ATHENA 6000T-01FATHENA 6000T-01F
Ñз¢£º½ô¸úÊг¡ È«ÃæÉæÁÔ
´Ó×îÔçµÄÕôÆûÍÆ½ø´¬ÐÍ£¬µ½ºóÀ´Ë«È¼ÁÏÍÆ½ø¡¢´¬ÌåÔÙÒº»¯£¬ÄËÖÁ×îеÄÒýÇæÆøÌåÖ±Åçʽ·¢¶¯»ú£¬»ôÄáΤ¶ûÕë¶Ô²»Í¬´¬ÐÍÌá³ö²îÒ컯½â¾ö·½°¸£¬Õâ˵Ã÷»ôÄáΤ¶û°éËæ´¬Ð͵ķ¢Õ¹±äǨÕûºÏÏà¹ØµÄ½â¾ö·½°¸¡£Í¬Ê±£¬»ôÄáΤ¶ûÒ²ÊǽôÃÜÌù½üÓû§ÐèÇ󣬲»¶ÏµØ¿ª·¢²¢¸üиüÓÐЧµÄ½â¾ö·½°¸£¬À´Ë³Ó¦Êг¡ºÍÓû§µÄÐèÇó¡£
´ÓÆÕͨµÄ¡¢¼òµ¥Ò»µãµÄ´¬Ð͵½¸ß¸½¼ÓÖµ¡¢¸ß¿Æ¼¼µÄ´¬ÐÍ£¬»ôÄáΤ¶û¶¼ÓÐÓ¦Ó᣾ÙÀý¶øÑÔ£¬2008ÄêÖк£ÓÍFPSOµÄÏîÄ¿ÖÐ80%ÒÔÉÏÓÉ»ôÄáΤ¶ûÀ´³ÐÀ¿£»²¢ÇÒ£¬»ôÄáΤ¶ûÕë¶ÔÓ͹޴¬ºÍ»õ´¬ÌṩÔËÊ伯Á¿ÏµÍ³¡¢ÎªÔì´¬³§¡¢ÉîÛÚµÄÕÐÉÌÖØ¹¤´¬³§µÄ½üº£×꾮ƽ̨¼°ÑĮ̀dzº£×꾮ƽ̨µÄ¸¨Öúƽ̨ÌṩIASϵͳ£¬²¢¸ù¾Ý²»Í¬µÄ»·¾³¶ÔÏàӦϵͳµÄÓ²¼þ¼°Èí¼þ½øÐиÄÁ¼¡£³ýÔÚ´¬ÉÏ¡¢º£Ê·½ÃæÓ¦ÓÃÒÔÍ⣬»ôÄáΤ¶ûµÄ²úÆ·ÔÚ½µØÉϵÄLNGµÄ½Ó´¥Õ¾ÒÔ¼°»¯¹¤³§¶¼ÓÐÓ¦Óá£
6062NZ10300 6062NZ10300A Archive Streaming Tape Drive -150 MB ABB
6063NZ10100 540 MB SCSI Disk Drive ABB
6063NZ10200 2 GB SCSI Disk Drive ABB
6063NZ10300 SCSI Disk Drive for ABB
6063NZ10400B SCSI Disk Drive for ABB
6063NZ10500 SCSI Disk Drive - 9 GB ABB
6063NZ10600 SCSI Disk Drive -36 GB ABB
6064NZ10000 SCSI DAT Drive ABB
6064NZ10100 SCSI DAT Drive ABB
6067CZ00010 MFM Disk Controller Cable ABB
6069BZ10000 DCN Interface Module ABB
6070NZ10000 6070NZ10000D Floppy Disk Drive - 5 1/4 inch ABB
6073NZ10000A 3.5 Inch Floppy Drive ABB
61002774 YPK113A UART Communication Module ABB
6100BZ10010 MP84188T-PGA, 6100BZ10010A, Analog Input Module ABB
6101BZ10010 MP8418T-EXP Analog Input Expander Module ABB
6102BZ10111 MV/TC Analog Input Module - 10 MV ABB
6102BZ10121 MV/TC Input Module - 20 mV ABB
6102BZ10131 MV/TC Input Module - 50 MV ABB
6102BZ10131B Thermocouple Input Module ABB
6105BZ10130 RTD Input Module ABB
61063404 Hand Held Control Panel ABB
6106BZ10010 Pulse Input Module ABB
6107BZ10010 Digital I/O Module ABB
6108BZ10060 Analog Output Module ABB
61411-0-4199656 6.414475.9 Digitiic P Controller
61411-0-4699922 Digitric P Digitric P Control Unit
61415-0-1699950 6.417617.6, Digitric P Digitric P
61511-0-4000002 CM1, 6.561563.3 Contronic CM1 ABB
6151NB10700 Interface Module Chassis -117 Vac ABB
6152NA10700 Power Distribution Panel ABB
6152NB10700 AC Power Distribution Panel ABB
6152NZ10700 AC Distribution Panel ABB
6153NB10700 Remote Interface Module Chassis ABB
6154BZ10121 TC Signal Conditioning Module ABB
6154BZ10141 6154BZ10141A Thermocouple Module ABB
6154BZ10991A Thermocouple Transmitter Module ABB
6155BZ10110 RTD Signal Conditioning Module ABB
6155BZ10990A SC8372 RTD Transmitter Module ABB
6157NZ10000 DC Power Distribution Panel ABB
61615-0-1200000 6.420102.0 Digitric 500 Panel Controller ABB
6200CP00015 IC660BLC001, 6200CP00015A TRIO Interconnect Cable - 15 inch ABB
6200CP00036 IC660BLC003 TRIO Interconnect Cable - 36 inch ABB
6200DP10800 IC660HHM501 Hand Held Monitor ABB
6202CZ00010A SC CPU to VT Interface Cable ABB
6202FP00075 IC660BLM508 Bus Terminator 75 Ohm ABB
6202FP00150A IC660BLM506 Bus Terminator - 150 Ohm (IC660BLM506) ABB
6202NZ10000 SC Controller Card File - Rack ABB
6203BZ10000 SC F-Bus Interface Module ABB
6203FP10800 IC660BSM021, 6203FP10800A Bus Switching Module 24/48Vdc ABB
6203FP10900 IC660BSM120 Bus Switching Module 115Vac/125Vdc ABB
6204BZ10100 AA P194016 SC Controller CPU Module ABB
6205BZ10000 SC D/F Module ABB
6208FZ00000A SC Power Supply Mounting Tray ABB
6211FZ00000 Blank Plate - I/O Interface Module ABB
6211FZ00000A Blank Plate, I/O INT Mod ABB
6213FZ00000 6213FZ00000A Blank Faceplate ABB
6214BZ10110 SC Backup Memory Module - 8MB ABB
6214BZ10120 Backup Memory Module 4 MEG ABB
6214BZ10121 SC Backup Memory Module 4 MEG ABB
6215BZ10000 CB P192030 SC I/O Transfer Module ABB
6215FZ10100 6215FZ10100B SC Controller Fan Assembly - 117 Vac ABB
6216BZ10000 SC I/O Extender Module ABB
6220BZ10701 SS TRIO ABB
6220BZ10721 SS TRIO ABB
6224NZ10800 Power Supply 110-240VAC, 50/60HZ ABB
6225BZ10000 SC Backup Memory Extender Module ABB
6226BZ10000 SC Direct I/O Module ABB
6226NZ10400 ABB Slot Power Supply ABB
6226NZ10400C P192078 Controller SC Slot Power Supply ABB
6227BZ10100 SC Controller Field Bus Module 1-Ch ABB
6227BZ10200 SC Controller Field Bus Module 2-Ch ABB
6228BZ10000 Multibus Fieldbus Module ABB
6229BZ10100 Multibus Field Bus Interface Module ABB
6229BZ10200 SC Field Bus Interface Module ABB
6229BZ10200B 109S1761 SC Controller Field Bus Interface ABB
6230BP10710 IC660BBA100 Analog Block ABB 124
6230BP10720 IC660EBA100 Electronic Assembly for 6230BP10710 ABB
6230BP10730 IC660TSA100 Terminal Assembly for 6230BP10710 ABB
6230BP10810 IC660BBA020 Block 24/48Vdc Analog 4 Inputs / 2 Outputs ABB
6230BP10820 IC660EBA020 Electronic Assembly for 6230BP10810 ABB
6230BP10830 IC660TSA020 Terminal Assembly for 6230BP10810 ABB
6230FP10800 IC660BSM021 Bus Switching Module 24/48Vdc ABB
6231BP10810 IC660BBA024 Block - Analog Current Source 4 Inputs / 2 Outputs ABB
6231BP10830 IC660TBA024 Terminal Assembly for 6231BP10810 ABB
6231BP10910 IC660BBA104 Block - Analog Current Source 4 Inputs / 2 Outputs ABB
6231BP10920 IC660EBA100 Electronic Assembly for 6231BP10920 ABB
6231BP10930 IC660TSA100 Terminal Assembly for 6231BP10910 ABB
6232BP10710 IC660BBA103 Block 115Vac/125Vdc Thermocouple Input 6 Channels ABB
6232BP10720 IC660EBA103 Electronic Assembly for 6232BP10710 ABB
6232BP10730 IC660TBA103 Terminal Assembly for 6232BP10710 ABB
6232BP10810 IC660BBA023 Block 24/48Vdc Thermocouple Input 6 Channels ABB
6232BP10820 IC660EBA023 Electronic Assembly for 6232BP10810. ABB
6232BP10830 IC660TBA023 Terminal Assembly for 6232BP10810 ABB
6233BP10810 IC660BBA021 RTD Block ABB
6233BP10820 IC660EBA021 RTD Electronic Assembly ABB
6233BP10830 IC660TBA021 RTD Terminal Assembly ABB
6233BP10910 IC660BBA101 TRIO Block 115Vac/125Vdc RTD ABB
6233BP10920 IC660EBA101 RTD Electronic Assembly ABB
6233BP10930 IC660TBA101 Terminal Assembly for 6233BP10910 ABB
6234BP10910 IC660BBD120 Block High Speed Counter ABB
6234BP10920 IC660EBD120 Electronic Assembly for 6234BP10910 ABB
6234BP10930 IC660TBD120 Terminal Assembly for 6234BP10910 ABB
6235BP10810 IC660BBA026 Block 24/48Vdc Analog Current Source 6 Inputs ABB
6235BP10820 IC660EBA026 Electronic Assembly for 6235BP10810 ABB
6235BP10830 IC660TBA026 Terminal Assembly for 6235BP10810 ABB
6235BP10910 IC660BBA106 Current Source Analog Input ABB
6235BP10920 IC660EBA106 Electronic Assembly for 6235BP10910 ABB
6235BP10930 IC660TBA106 Terminal Assembly for 6235BP10910 ABB
6236BP10810 IC660BBA025 Block 24/48Vdc Analog Current Source 6 Outputs ABB
6236BP10820 IC660EBA025 Electronic Assembly for 6236BP10810 ABB
6236BP10830 IC660TBA025 Terminal Assembly for 6236BP10810 ABB
6236BP10910 IC660BBA105 Block 115Vac/125Vdc Analog Current Source GE - General Electric
6236BP10920 IC660EBA105 Electronic Assembly for 6236BP10910 ABB
6236BP10930 IC660TBA105 Terminal Assembly for 6236BP10910 ABB
6240BP10411 IC660BBD022 Block - Source I/O 16 Circuits ABB
6240BP10412 IC660BBD023 Block 24Vdc Sink I/O 16 Circuits ABB
6240BP10421 IC660EBD022 Electronic Assembly for 6240BP10411 ABB
6240BP10422 IC660EBD023 Electronic Assembly for 6240BP10412 ABB
6240BP10431 IC660TBD022 Terminal Assembly for 6240BP10411 ABB
