Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú CM902WX£¬CM902WX
²úÆ·Ãû³Æ£º CM902WX£¬CM902WX
ÐÍ ºÅ£º CM902WX£¬CM902WX
CM902WX CM902WX CM902WX IASϵͳ£ºÌá¸ßЧÂÊ ½µµÍ³É±¾
»ôÄáΤ¶ûÔÚÐÐÒµÄڵõ½Óû§ºÍ´¬³§µÄÊ׿ϣ¬µÃÒæÓÚÆäIAS¼¯³É¿ØÖÆÏµÍ³¡£IAS¼¯³É¿ØÖÆÏµÍ³°üÀ¨IO¿¨¼þ¡¢¿ØÖÆÆ÷¡¢ HMIÈË»ú½çÃæ¡¢ÔËËã²ãÃæµÈ£¬ÔÚÕâЩ²ãÃæÖ®¼ä²ÉÓûôÄáΤ¶ûרÀû¿ØÖÆ·À»ðǽ½øÐÐÊý¾Ý¸ôÀ룬´Ó¶ø±£ÕÏÍøÂ簲ȫ¡£¶øIAS¼¯³ÉCM902WX CM902WX
¿ØÖÆÏµÍ³»ùÓÚLNGÔËÊä´¬¿ØÖƵIJ¿·Ö£¬Ö÷Òª·ÖΪ¶¯Á¦¹ÜÀíϵͳºÍÆøÌå¹ÜÀíϵͳ¡£ÆøÌå¹ÜÀíϵͳ°üÀ¨¼à¿Ø¹ÞÀïµÄѹÁ¦¡¢Î¶ÈÒÔ¼°¿ØÖƹÞÀïµÄ¹¤ÒÕÁ÷³Ì£»¶ø¶¯Á¦¹ÜÀíÔò¿ÉÒÔÁ¬½Óµ½·¢¶¯»úÒýÇæ¡¢ÍƽøÆ÷£¬Ë«È¼Áϵç»úµÈ¡£LNG˫ȼÁÏ´¬µÄGMSºÍPMSÊÇ»¥Ïà¹ØÁª¿ØÖƵġ£Í¨¹ý¿ØÖÆÆ÷£¬°ÑËùÓÐ×Ô¶¯»¯µÄ³ÌÐòÏÂÔØµ½¿ØÖÆÆ÷ÀÓÉÕû¸öIASÀ´Ö´ÐÐÈ«Ì×¹ØÁª¿ØÖƵÄÖ´Ðк͹ÜÀí¡£
LNG´¬²»Í¬ÓÚÒÔÍù´¬Ö»£¬Ëüʱ¿Ì´¦ÓÚ-160¡æÒÔϵĵÍÎÂ״̬£¬¶øIAS¼¯³É¿ØÖÆÏµÍ³ÊµÊ±µØ¶ÔÒº»¯Òº¹ÞµÄѹÁ¦ºÍ²ÎÊý½øÐмà²â£¬µ±ÓÃ̽ͷºÍÆäËûµÄ·ÖÎöÒDZí¶ÔÆøÌåºÍ¹ÞÌåÖÜΧµÄÆøÌå½øÐвÉÑù»òÕß̽²âµ½ÆøÌåй¶»òÕß¼°ÆäËü°²È«Òþ»¼Ê±£¬ÏµÍ³»áÁ¢¿Ì±¨¾¯£¬Í¬Ê±Í¨¹ýIASϵͳ£¬´¥·¢°²È«Í£³µ½ô¼±¹Ø¶ÏµÄ¹¦ÄÜ£¬´Ó¶ø±£Ö¤´¬Ö»ÔÚÔËÓª¹ý³ÌÖеݲȫºÍ¿É¿¿ÐÔ£»³ý´ËÖ®Í⣬ʵʱÐԵļ¼ÊõÖ§³ÖҲΪIASϵͳµÄÕý³£ÔËÐб£¼Ý»¤º½£¬´Ó¶ø±£Ö¤´¬Ö»µÄÔËӪЧÂÊ¡£
Ϊ˳Ӧ´¬Ö»Ðͺŵı仯£¬»ôÄáΤ¶û¸ù¾Ý²»Í¬´¬Ð͸Ľø¿ØÖƲßÂÔ£¬ÒÔÌṩÊÊÒ˵Ľâ¾ö·½°¸¡£»ùÓÚLNG´¬¶øÑÔ£¬Ä¿Ç°»ôÄáΤ¶ûÌá³öµÄз½°¸¾ÍÊÇȼÁÏ»ìºÏ»òÕßÊÇȼÁϹ²ÏíµÄ·½Ê½¡£¸ù¾Ý¹Þ×ÓµÄѹÁ¦¼°ÆøÌåµÈ²ÎÊý£¬ÀûÓÃ˫ȼÁÏ·¢¶¯»úÀïÊ£ÓàµÄÆøºÍÓÍ£¬Í¨¹ýIASϵͳµÃÒÔ¿ØÖƲ¢·ÖÅ䣬ʹÕâ¸öº½Ðдﵽһ¸ö×îÓÐЧ¡¢×î¾­¼Ã»¯µÄƽºâµÄ״̬¡£ÁíÍ⣬»ôÄáΤ¶ûÌṩµÄÌØÊâ¸ôÀë²ÄÁÏ¿ÉÒÔ¸ø¹ÞÌ彵Σ¬¼õÉÙÕô·¢ÆøµÄ²úÉúÁ¿£¬ÒÔ±£Ö¤´¬Ö»µ½°¶Ê±£¬Òº»¯ÌìÈ»ÆøµÄº¬Á¿×î´ó£¬´Ó¶ø±£Ö¤ÊÕÒæ¡£
6ES7193-4CD70-0AA0    TM-P15N23-A0    Terminal Module for Power Modules    Siemens
6ES7193-4CE00-0AA0    TM-P15S22-01    Terminal Block for Power Module    Siemens
6ES7193-4CE00-1AA0        MODULE,ET200S, 5 TERM TM-P15S22-01    Siemens
6ES7193-4CE10-0AA0    TM-P15C22-01    Terminal Block for Power Modules    Siemens
6ES7193-4CE10-1AA0        MODULE,ET200S,5 TERM,TM-P15C22-01    Siemens
6ES7193-4CE60-0AA0    TM-P15N22-01    Terminal Block for Power Modules    Siemens
6ES7193-4CF40-0AA0    TM-E30S46-A1    Terminal Module    Siemens
6ES7193-4CF50-0AA0    TM-E30C46-A1    Terminal Module    Siemens
6ES7193-4CG20-0AA0    TM-E30S44-01    Terminal Module    Siemens
6ES7193-4CG30-0AA0    TM-E30C44-01    Terminal Module    Siemens
6ES7193-4CK20-0AA0    TM-P30S44-A0    Terminal Module    Siemens
6ES7193-4CK30-0AA0    TM-P30C44-A0    Terminal Module    Siemens
6ES7193-4CL20-0AA0    TM-E15S24-AT    Terminal Module    Siemens
6ES7193-4CL30-0AA0    TM-E15C24-AT    Terminal Module    Siemens
6ES7193-4DL00-0AA0    TM-C120C    Terminal Module    Siemens
6ES7193-4DL10-0AA0    TM-C120S    Terminal Module    Siemens
6ES7193-4FL00-0AA0        Additional Terminal    Siemens
6ES7193-4FL10-0AA0        Additional Terminal    Siemens
6ES7193-4GA00-0AA0        Terminal Module Shield Connecting Elements-5 Pack    Siemens
6ES7193-4GB00-0AA0        Terminal Elements-5 Pack    Siemens
6ES7193-4JA00-0AA0        Simatic DP Terminating Module ET200S    Siemens
6ES7193-4JB00-0AA0        24 VDC Plug - Package of 10    Siemens
6ES7193-4JB50-0AA0        DC Plug - 10 Pack    Siemens
6ES7193-4LA20-0AA0        Coding Plates for Terminal Modules    Siemens
6ES7193-4LB20-0AA0        Coding Plates for Terminal Modules    Siemens
6ES7193-4LC20-0AA0        Coding Plates for Terminal Modules    Siemens
6ES7193-4LD20-0AA0        Coding Plates for Terminal Modules    Siemens
6ES7193-4LF20-0AA0        Coding Plates for Terminal Modules    Siemens
6ES7193-4LG20-0AA0        Coding Plates for Terminal Modules    Siemens
6ES7193-4LH20-0AA0        Coding Plates for Terminal Modules    Siemens
6ES7193-6AF00-0AA0        SIMATIC ET 200SP,BA 2XFC    Siemens
6ES7193-6AR00-0AA0        BUS ADAPTER BA 2XRJ45    Siemens
6ES7193-6BP00-0BA0        BASE UNIT TYPE A0, BU15-P16+A0+2B    Siemens
6ES7193-6BP00-0BA1        BASE UNIT TYPE A1, BU15-P16+A0+2B/T    Siemens
6ES7193-6BP00-0BD0        BASEUNIT TYPE D0, BU20-P12+A0+0B    Siemens
6ES7193-6BP00-0DA0        BASE UNIT TYPE A0, BU15-P16+A0+2D    Siemens
6ES7193-6BP00-0DA1        BASE UNIT TYPE A1, BU15-P16+A0+2D/T    Siemens
6ES7193-6BP20-0BA0        BASE UNIT TYPE A0, BU15-P16+A10+2B    Siemens
6ES7193-6BP20-0BB0        BASEUNIT TYP B0, BU20-P12+A4+0B    Siemens
6ES7193-6BP20-0DA0        BASE UNIT TYPE A0, BU15-P16+A10+2D    Siemens
6ES7193-6BP20-0DC0        BASEUNIT TYP C0, BU20-P6+A2+4D    Siemens
6ES7193-6BP40-0BA1        BASE UNIT TYPE A1, BU15-P16+A0+12B/T    Siemens
6ES7193-6BP40-0DA1        BASE UNIT TYPE A1, BU15-P16+A0+12D/T    Siemens
6ES7193-6CP01-2MA0        10 COLOR CODE PLATES, COLOR CODE CC01    Siemens
6ES7193-6CP02-2MA0        10 COLOR CODE PLATES, COLOR CODE CC02    Siemens
6ES7193-6CP03-2MA0        10 COLOR CODE PLATES, COLOR CODE CC03    Siemens
6ES7193-6CP81-2AB0        10 COLOR IDENTIFICATION LABELS CC81    Siemens
6ES7193-6CP82-2AB0        10 COLOR IDENTIFICATION LABELS CC82    Siemens
6ES7193-6CP83-2AB0        10 COLOR IDENTIFICATION LABELS CC83    Siemens
6ES7193-6CP84-2AC0        10 COLOR IDENTIFICATION LABELS CC84    Siemens
6ES7193-6CP85-2AC0        10 COLOR IDENTIFICATION LABELS CC85    Siemens
6ES7193-6CP86-2AC0        10 COLOR IDENTIFICATION LABELS CC86    Siemens
6ES7193-6EF00-1AA0        CODING ELEMENT,TYPE F,SPARE PART    Siemens
6ES7193-6LA10-0AA0        1000 LABELING STRIPES A4, LIGHT GREY    Siemens
6ES7193-6LA10-0AG0        1000 LABELING STRIPES A4, YELLOW    Siemens
6ES7193-6LF30-0AW0        160 EQUIPMENT IDENTIFIER PLATES    Siemens
6ES7193-6LR10-0AG0        500 LABELING STRIPES, LIGHT YELLOW    Siemens
6ES7193-6PA00-0AA0        ET200SP, SERVERMODULE    Siemens
6ES7193-6SC00-1AM0        ET200SP,5 SCHIELDING CONNECTIONS    Siemens
6ES7193-7AA00-0AA0    TM-IM/EM60S    Terminal Module    Siemens
6ES7193-7AA10-0AA0    TM-IM/EM60S    Terminal Module    Siemens
6ES7193-7AA20-0AA0    TM-IM/EM60S    Terminal Module    Siemens
6ES7193-7AB00-0AA0    TM-IM/IM    Terminal Module    Siemens
6ES7193-7BB00-0AA0        Labeling Sheets    Siemens
6ES7193-7BH00-0AA0        Labeling Sheets    Siemens
6ES7193-7CA00-0AA0    TM-EM/EM60S    Terminal Module    Siemens
6ES7193-7CA10-0AA0    TM-EM/EM60C    Terminal Module    Siemens
6ES7193-7CA20-0AA0    TM-EM/EM60S    Terminal Module    Siemens
6ES7193-7CB00-0AA0    TM-RM/RM    Terminal Module    Siemens
6ES7193-7DA10-0AA0    TM-RM/RM    Terminal Module    Siemens
6ES7193-7DA20-0AA0    TM-PS-A    Terminal Module    Siemens
6ES7193-7DB10-0AA0    TM-PS-B    Terminal Module    Siemens
6ES7193-7DB20-0AA0    TM-PS-B    Terminal Module    Siemens
6ES7193-8LA00-0AA0    BT200    Charger for BT200 Bus Tester - 230 VAC    Siemens
6ES7193-8LB00-0AA0    BT200    Charger for BT200 Bus Tester - 110VAC    Siemens
6ES7194-1AA01-0XA0        Base Connector ET200X    Siemens
6ES7194-1FC00-0XA0        ET 200X Plug Connector    Siemens
6ES7194-1JB10-0XA0        SIMATIC DP, DISTRIBUTED I/O ET    Siemens
6ES7194-1KA01-0XA0        ET200X Y Connector 5pin.    Siemens
6ES7194-1KB00-0XA0        Connector    Siemens
6ES7194-3AA00-0AA0        BLOCK CONNECT ECOFAST ET200ECO ADDR SET    Siemens
6ES7194-3AA00-0BA0        Connecting Block    Siemens
6ES7194-3JA00-0AA0        PLUG BLANK 7/8" SIMATIC DP ET200ECO,10PK    Siemens
6ES7194-4AA00-0AA0        SIMATIC DP,CON MOD FOR ET 200PRO    Siemens
6ES7194-4AB00-0AA0        CONNECTOR,M12,COMPENSATION,PT1000    Siemens
6ES7194-4AC00-0AA0        SIMATIC DP, CONNECTING MODULE FOR PROFIB    Siemens
6ES7194-4AD00-0AA0        Simatic DP Connecting Module    Siemens
6ES7194-4AF00-0AA0        ET200PRO, CM IM PN 2XRJ45    Siemens
6ES7194-4AJ00-0AA0        ET200PRO, CM IM PN M12 7/8"    Siemens
6ES7194-4AN00-0AA0        ET200PRO, CM IM-CPU PN/DP M12 / 7/8"    Siemens
6ES7194-4BA00-0AA0        SIMATIC DP,CON MOD FOR PM-E ET 200PRO    Siemens
6ES7194-4BC00-0AA0        SIMATIC DP,CON MOD FOR ET 200PRO    Siemens
6ES7194-4BD00-0AA0        SIMATIC DP,CON MOD FOR PM-E ET 200PRO    Siemens
6ES7194-4BE00-0AA0        ET200PRO, CM PM-E PP    Siemens
6ES7194-4BH00-0AA0        ET200PRO, CM PM-O PP    Siemens
6ES7194-4CA00-0AA0        SIMATIC DP, CONNECTING MODULE FOR DIGITA    Siemens
6ES7194-4CA10-0AA0        ET200PRO, CM IO 4 X M12 P    Siemens
6ES7194-4CA50-0AA0        ET200PRO, CM IO 4 X M12 INVERS    Siemens
6ES7194-4CB00-0AA0        SIMATIC DP, CONNECTING MDULE FOR DIGITAL    Siemens
6ES7194-4CB10-0AA0        ET200PRO, CM IO 8 X M12 P    Siemens
6ES7194-4CB50-0AA0        MODULE,CONNECTING,16DI,24VDC,ET200PRO    Siemens
6ES7194-4DA00-0AA0        ET200PRO,CM IO 2 X M12    Siemens
6ES7194-4DC00-0AA0        SIMATIC DP, ET200PRO CONNECTING MODULE    Siemens
6ES7194-4DD00-0AA0        SIMATIC DP,ET200PRO,CONN MOD FOR FAILSAF    Siemens
6ES7194-4EB00-0AA0        ET200PRO,CM IO 8 X M8    Siemens
6ES7194-4FA00-0AA0        SIMATIC DP,CON MOD FOR ET 200PRO    Siemens
6ES7194-4FB00-0AA0        ET200PRO,CM IO 2 X M12, 8 PIN    Siemens
6ES7194-4GA00-0AA0        Simatic Module Rack    Siemens
6ES7194-4GA20-0AA0        SIMATIC DP, COMPACT NARROW 2000MM    Siemens
6ES7194-4GA20-0XA0    S KXR4    Simatic Module Rack    Siemens
6ES7194-4GA60-0AA0        ET200PRO, MOD. CARRIER, NARROW, L:1000MM    Siemens
6ES7194-4GB00-0AA0        SIMATIC DP, MODULE CARRIER WIDE,500MM    Siemens
6ES7194-4GB20-0AA0        SIMATIC DP,MODULE CARRIER WIDE,2000MM    Siemens
6ES7194-4GB60-0AA0        ET200PRO, MOD. CARRIER, WIDE, L:1000MM    Siemens
6ES7194-4GC20-0AA0        BLOCK CONNECT ECOFAST ET200ECO ADDR SET    Siemens
6ES7194-4GC60-0AA0        ET200PRO, MOD. CARRIER, COMPACT,L:1000MM    Siemens
6ES7194-4GC70-0AA0        ET200PRO, MOD. CARRIER, COMPACT,L:500MM    Siemens
6ES7194-4GD00-0AA0        ET200PRO, MOD. CARRIER, COMPACT, L:500MM    Siemens
6ES7194-4GD10-0AA0        ET200PRO, MOD. CARRIER, COMPACT,L:1000MM    Siemens
6ES7194-4HA00-0AA0        SIMATIC DP, MODULE LABELS FOR ET 200PRO    Siemens
6ES7194-4HB00-0AA0        SIMATIC DP,FUSES 12.5A,FOR ET 200PRO    Siemens
6ES7194-4JA50-0AA0        ET200PRO,CAPS FOR PUSH PULL SOCKETS,5PCS    Siemens
6ES7194-4JD50-0AA0        ET200PRO,CAPS FOR PUSH PULL SOCKETS,5PCS    Siemens
6ES7194-4JD60-0AA0        ET 200PRO,BLANK PLUG M12 INSIDE TH, 5PCS    Siemens
6ES7194-4MA00-0AA0        ET200PRO, ANTENNA IM 154-6 PN HF IWLAN    Siemens
6ES7194-6CA00-0AA0        TERMINAL BLOCK FOR ET200ECO PN    Siemens
6ES7194-6GA00-0AA0        MOUNTING BAR FOR ET200ECO PN    Siemens
6ES7194-6HB00-0AA0        REPLACEMENT FUSE TERMINAL BLOCK,10PCS    Siemens
6ES7194-6KA00-0XA0        ET200, Y CABLE    Siemens
6ES7194-6MA00-0AA0        SELF-TAPPING SCREW FOR ET200ECO PN    Siemens
6ES7195-1BE00-0XA0        Simplex Connector Adaptor - Package of 50    Siemens
6ES7195-1GA00-0XA0        Rail for ET200M - 483MM    Siemens
6ES7195-1GC00-0XA0        RAIL FOR BUS MODULES ET200M INS/REM 2M    Siemens
6ES7195-1GF30-0XA0        DIN Rail Rack - 530 MM    Siemens
6ES7195-1GG30-0XA0        RAIL FOR BUS MODS ET200M INS/REM 620MM    Siemens
6ES7195-1JA00-0XA0        COVER BACKPLANE BUS ET200M    Siemens
6ES7195-1KA00-0XA0        ARDWARE EXPLOSION-PROOF PARTITN ET200M    Siemens
6ES7195-3BF02-0YA0        PROFISAFE-STARTERKIT V3.4    Siemens
6ES7195-7BA00-0XB0        Profibus Module    Siemens
6ES7195-7HA00-0XA0        Bus Module    Siemens
6ES7195-7HB00-0XA0        Bus Module    Siemens
6ES7195-7HC00-0XA0        ET200M Bus Unit    Siemens
6ES7195-7HD00-0XA0        Bus Unit for Redundancy    Siemens
6ES7195-7HD10-0XA0        Bus Unit for Redundancy    Siemens
6ES7195-7HD80-0XA0        Profibus Bus Unit for IM157 DPV1    Siemens
6ES7195-7HF80-0XA0        DP/PA Bus Module    Siemens
6ES7195-7HG00-0XA0        MODULE SEPARATOR BUS ET200M F/SAFETY    Siemens
6ES7195-7HG80-0XA0        Profibus Bus Unit for IM157 DPV1    Siemens
6ES7195-7KF00-0XA0        Separator Module    Siemens
6ES7197-1LA04-0XA0        Y-LINK F. CONNECT. OF 1CHANNEL DP-SLAVES    Siemens
6ES7197-1LA11-0XA0        Y-LINK for Connecting 1-Channel DP-Slaves    Siemens
6ES7197-1LB00-0XA0        Y-Coupler Module    Siemens
6ES7211-0AA21-0XB0    CPU221    CPU 221 Module    Siemens
6ES7211-0AA23-0XB0    CPU 221    CPU 221 Compact Unit    Siemens
6ES7211-0BA20-0XB0    CPU 221    CPU 221 Module    Siemens
6ES7211-0BA21-0XB0    CPU 221    CPU 221    Siemens
6ES7211-0BA22-0XB0    CPU 221    CPU 221    Siemens
6ES7211-0BA23-0XB0    CPU 221    CPU 221 Compact Unit    Siemens
6ES7211-1AD30-0XB0    CPU1211C    CPU 1211C Compact CPU    Siemens
6ES7211-1AE31-0XB0    CPU1211C    Compact CPU 1211C    Siemens
6ES7211-1BD30-0XB0    CPU1211C    CPU 1211C Compact CPU    Siemens
6ES7211-1BE31-0XB0        CPU 1211C, AC/DC/RELAY, 6DI/4DO/2AI    Siemens
6ES7211-1HD30-0XB0    CPU1211C    CPU 1211C Compact CPU    Siemens
6ES7211-1HE31-0XB0        CPU 1211C, DC/DC/RELAY, 6DI/4DO/2AI    Siemens
6ES7212-1AA01-0XB0    CPU212    CPU 212    Siemens
6ES7212-1AB21-0XB0    CPU 222    CPU 222 Compact Module    Siemens
6ES7212-1AB22-0XB0    CPU222    CPU222 Compact Unit    Siemens
6ES7212-1AB23-0XB0    CPU222    CPU222 Compact Unit    Siemens
6ES7212-1AD30-0XB0    CPU1212C    CPU 1212C Compact Unit    Siemens
6ES7212-1AE30-0XB0    CPU1212C    CPU 1212C Compact Unit    Siemens
6ES7212-1AE31-0XB0    CPU1212C    CPU 1212C Compact Unit    Siemens
6ES7212-1BA00-0XB0    CPU212    CPU 212    Siemens
6ES7212-1BA01-0XB0    CPU 212    Simatic S7-200 CPU 212    Siemens
6ES7212-1BA10-0XB0    CPU212    Simatic S7-200 CPU 212    Siemens
6ES7212-1BB21-0XB0    CPU222    CPU222    Siemens
6ES7212-1BB22-0XB0    CPU222    CPU 222 Compact Unit, AC Power Supply    Siemens
6ES7212-1BB23-0XB0    CPU222    CPU222    Siemens
6ES7212-1BD30-0XB0    CPU1212C    CPU 1212C Compact Unit    Siemens
6ES7212-1BE31-0XB0        CPU 1212C, AC/DC/RELAY, 8DI/6DO/2AI    Siemens
6ES7212-1CA00-0XB0    CPU212    Simatic S7-200 CPU 212    Siemens
6ES7212-1HD30-0XB0    CPU1212C    CPU 1212C Compact CPU    Siemens
6ES7212-1HE31-0XB0        CPU 1212C, DC/DC/RELAY, 8DI/6DO/2AI    Siemens
6ES7214-1AC00-0XB0    CPU 214    Simatic S7-200 CPU 214    Siemens
6ES7214-1AC01-0XB0    CPU 214    Simatic S7-200 CPU 214    Siemens
6ES7214-1AD21-0XB0    CPU 224    Simatic S7-200 CPU 224    Siemens
6ES7214-1AD22-0XB0    CPU 224    Simatic S7-200 CPU 224    Siemens
6ES7214-1AD23-0XB0    CPU224    CPU 224 Compact Unit    Siemens
6ES7214-1AD23-0XB8    CPU224    CPU 224 Compact Unit    Siemens
6ES7214-1AE30-0XB0    CPU1214C    CPU 1214C Compact CPU    Siemens
6ES7214-1AG31-0XB0    CPU1214C    CPU 1214C Compact CPU    Siemens
6ES7214-1BC00-0XB0    CPU214    Simatic S7-200 CPU 214    Siemens
6ES7214-1BC01-0XB0    CPU 214    Simatic S7-200 CPU 214    Siemens
6ES7214-1BC10-0XB0    CPU 214    Simatic S7-200 CPU 214    Siemens
6ES7214-1BD21-0XB0    CPU 224    Simatic S7-200 CPU 224    Siemens
6ES7214-1BD22-0XB0    CPU224    Simatic S7-200 CPU 224    Siemens
6ES7214-1BD23-0XB0    CPU 224    Simatic S7-200 CPU 224    Siemens
6ES7214-1BE30-0XB0    CPU1214C    CPU 1214C Compact CPU    Siemens
6ES7214-1BG31-0XB0    CPU 1214C    CPU 1214C Compact CPU    Siemens
6ES7214-1CC01-0XB0    CPU 214    Simatic S7-200 CPU 214    Siemens
6ES7214-1DC01-0XB0    CPU 214    Simatic S7-200 CPU 214    Siemens
¹«Ë¾Ãû³Æ£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ÏúÊÛ²¿
µç »°£º 0592 5321698 / ÕÅÃÀ·ï
ÊÖ»ú£º 18020776791
µØ Ö·£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ ÏÃÃÅ˼Ã÷Çøºþ±õ¶«Â·ºþ¹â´óÏÃ18Â¥ABµ¥Ôª
ÓÊ ±à£º 361004
Ö÷ Ò³£º http://www.zxdadsqc.com/
  • HP PGM3410R
  • Shimadzu EI-D2003M
  • Panasonic MGM-32262S
  • 653B-8-200J-2
  • SGDM-50ADA
  • 1264C62G19,1264C62G19
  • Reliance O-60053
  • CR115A19
  • Square 9998HG1£¬Square 9998HG1
  • CM902WX
