ES7326-2BF40-0AB0 SM326 SM326 Digital Output Module - Failsafe Siemens
6ES7326-2BF41-0AB0 SM326 SM326 Digital Output Module - Failsafe Siemens
6ES7327-1BH00-0AB0 SM327 Digital I/O Module Siemens
6ES7328-0AA00-7AA0 Raised Front Doors - Package of 5 Siemens
6ES7328-7AA10-0AA0 EXTENDED FRONT DOOR F. F MODULES, 5 PCS. Siemens
6ES7331-1KF00-0AB0 SM331 Analog Input Module Siemens
6ES7331-1KF01-0AB0 SM331 Analog Input Module Siemens
6ES7331-1KF02-0AB0 SM331 Analog Input Module Siemens
6ES7331-7HF01-0AB0 SM331 Analog Input Module Siemens
6ES7331-7KB01-0AB0 SM331 SM331 Analog Input Module Siemens
6ES7331-7KB02-0AB0 SM331 Analog Input Module Siemens
6ES7331-7KB82-0AB0 SM331 Analog Input Module - Isolated Siemens
6ES7331-7KF01-0AB0 SM331 SM331 Analog Input Siemens
6ES7331-7KF02-0AB0 SM331 SM331 Analog Input Module Siemens
6ES7331-7NF00-0AB0 SM331 Analog Input Module Siemens
6ES7331-7NF10-0AB0 SM331 Analog Input Module Siemens
6ES7331-7PE10-0AB0 SM331 Analog Input Module Siemens
6ES7331-7PF00-0AB0 SM331 Analog Input Module - RTD Siemens
6ES7331-7PF01-0AB0 SM331 Analog Input Module - RTD Siemens
6ES7331-7PF10-0AB0 SM331 Analog Input Module - TC Siemens
6ES7331-7PF11-0AB0 SM331 Analog Input Module - TC Siemens
6ES7331-7RD00-0AB0 SM331 Analog Input Module Siemens
6ES7331-7SF00-0AB0 SM331 Analog Input Module Siemens
6ES7331-7TB00-0AB0 SM331 Analog Input Module Siemens
6ES7331-7TF00-0AB0 SM331 Analog Input Module - HART Siemens
6ES7331-7TF01-0AB0 SM331 Analog Input Module Siemens
6ES7332-5HB01-0AB0 SM332 Analog Output Module Siemens
6ES7332-5HB81-0AB0 SM 332 Analog Output Module Siemens
6ES7332-5HD01-0AB0 SM332 Analog Output Module Siemens
6ES7332-5HF00-0AB0 SM332 Analog Output Module Siemens
6ES7332-5RD00-0AB0 SM332 Analog Output Module Siemens
6ES7332-5TB00-0AB0 SM332 Analog Output Module -HART Siemens
6ES7332-7ND00-0AB0 SM332 Analog Output Module, 16-bit Siemens
6ES7332-7ND01-0AB0 SM332 SM332 Analog Output Module Siemens
6ES7332-7ND02-0AB0 SM332 SM 332 Analog Output Module Siemens
6ES7332-8TF01-0AB0 SM332 Analog Output Module Siemens
6ES7334-0CE00-0AA0 SM334 Analog Module SM334 Siemens
6ES7334-0CE01-0AA0 SM334 Analog I/O Module Siemens
6ES7334-0KE00-0AB0 SM334 Analog Input/Output Module Siemens
6ES7334-0KE80-0AB0 SM334 Analog Input/Output Module Siemens
6ES7335-7HG00-0AB0 SM335 SM335 Analog Input/Output Module Siemens
6ES7335-7HG01-0AB0 SM335 SM335 Analog Input/Output Module Siemens
6ES7335-7HG02-0AB0 SM335 Analog I/O Module Siemens
6ES7336-1HE00-0AB0 SM336 SM336 Analog Input Module Siemens
6ES7336-4GE00-0AB0 SM336 Analog Input Module - Failsafe Siemens
6ES7338-4BC00-0AB0 SM338 SM338 Signal Module Siemens
6ES7338-4BC01-0AB0 SM338 Signal Module for Positioning Sensors Siemens
6ES7338-7UH01-0AC0 SM338 SM 338 Ultrasonic Position Decoder Module Siemens
6ES7338-7XF00-0AB0 SM338 IQ-Sense Module Siemens
6ES7340-1AH00-0AE0 CP 340 CP340 Communications Processor Module Siemens
6ES7340-1AH01-0AE0 CP340 CP340 Communications Processor Module Siemens
6ES7340-1AH02-0AE0 CP340 CP340 Serial Communication Module Siemens
6ES7340-1BH00-0AE0 CP340 CP340 20mA TTY Interface Module Siemens
6ES7340-1BH02-0AE0 CP340 CP340 20mA TTY Interface Module Siemens
6ES7340-1CH00-0AE0 CP340 Communications Processor CP340 Siemens
6ES7340-1CH02-0AE0 CP340 CP340 RS422/485 Interface Module Siemens
6ES7341-1AH00-0AE0 CP341 Simatic S7-300 CP341 RS232C Siemens
6ES7341-1AH01-0AE0 CP341 CP341 Communication Module - Serial Siemens
