Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú CM902WL I/A£¬CM902WL I/A
²úÆ·Ãû³Æ£º CM902WL I/A£¬CM902WL I/A
ÐÍ ºÅ£º CM902WL I/A£¬CM902WL I/A
δÀ´£º°²È«»·±£ ³ÖÐø¿É¿¿
Foxboro CM902WL I/AFoxboro CM902WL I/A
LNG´¬ÐͳÖÐøµÄ±äǨ²¢¸Ä½øÊÇ»ùÓÚ³§É̶ÔÓÚ°²È«ºÍ»·±£µÄÒªÇó£¬ÕâЩҪÇóÍÆ¶¯×Å»ôÄáΤ¶û²»¶Ï¸ÄÉÆÏµÍ³µÄÐÔÄÜͳ¼°´¬Ö»ÕûÌåÔËÊ䷽ʽ¡£¿Í»§¶ÔÓÚ²úÆ·°²È«ÐÔµÄÒªÇ󼰿ɳÖÐø·¢Õ¹µÄ˼ÏëÔÚÄÔº£ÖиùÉîµÙ¹Ì£¬²úÆ·Óëʱ¾ã½øµØ²»¶Ï¸ÄÁ¼Ò²ÊÇØ½´ý½â¾öµÄÎÊÌâ¡£ÕýËùν“¶Àľ²»³ÉÁÖ”£¬ÈôÏëÍê³ÉÕâÒ»Ô¸¾°£¬»ôÄáΤ¶ûÔÚδÀ´½«»á¼ÓǿͬӲ¼þ¹©Ó¦É̺ʹ¬³§µÄ½ôÃܺÏ×÷£¬¾Í»á¸Ä½øÆäÏÖÓеÄIASϵͳ£¬À´Âú×ãÐµĻ·±£ºÍ°²È«µÄÒªÇó£¬Í¬Ê±°ïÖú¿Í»§½øÐÐÏàÓ¦µÄÓ²¼þÑ¡ÐÍ£¬Ê¹ÐÂÐ͵ÄLNG´¬¿ÉÒÔÂú×ãµ±ÏµĻ·±£ÒªÇó¡£
LNG´¬²ÉȡȫÇò»¯ÔËÐÐģʽ£¬´¬ÉϵĻõÎï¼ÛÖµ²»·Æ£¬Èôϵͳ¿É¿¿ÐÔ²»¹»Ç¿£¬´¬µÄº½ÐÐÑÓÎ󣬽«»áÔì³ÉÎÞ·¨¹ÀÁ¿µÄËðʧ£¬Òò´Ë¿É¿¿ÐԺͿɳÖÐøÐÔΪ¿Í»§×îÎªÖØÊÓµÄÐÐÒµÃüÂöËùÔÚ¡£»ôÄáΤ¶ûÕû¸öϵͳµÄ¿É¿¿ÐÔÆÄΪҵ½çÓû§ËùÇàíù£¬¾ßÓнÏÇ¿¾ºÕùÁ¦¡£³ý´ËÖ®Í⣬»ôÄáΤ¶û¾ßÓб鲼ȫÇòµÄ¹¤³ÌʦºÍ¼¼ÊõÍŶӽøÐм¼ÊõÖ§³Ö£¬²¢±£Ö¤×ã¹»µÄÈËÁ¦¿É½øÐÐÊÊʱµØÊۺ󱸼þµÄ±¸»»»òÆäËûµÄά»¤·þÎñ£¬Òò´Ë¿ÉÒÔ¼õÉÙº½°àµÄÑÓÎó¡£
Ö±ÃæÖйúµÄLNGÊг¡µÄÀ©ÕÅÌ¬ÊÆ£¬»ôÄáΤ¶û¸øÓèºÜ¸ßµÄÆÚÍû£¬ÖйúµÄ´¬ÒµÎñ¹æÄ£Ò²»áÖð½¥×öÇ¿£¬»ôÄáΤ¶ûÔÚδÀ´½«Ö²¸ùÖйúÊг¡£¬´Ó¶øÎª¿Í»§Ìṩ¸ü¼ÓÊÊÒ˵Ľâ¾ö·½°¸¡£
6ES7954-8LF00-0AA0        S7 MEMORY CARD, 24 MB    Siemens
6ES7954-8LF01-0AA0        Memory Card - 24 MB    Siemens
6ES7954-8LP01-0AA0        SIMATIC S7 MEMORY CARD, 2 GB    Siemens
6ES7960-1AA00-0XA0    IF 960-HF    IF 960-HF Synchronization Module for S7-400H    Siemens
6ES7960-1AA00-5AA0        Patch Cable - 1M    Siemens
6ES7960-1AA04-0XA0        Sync Submodule for Patch Cable    Siemens
6ES7960-1AA04-5AA0        Patch Cable - 1M    Siemens
6ES7960-1AA04-5BA0        FO Patch Cable for Sync Module -2M    Siemens
6ES7960-1AA04-5KA0        FO Patch Cable for Sync Module -10 M    Siemens
6ES7960-1AA06-0XA0        S7 SYNC-MOD. V6 F. S7-400H/F/FH    Siemens
6ES7960-1AB04-0XA0        Sync Module    Siemens
6ES7960-1AB06-0XA0        ASM_OTHER_SYNCHRONISIERUNGS-MODUL V6    Siemens
6ES7961-1AA00-0AC0    F 961    IF 961 DIGITAL I/O    Siemens
6ES7961-2AA00-0AC0    IF961-AIO    IF961 Analog I/O    Siemens
6ES7961-3AA00-0AC0    IF961-AIO    Analog I/O Interface Module    Siemens
6ES7962-1BA00-0AC0    IF962-VGA    IF962-VGA Interface Module    Siemens
6ES7962-1BA01-0AC0    IF962-VGA    IF962-VGA Interface Module    Siemens
6ES7962-3AA00-0AC0    IF962-COM    IF962-COM Interface Module RS232    Siemens
6ES7962-4AA00-0AC0    IF962-LPT    IF962-LPT Interface Module    Siemens
6ES7963-1AA00-0AA0    IF963-RS232    Interface Module IF963-RS232    Siemens
6ES7963-1AA10-0AA0        INTERFACE MODULE IF963-RS232/CP 441    Siemens
6ES7963-2AA00-0AA0    IF963-TTY    Interface Module IF963-TTY    Siemens
6ES7963-3AA00-0AA0    IF963-X27    Interface Module IF963-X27    Siemens
6ES7963-3AA10-0AA0        INTERFACE MODULE IF963 RS422/CP 441    Siemens
6ES7964-2AA00-0AB0    IF964-DP    IF964-DP Profibus Interface Module    Siemens
6ES7964-2AA01-0AB0    IF964-DP    IF964 Interface Sub-Module -DP Master    Siemens
6ES7964-2AA04-0AB0    IF964-DP    IF964 Interface Sub-Module -DP Master    Siemens
6ES7971-0BA00        Back Up Battery    Siemens
6ES7971-1AA00-0AA0        Battery 3.6 Volt    Siemens
6ES7971-2BA00-0AA0        Battery for WinAC Slot PC Module    Siemens
6ES7971-5BB00-0AA0        Rechargeable Battery for Real-Time Clock Backup    Siemens
6ES7972-0AA00-0XA0        RS-485 Repeater    Siemens
6ES7972-0AA01-0XA0        Repeater Module RS485    Siemens
6ES7972-0AA02-0XA0        Repeater Module RS4855    Siemens
6ES7972-0AB01-0XA0        Diagnose-Repeater for Profibus DP    Siemens
6ES7972-0AC80-0XA0        RS485-IS Coupler    Siemens
6ES7972-0BA10-0XA0        SINEC-L2 Bus Connector    Siemens
6ES7972-0BA11-0XA0    H7 L4 4147/C    90 Degree Profibus Connector    Siemens
6ES7972-0BA12-0XA0        Profibus Connector    Siemens
6ES7972-0BA20-0XA0        Profibus Connector    Siemens
6ES7972-0BA30-0XA0        Profibus Connector    Siemens
6ES7972-0BA40-0XA0        Profibus Connector    Siemens
6ES7972-0BA41-0XA0        Profibus Connector    Siemens
6ES7972-0BA42-0XA0        Profibus Connector    Siemens
6ES7972-0BA50-0XA0        Profibus Connector    Siemens
6ES7972-0BA51-0XA0        Profibus Connector    Siemens
6ES7972-0BA52-0XA0        Profibus Connector    Siemens
6ES7972-0BA52-0XB0        PB CONNECTOR, 90 DEGREE, W/O PG SOCKET    Siemens
6ES7972-0BA60-0XA0        Profibus Connector -35 Degree    Siemens
6ES7972-0BA70-0XA0        CONNECTOR PROFI, 90 DEG, W/O PG SOCKET    Siemens
6ES7972-0BB10-0XA0        Profibus Connector -90 Degree    Siemens
6ES7972-0BB11-0XA0        Profibus Connector -90 Degree    Siemens
6ES7972-0BB12-0XA0        Profibus Connector - 90 Degree    Siemens
6ES7972-0BB20-0XA0        Profibus Connector    Siemens
6ES7972-0BB40-0XA0        Profibus Connector - 45 Degree    Siemens
6ES7972-0BB41-0XA0        Profibus Connector - 45 Degree    Siemens
6ES7972-0BB42-0XA0        Profibus Connector - 45 Degree    Siemens
6ES7972-0BB50-0XA0        Profibus Connector    Siemens
6ES7972-0BB51-0XA0        Profibus Connector    Siemens
6ES7972-0BB52-0XA0        Profibus Connector    Siemens
6ES7972-0BB60-0XA0        Profibus Connector - 35 Degree    Siemens
6ES7972-0BB70-0XA0        PB CONNECTOR, 90 DEGREE, WITH PG SOCKET    Siemens
6ES7972-0CA00-0XA0        External Power Supply Set for USB PC Adaptor    Siemens
6ES7972-0CA11-0XA0        HMI Adaptor    Siemens
6ES7972-0CA21-0XA0        PC Adapter    Siemens
6ES7972-0CA22-0XA0        PC Adapter (serial conforming to MPI)    Siemens
6ES7972-0CA23-0XA0        PC Adapter (serial conforming to MPI)    Siemens
6ES7972-0CA33-0XA0        Teleservice Adapter Cable    Siemens
6ES7972-0CA34-0XA0        Teleservice Adapter Cable    Siemens
6ES7972-0CB20-0XA0        SIMATIC PC Adapter USB    Siemens
6ES7972-0CB35-0XA0        TS Adapter II for Simatic Teleservice    Siemens
6ES7972-0CC35-0XA0        Teleservice Adaptor II ISDN    Siemens
6ES7972-0DA00-0AA0        Profibus Terminator 24V    Siemens
6ES7972-0DA60-0XA0        Profibus Connector    Siemens
6ES7972-0EB00-0XA0        TS ADAPTER IE BASIC SIMATIC TELESERVICE    Siemens
6ES7972-0ED00-0XA0        TS-ADAPTER IE ISDN SIMATIC TELESERVICE    Siemens
6ES7972-0EM00-0XA0        TS-ADAPTER IE ANALOG SIMATIC TELESERVICE    Siemens
6ES7972-0MD00-0XA0        S7,TS MODULE ISDN SIMATIC TELESERVICE    Siemens
6ES7972-0MM00-0XA0        S7,TS MODULE MODEM SIMATIC TELESERVICE    Siemens
6ES7972-0MS00-0XA0        S7,TS MODULE RS232 SIMATIC TELESERVICE    Siemens
6ES7972-4AA00-0XA0        Power Rail Booster Signal Amplifier    Siemens
6ES7972-4AA02-0XA0        Simatic Power Rail Booster    Siemens
6ES7972-4AA50-0XA0        SIMATIC DP, PRB SEGMENT CONTROLLER, AUTO    Siemens
6ES7973-1HD00-0AA0        FUSE SET SM322 10 FUSE 8A, 2 FUSE HLDRS    Siemens
6ES7973-1HD10-0AA0        FUSE SPARE KIT S7400 DIO 422-5EH00-0AB0    Siemens
6ES7974-0AA00-0AA0        MODULE MEAS RANGE S7400 ANALOG IN 2PK    Siemens
6ES7998-8XC01-8YE0        MANUAL CD-ROM COLLECTION 5 LANG    Siemens
6ES7998-8XC01-8YE2        MANUAL UPD 1YR CD-ROM COLLECTION 5 LANG    Siemens
6EW1881-8AA    A5E00167497    Power Supply    Siemens
6FC5263-0AA03-0AB0        SIN.840D/810D EDIT FM WIND FM353/354/357    Siemens
6FC5263-1AA03-5AB0        EDIT-FM 6FC5263-1AA03-5AB0    Siemens
6GK1140-1AA00    CP1401    CP1401 Communication Module    Siemens
6GK1501-1AA00        Simatic L2FO Interface Module    Siemens
6GK1561-1AM00    CP5611    Profibuse Interface Module Kit    Siemens
6GK1571-1AA00-0AD0        USB-CONNECTING CABLE FOR CP 5711    Siemens
6GK1704-0AA06-3AA0        SOFTWARE SIMATIC NET UPG 11/02    Siemens
6GK1704-1PW33-3AA0        SOFTWARE SOFTNET-PG NT4.0,2K V3.3    Siemens
6GK1706-0HB63-3AA0        SIMATIC NET IE PN CBA OPCSERVER/2005,WXP    Siemens
6GK1706-1NW61-3AA0        SOFTWARE SNMP OPC SERV 20IP    Siemens
6GK1706-1NX61-3AA0        SOFTWARE SNMP OPC SERV 200 IP    Siemens
6GK1713-5CB21-3AA0        S7 5613/WIN NT4.0-V2.1(R)    Siemens
6GK1716-0HB61-3AA4        SOFTWARE S7-REDCONNECT UPG V6.0    Siemens
6GK1716-1TB61-3AA0        SOFTWARE TF-1613 V6.1    Siemens
6GK1781-1BA01-1AA0        SW,SINEMA SERVER BASIC 50 V11    Siemens
6GK1781-1DA01-1AA0        SW,SINEMA SERVER BASIC 100 V11    Siemens
6GK1781-1HA01-1AA0        SW,SINEMA SERVER BASIC 250 V11    Siemens
6GK7242-2AX00-0XA0    CP242-2    Simatic Net, CP 242-2    Siemens
6GK7242-8dp00-0XA0    CP242-8    Simatic Net, CP 242-8    Siemens
6GK7243-1EX00-0XE0    CP243-1    CP243-1 Communications Processor    Siemens
6GK7243-1EX01-0XE0    CP243-1    CP243-1 Communications Processor    Siemens
6GK7243-1GX00-0XE0    CP 243-1IT    CP243-1IT Communications Processor    Siemens
6GK7243-2AX01-0XA0    CP243-2    CP 243-2 AS-Interface Master    Siemens
6GK7277-1AA10-0AA0    CSM1277    CSM 1277 Compact Switch Module    Siemens
6GK7342-2AH00-0XA0    CP 342-2    CP342-2 AS Interface Module    Siemens
6GK7342-2AH01-0XA0    CP342-2    CP342-2 AS-I Communication Module    Siemens
6GK7342-5DA00-0XE0    CP342-5    CP342-5 Profibus Communications Module    Siemens
6GK7342-5DA01-0XE0    CP 342-5    CP 342-5 Profibus Communications Processor    Siemens
6GK7342-5DA02-0XE0    CP 342-5    CP 342-5 Profibus Communications Processor    Siemens
6GK7342-5DA03-0XE0    CP 342-5    CP 342-5 Profibus Communications Processor    Siemens
6GK7342-5DF00-0XE0    CP342-5 FO    CP342-5 FO Communications Processor    Siemens
6GK7343-1BA00-0XE0    CP343-1    CP343-1 Ethernet Module    Siemens
6GK7343-1CX00-0XE0    CP343-1    CP343-1 Ethernet Module    Siemens
6GK7343-1CX10-0XE0    CP343-1    CP343-1 Ethernet Module    Siemens
6GK7343-1EX00-0XE0    CP 343-1    CP 343-1 Ethernet Communication Module    Siemens
6GK7343-1EX10-0XE0    CP 343-1    CP 343-1 TCP COM    Siemens
6GK7343-1EX11-0XE0    CP 343-1    CP 343-1 Ethernet Communication Module    Siemens
6GK7343-1EX20-0XE0    CP 343-1    CP 343-1 Ethernet Module    Siemens
6GK7343-1EX21-0XE0    CP 343-1    CP 343-1 Ethernet Module    Siemens
6GK7343-1EX30-0XE0    CP 343-1    CP 343-1 Ethernet Module    Siemens
6GK7343-1FX00-0XE0    CP343-1 ERPC    CP343-1 ERPC Communications Processor    Siemens
6GK7343-1GX00-0XE0    CP 343-1    CP343-1 Industrial Ethernet Module    Siemens
6GK7343-1GX11-0XE0    CP 343-1    CP343-1 Industrial Ethernet Module    Siemens
6GK7343-1GX20-0XE0    CP 343-1    CP 343-1 Advanced Communications Processor    Siemens
6GK7343-1GX21-0XE0    CP 343-1    CP 343-1 Advanced Communications Processor    Siemens
6GK7343-1GX30-0XE0    CP 343-1    CP 343-1 Advanced Communications Processor    Siemens
6GK7343-1HX00-0XE0    CP 343-1    Communications Processor CP343-1    Siemens
6GK7343-2AH00-0XA0    CP343-2    CP 343-2 AS Communication Module    Siemens
6GK7343-2AH01-0XA0    CP343-2    CP 343-2 AS Communication Module    Siemens
6GK7343-2AH10-0XA0    CP343-2    CP343-2 ASI Communication Module    Siemens
6GK7343-2AH11-0XA0    CP343-2    CP343-2 ASI Communication Module    Siemens
6GK7343-5FA00-0XE0    CP343-5    CP 343-5 Profibus Communications Processor    Siemens
6GK7343-5FA01-0XE0    CP 343-5    CP 343-5 Profibus    Siemens
6GK7377-1AA00-0AA0    CSM377    CSM 377 Compact Switch Module    Siemens
6GK7443-1BX00-0XE0    CP443-1    CP443-1 Ethernet Module    Siemens
6GK7443-1BX01-0XE0    CP443-1    CP443-1 Ethernet Module    Siemens
6GK7443-1EX00-0XE0    CP443-1    CP443-1 Ethernet Module    Siemens
6GK7443-1EX01-0XE0    CP443-1    CP443-1 Ethernet Module    Siemens
6GK7443-1EX02-0XE0    CP 443-1    CP 443-1 TCP Communication Processor    Siemens
6GK7443-1EX10-0XE0    CP443-1    CP443-1 Industrial Ethernet Module    Siemens
6GK7443-1EX11-0XE0    CP443-1    CP443-1 Industrial Ethernet Module    Siemens
6GK7443-1EX20-0XE0    CP443-1    CP443-1 Communications Processor    Siemens
6GK7443-1EX40-0XE0    CP443-1    CP443-1 Communications Processor    Siemens
6GK7443-1EX41-0XE0    CP 443-1    CP 443-1 Advanced Communications Processor    Siemens
6GK7443-1GX11-0XE0    CP443-1    Communication Processor CP443-1    Siemens
6GK7443-1GX20-0XE0    CP443-1    Communication Processor CP443-1    Siemens
6GK7443-5DX00-0XE0    CP 443-5    CP 443-5 Extended    Siemens
6GK7443-5DX01-0XE0    CP 443-5    CP 443-5 Extended    Siemens
6GK7443-5DX02-0XE0    CP443-5    CP443-5 Profibus Module    Siemens
6GK7443-5DX03-0XE0    CP 443-5    Communication Module CP 443-5 Extended    Siemens
6GK7443-5DX04-0XE0    CP 443-5    Communication Module CP 443-5 Extended    Siemens
6GK7443-5DX05-0XE0    CP 443-5 EXT    Communication Module CP 443-5 Extended    Siemens
6GK7443-5FX00-0XE0    CP443-5    CP443-5 Profibus Communication Module    Siemens
6GK7443-5FX01-0XE0    CP443-5    CP443-5 Profibus Module    Siemens
6GK7443-5FX02-0XE0    CP 443-5    CP443-5 Basic Communications Processer    Siemens
6GK7830-1BA01-0YA0        NCM S7 (V3.X) FOR IND ETHERNET(O)    Siemens
6GT2002-0HD00        RFID Communication Module    Siemens
6GT2002-1HD00        RFID Communication Module    Siemens
6MD1021-0AA00    705 65 249    Digital Input Module    Siemens
6NH7997-0CA50-0AA0        SOFTWARE,SINAUT ST7,SW ST7 09/2009    Siemens
6NH7997-0CA51-0AA0        SINAUT ST7,SW ST7,V5.1    Siemens
6NH7997-0CA52-0AA0        SOFTWARE,SINAUT ST7, SW ST7    Siemens
6NH7997-0CA52-0GA0        SOFTWARE,SINAUT ES V5.2 UPGRADE,WIN03    Siemens
9AC9102-0AA00    IF961-AO8    IF961-AO8 Module    Siemens
9AC9102-0AA01    IF961-ENC4    IF961-ENC4 Module    Siemens
9AE4100-1AA10    C79459-A1299-A1    SIMBA Profibus Simulation Module    Siemens
9AE4100-1BA10    C79459-A1299-A1    SIMBA Profibus Simulation Module    Siemens
A5E00086045        COMPUTER SERIAL PORT ADAPTERS G/C    Siemens
A5E00166133        RUBBER FOOT SET, SIMATIC PG    Siemens
A5E00294876    PBT-GF30-FR    ET200pro 1 Slot Rack Mount    Siemens
A5E00361266    PBT-GF30-FR    ET200pro 2 Slot Rack Mount    Siemens
A5E00462109A    PBT-GF30    ET200pro End Connector    Siemens
A5E00749366        TOUCHPAD FOR FIELD PG    Siemens
A5E00753961        BATTERY BOX    Siemens
A5E00995501    PBT-GF30-FR    ET200pro 1 Slot Rack Mount    Siemens
A5E01018199        Replacement Fan    Siemens    6
A5E01672409        CABLE,DISPLAY,FPG M3/M4    Siemens
A5E02237594        DVI-VGA-ADAPTER,FPG M3    Siemens
A5E02262034        INDICATOR BOARD, FPG M3 SPARE PART    Siemens
A5E02262046        HDD SLIDE IN FIELD PG M3    Siemens
A5E02262070        DISPLAY LID COMPLETE,SPARE PART    Siemens
A5E02572425        FLEX CABLE OPT. DRIVE, PG M3    Siemens
A5E02916222        COVER,RUBBER USB/RJ11,PG M3, 20PCS    Siemens
A5E02916227        COVER MEMORY CARD, FPG M3    Siemens
A5E02916228        SPRING,DISPLAY LOCKING SLIDER,FPG M3,20P    Siemens
A5E02916231        DISPLAY BRAKES,FPG M3    Siemens
A5E02916233        ASSEMBLY DISPLAY PARTS (PLASTICS)    Siemens
A5E02944871        HANDLE FOR FIELD PG M3    Siemens
A5E02960734        INTERFACE COVER, 10 PCS    Siemens
A5E03437668        BATTERY COVER FIELD PG M3,SPARE PART    Siemens
A5E03464757        KEYBOARD MODULE COMPL. GERMAN/INT.    Siemens
¹«Ë¾Ãû³Æ£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ÏúÊÛ²¿
µç »°£º 0592 5321698 / ÕÅÃÀ·ï
ÊÖ»ú£º 18020776791
µØ Ö·£º ÏÃÃÅÖÙöδï×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾ ÏÃÃÅ˼Ã÷Çøºþ±õ¶«Â·ºþ¹â´óÏÃ18Â¥ABµ¥Ôª
ÓÊ ±à£º 361004
Ö÷ Ò³£º http://www.zxdadsqc.com/
  • HP PGM3410R
  • Shimadzu EI-D2003M
  • Panasonic MGM-32262S
  • 653B-8-200J-2
  • SGDM-50ADA
  • 1264C62G19,1264C62G19
  • Reliance O-60053
  • CR115A19
  • Square 9998HG1£¬Square 9998HG1
  • CM902WX
