MTS 400679C MTS 400679C
³É³¤ÖлãÄá¿Ë
“»ãÄá¿ËµÄ¶¨Î»¾ÍÊÇ×ö¹¤¿Ø²úÆ·´úÀí£¬ÃæÏòÖйúÉ豸³§É̔ǮÕܾü˵¡£1998Äê³õ£¬Ç®Õܾü´´Á¢¹ãÖÝ»ãÄá¿Ë£¬²¢½«Ä¿¹â¾ÛÖ®ÓÚÈÕϵ¹¤¿Ø²úÆ·¡£ÔÚËû¿´À´£¬ÈÕϵ¹¤¿Ø²úÆ·ÔÚ²úÆ·Éè¼ÆµÈ·½Ãæ¸üΪ·ûºÏÖйúÓû§µ±Ê±µÄʹÓÃϰ¹ß¡£
ÔÚ»ãÄá¿Ë³ÉÁ¢Ö®³õ£¬Ç®ÕܾüÑ¡Ôñ´úÀíÈÕ±¾ÈýÁâÆ·ÅÆµÄPLC¼°±äƵÆ÷¡£ÔÚ¾½üÒ»ÄêµÄÊг¡ÍØÕ¹ºó£¬Ç®ÕܾüÒâʶµ½µ±Ê±µÄÖйúÊг¡ÈýÁâ´úÀíÉÌÖڶ࣬Êг¡¾ºÕù¼¤ÁÒ£¬¶øÀûÈó¿Õ¼äÓÐÏÞ¡£Óë´Ëͬʱ£¬ËÉϵĴúÀíÈ´ÔÚÖйú¸Õ¸ÕÆð²½£¬½öÔÚÈ«¹ú±±ÉϹãµÈÒ»Ïß³ÇÊÐÓÐÆä´úÀíÉÌ¡£ÔÚ»ãÄá¿Ë³ÉÁ¢µÚÒ»Ä꣬ǮÕܾüƾÆä¶Ôµ±Ê±Êг¡Çé¿öÚÏÊ죬¹û¶Ï¸ü»»´úÀíÆ·ÅÆ¡£1998Äêµ×£¬»ãÄá¿ËÓëËÉÏÂÇ©¶©´úÀíÐÒ飬´úÀíËÉÏÂ±äÆµÆ÷¡¢PLC¡¢´«¸ÐÆ÷¡£´ÓÄÇʱÆð£¬»ãÄá¿ËÕýʽ³ÉΪËÉÏ´úÀíÉÌ¡£´ÓËÉϵÍѹ¶¨Ê±Æ÷¡¢½ÓÊÕÆ÷µÈµÍѹԪÆ÷¼þ¿ªÊ¼£¬µ½PLC¡¢±äƵÆ÷¡¢´«¸ÐÆ÷£¨ÉñÊÓ£©£¬ÖÁ½ñ»ãÄá¿ËÒѳÉΪËÉϵÄA¼¶´úÀíÉÌ¡£
2004Ä꣬»ãÄá¿Ë·¢Õ¹ÔâÓöÆ¿¾±¡£Ç®ÕܾüÓÚÀ§¾³Öм°Ê±Á¦ÍØÒµÎñ·¢Õ¹·½Ïò£¬»ãÄá¿ËÓÚµ±Äê½Ó´¥ÊýÏÔÒÇÆ÷ÒDZíÊг¡µÄʵÁ¦Æ·ÅÆ-ºìʨ£¬Ëæºó³ÉΪÆäÔÚÖйúµÄ×î´ó´úÀíÉÌ£¬´úÀíÆäµçѹ±í¡¢µçÁ÷±í¡¢ÏÔʾÆ÷µÈÊýÏÔÒÇ±í£¬ÕâÒ²Ðû¸æ»ãÄá¿ËÕýÊ½Éæ×ãÏÔʾÒÇÆ÷ÒDZíÒµÎñ¡£
6FX2003-5AE02 CONTACT FEMALE 500 PER BAG. Siemens
6FX2003-5AE05 Fem.Contact for Sub-D Conn. Siemens
6FX2003-7AX00 MOUNTING FLANGE - CONNECT SZ 3 VERS 2004 Siemens
6FX2003-7BX00 MOUNTING FLANGE F. CONN Siemens
6FX2003-7CX00 FLANGE FOR POWER PLUG, SZ1.5 Siemens
6FX2003-7DX00 MOUNTING FLANGE F. SIGNAL CABLE Siemens
6FX2003-7FX00 CLAMP,HF,MOUNTING, F/ SIG_PWR_CBL,SIZ-1 Siemens
6FX2003-7GX00 HF CLAMP FOR PWR CONN, PWR CONN SZ 1.5 Siemens
6FX2003-7HX00 MOUNTING FLANGE M17/ SIZE 0.5 Siemens
6FX2003-7KB20 SOCKET CONTACTS 0.14-0.5 SQMM (20pcs) Siemens
6FX2003-7KS20 MALE CONTACTS 0.14 - 0.5 SQMM (20pcs) Siemens
6FX2003-7LB00 SOCKET CONTACTS 1.0-2.5 MM2 Siemens
6FX2003-7LB10 SOCKET CONTACTS 1.5-4.0 MM2,SZ 1.5,10PCS Siemens
6FX2003-7LB20 SOCKET CONTACTS 6 - 16 MM2,SZ 1.5,10PCS Siemens
6FX2003-7LS00 PIN CONTACTS 1.0-2.5 MM2,SZ1,10pcs Siemens
6FX2003-7LS10 PIN CONTACTS 1.5-4.0 MM2,SZ1,10PCS Siemens
6FX2003-7LS20 PIN CONTACTS 6-16 MM2,SZ 1.5, 10PCS Siemens
6FX2003-7LS30 PIN CONTACTS 1-2.5 MM2,SZ 1.5,10PCS Siemens
6FX2003-8LB10 SOCKET- CONTACTS,SZ=3,5XP/C,10SQMM.3XBKE Siemens
6FX2003-8LB16 SET OF SOCKET CONTACTS SIZE 3, 5PCS Siemens
6FX2003-8LB25 SET OF CONTACTS,SIZE3,5X25MM,3X1-2.5MM Siemens
6FX2003-8LB35 SOCKET CONTACTS, POWER CONN SIZE 3 Siemens
6FX2003-8LB50 SET OF SOCKET CONTACTS,PWR CONNECT SZ3 Siemens
6FX2003-8LS10 SET OF PIN CONTACTS,SZ 3 Siemens
6FX2003-8LS16 SET OF PIN CONTACTS FOR POWR CONN SIZE 3 Siemens
6FX2003-8LS25 SET OF PIN CONTACTS, SIZE 3 Siemens
6FX2003-8LS35 SET OF PIN CONTACTS Siemens
6FX2003-8LS50 SET OF PIN CONTACTS Siemens
6FX2006-1BA01 Connector Siemens
6FX2008-1DC00-1FA0 SIGNAL CABLE,NON-TRAILING,50M Siemens
6FX5002--2AH0-0-1BJ0 PREFAB,CABLE,ROD,STD,SHLD,18M Siemens
6FX5002--2AH0-0-1CC0 PREFAB,CABLE,ROD,STD,SHLD,22M Siemens
6FX5002--2CA3-1-1CB0 SIGNAL CABLE, PREASSEMBLED, Siemens
6FX5002--2CA3-1-2AA0 PREFAB,CABLE,ERN,STD,SHLD,100M Siemens
6FX5002--2DC1-0-1CJ0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,28M Siemens
6FX5002--2DC1-0-1DA0 SIGNAL CABLE,PREFAB,MC500,30M Siemens
6FX5002--2DC1-0-1DC0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,32M Siemens
6FX5002--2DC1-0-1DE0 CABLE,SIGNAL,PREFAB,MC500,34M Siemens
6FX5002--2DC1-0-1DG0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,36M Siemens
6FX5002--2DC1-0-1DJ0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,38M Siemens
6FX5002--2DC1-0-1EA0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,40M Siemens
6FX5002--2DC1-0-1EE0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,44M Siemens
6FX5002--2DC1-0-1FA0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,50M Siemens
6FX5002--5CA0-1-1CB0 PREFAB,PWRCB,4X1.5C,MC 500,21M Siemens
6FX5002--5CA3-1-1AE0 PREFAB,PWRCB,SZ1.5,MC 500,4M Siemens
6FX5002--5CA4-1-1CA0 PREFAB,PWRCB,SZ1.5,MC 500,20M Siemens
6FX5002--5CS0-1-1AG0 PREFAB,PWRCB,4X1.5C,MC 500,6M Siemens
6FX5002--5CS0-1-1AJ0 CABLE,POWER,PREFAB,4X1.5C,MC 500,8M Siemens
6FX5002--5CS0-1-1DA0 PREFAB,PWRCB,SZ1.5MM,MC 500,30M Siemens
6FX5002--5CS0-1-1DC0 PREFAB,PWRCB,SZ1.5MM,MC 500,32M Siemens
6FX5002--5CS0-1-1DE0 PREFAB,PWRCB,SZ1.5,MC 500,34M Siemens
6FX5002--5CS0-1-1DG0 PREFAB,PWRCB,SZ1.5MM,MC 500,36M Siemens
6FX5002--5CS0-1-1DJ0 PREFAB,PWRCB,MC 500,38M Siemens
6FX5002--5CS0-1-1EA0 PREFAB,PWRCB,SZ1.5MM,MC 500,40M Siemens
6FX5002--5CS0-1-1ED0 PREFAB,PWRCB,SZ1.5MM,MC 500,43M Siemens
6FX5002--5CS0-1-1EE0 PREFAB,PWRCB,SZ1.5MM,MC 500,44M Siemens
6FX5002--5CS0-2-1BA0 PREFAB,PWRCB,SZ1.5,MC500,10M Siemens
6FX5002--5CS0-2-1CA0 PREFAB,PWRCB,4X1.5 C,20M Siemens
6FX5002--5CS0-2-1CF0 PREFAB,PWRCB,SZ1.5,MC 500,25M Siemens
6FX5002--5CS1-2-1CA0 PREFAB,PWRCB,4X2.5 C,20M Siemens
6FX5002--5CS4-2-1DK0 D-CLiQ CABLE,IP20/67-PREFAB,w24V,STD,39M Siemens
6FX5002--5CS6-2-1FA0 PREFAB,PWRCB,4X10C,MC 500,50M Siemens
6FX5002--5DA0-1-2AA0 PREFAB,PWRCB,STD,SZ1,100M Siemens
6FX5002--5DA1-1-1BA0 PREFAB,PWRCB,STD,SZ1,SHLD,BRK,10M Siemens
6FX5002--5DA2-3-1BA0 PREFAB,PWRCB,STD,SZ3,SHLD,BRK,10M Siemens
6FX5002--5DS2-1-1BA0 PREFAB,PWRCB,STD,SZ1.5,SHIELD,10M Siemens
6FX5002-1AA00-1AF0 SIGNAL CABLE 5M PREASSEMBLED Siemens
6FX5002-1AA02-1AB0 SIGNAL CABLE,PREFAB,1M Siemens
6FX5002-1AA02-1AD0 SIGNAL CABLE 3M Siemens
6FX5002-1AA02-1AF0 SIGNAL CABLE 5M PREASSEMBLED Siemens
6FX5002-1AA02-1AG0 SIGNAL CABLE 6M PREASSEMBLED Siemens
6FX5002-2AD00-1AF0 SIGNAL CABLE,PREFAB,MC500,5M Siemens
6FX5002-2AD00-1AJ0 SIGNAL CABLE,PREFAB,MC500,8M Siemens
6FX5002-2AD00-1BA0 PREFAB,SIGCB,DMC,SHLD,10M Siemens
6FX5002-2AD00-1BC0 SIGNAL CABLE,PREFAB,MC500,12M Siemens
6FX5002-2AD00-1BF0 PREFAB,SIGCB,DMC,SHLD,15M Siemens
6FX5002-2AD04-1AA5 SIGNAL CABLE,PREFAB,MC500,0.5M Siemens
6FX5002-2AD04-1AB0 CABLE,SIGNAL,PREFAB,MC500, 1M Siemens
6FX5002-2AD04-1AD0 SIGNAL CABLE,PREFAB,MC500,3M Siemens
6FX5002-2AD04-1AF0 PREFAB,SIGCB,DMC,SHLD,5M Siemens
6FX5002-2AD04-1DD0 SIGNAL CABLE, PREASSEMBLED,EXT.,33M Siemens
6FX5002-2AD04-1EC0 POWER CABLE,PREFAB,MC500,40M Siemens
6FX5002-2AD04-1ED0 POWER CABLE,PREFAB,MC500,40M Siemens
6FX5002-2AD04-1EG0 POWER CABLE,PREFAB,MC500,40M Siemens
6FX5002-2AH00-1AB0 PREFAB,CABLE,ROD 431,STD,SHLD,1M Siemens
6FX5002-2AH00-1AC0 SIGNAL CABLE,PREFAB,MC500,2M Siemens
6FX5002-2AH00-1AD0 SIGNAL CABLE,PREFAB,MC500,3M Siemens
6FX5002-2AH00-1AE0 SIGNAL CABLE,PREFAB,MC500,4M Siemens
6FX5002-2AH00-1AF0 PREFAB,CABLE,ROD,STD,SHLD,5M Siemens
6FX5002-2AH00-1AJ0 PREFAB,CABLE,ROD,STD,SHLD,8M Siemens
6FX5002-2AH00-1BA0 PREFAB,CABLE,ROD,STD,SHLD,10M Siemens
6FX5002-2AH00-1BB0 SIGNAL CABLE,PREFAB,MC500,11M Siemens
6FX5002-2AH00-1BC0 SIGNAL CABLE,PREFAB,MC500,12M Siemens
6FX5002-2AH00-1BE0 SIGNAL CABLE,PREFAB,MC500,14M Siemens
6FX5002-2AH00-1BF0 PREFAB,CABLE,ROD,STD,SHLD,15M Siemens
6FX5002-2AH00-1BG0 SIGNAL CABLE,PREFAB,MC500,16M Siemens
6FX5002-2AH00-1BK0 SIGNAL CABLE,PREFAB,MC500,19M Siemens
6FX5002-2AH00-1CA0 PREFAB,CABLE,ROD,STD,SHLD,20M Siemens
6FX5002-2AH00-1CB0 SIGNAL CABLE,PREFAB,MC500,21M Siemens
6FX5002-2AH00-1CD0 SIGNAL CABLE, PREFABRICATED (ROD 431 MAS Siemens
6FX5002-2AH00-1CF0 PREFAB,CABLE,ROD,STD,SHLD,25M Siemens
6FX5002-2AH00-1CK0 SIGNAL CABLE,PREFAB,MC500,29M Siemens
6FX5002-2AH00-1DA0 PREFAB,CABLE,ROD,STD,SHLD,30M Siemens
6FX5002-2AH00-1DE0 SIGNAL CABLE,PREFAB,MC500,34M Siemens
6FX5002-2AH00-1DF0 PREFAB,CABLE,ROD,STD,SHLD,35M Siemens
6FX5002-2AH00-1DH0 SIGNAL CABLE,PREFAB,MC500,37M Siemens
6FX5002-2AH00-1EA0 PREFAB,CABLE,ROD,STD,SHLD,40M Siemens
6FX5002-2AH00-1EB0 SIGNAL CABLE,PREFAB,MC500,41M Siemens
6FX5002-2AH00-1EF0 PREFAB,CABLE,ROD,STD,SHLD,45M Siemens
6FX5002-2AH00-1EK0 PREFAB,SIGCB,ROD,STD,SHLD,49M Siemens
6FX5002-2AH00-1FA0 PREFAB,CABLE,ROD,STD,SHLD,50M Siemens
6FX5002-2AH00-1FF0 PREFAB,SIGCB,ROD,STD,SHLD,55M Siemens
6FX5002-2AH00-1FJ0 SIGNAL CABLE,PREFAB,MC500,58M Siemens
6FX5002-2AH00-1GA0 SIGNAL CABLE,PREFAB,MC500,60M Siemens
6FX5002-2AH00-1HA0 PREFAB,CABLE,ROD 431 ,MC 500,70M Siemens
6FX5002-2AH00-1HF0 PREFAB,SIGCB,ROD,STD,SHLD,75M Siemens
6FX5002-2AH00-1HG0 PREFAB,SIGCB,ROD,STD,SHLD,76M Siemens
6FX5002-2AH00-1HJ0 PREFAB,SIGCB,ROD,STD,SHLD,78M Siemens
6FX5002-2AH00-1JA1 PREFAB,SIGCB,ROD,STD,SHLD,80M Siemens
6FX5002-2AH00-1KA0 PREFAB,CABLE,SIGNAL,ROD 431,90M Siemens
6FX5002-2AH00-1KC0 PREFAB,SIGCB,ROD,STD,SHLD,76M Siemens
6FX5002-2AH00-1KF0 PREFAB,CABLE,SIGNAL,ROD 431,90M Siemens
6FX5002-2AH00-2AA0 SIGNAL CABLE,PREFAB,MC500,100M Siemens
6FX5002-2AH00-2AJ0 PREFAB,SIGCB,ROD,STD,SHLD,108M Siemens
6FX5002-2AH00-2BA0 SIGNAL CABLE,PREFAB,MC500,110M Siemens
6FX5002-2AH00-2CA0 CABLE,SIGNAL,PREFAB,MC500,DMAX9.3MM,120M Siemens
6FX5002-2AH00-2CC0 PREFAB,SIGCB,ROD,STD,SHLD,122M Siemens
6FX5002-2AH00-2FA0 CABLE,SIGNAL,PREFAB,MC500,150M Siemens
6FX5002-2AH00-2JD0 PREFAB,SIGCB,ROD,STD,SHLD,183M Siemens
6FX5002-2AH04-1AF0 SIGNAL CABLE,PREFAB,5M Siemens
6FX5002-2AH04-1AJ0 SIGNAL CABLE,PREFAB,8M Siemens
6FX5002-2AH04-1BD0 SIGNAL CABLE,PREFAB,13M Siemens
6FX5002-2AH04-1BF0 SIGNAL CABLE,PREFAB,15M Siemens
6FX5002-2AH11-1BA0 SIGNAL CABLE,PREFAB,TRAILING, MC800,10M Siemens
6FX5002-2AH11-1BF0 SIGNAL CABLE,PREFAB,TRAILING, MC800,10M Siemens
6FX5002-2AH11-1CA0 SIGNAL CABLE,PREFAB,TRAILING,MC800,20M Siemens
6FX5002-2AH11-1CF0 SIGNAL CABLE PREFAB,MC800,TRAILING,25M Siemens
6FX5002-2AH11-1EA0 SIGNAL CABLE,PREFAB,TRAILING,MC800,40M Siemens
6FX5002-2AH11-1HA0 SIGNAL CABLE,PREFAB,TRAILING,MC800,70M Siemens
6FX5002-2AL00-1CA0 SIGNAL CABLE,PREFAB,MC500,20M Siemens
6FX5002-2CA11-1AC0 SIGNAL CABLE,PREFAB,MC500,2M Siemens
6FX5002-2CA11-1AE0 PREFAB,PWRCB,STD,ENC,SHLD,4M Siemens
6FX5002-2CA11-1AF0 SIGNAL CABLE,PREFAB,MC500,5M Siemens
6FX5002-2CA11-1BA0 SIGNAL CABLE,PREFAB,MC500,10M Siemens
6FX5002-2CA11-1BF0 SIGNAL CABLE,PREFAB,MC500,15M Siemens
6FX5002-2CA11-1CA0 SIGNAL CABLE,PREFAB,MC500,20M Siemens
6FX5002-2CA11-1CF0 SIGNAL CABLE,PREFAB,MC500,25M Siemens
6FX5002-2CA12-1AC0 CABLE HTL AND TTL ENCODER SIMOVERT 2M Siemens
6FX5002-2CA12-1AD0 CABLE HTL AND TTL ENCODER SIMOVERT (3M) Siemens
6FX5002-2CA12-1AF0 CABLE HTL AND TTL ENCODER SIMOVERT (5M) Siemens
6FX5002-2CA12-1AG0 SIGNAL CABLE,PREFAB,MC500,6M Siemens
6FX5002-2CA12-1BA0 CABLE HTL/TTL ENCODER SIMOVERT (10M) Siemens
6FX5002-2CA12-1CA0 SIGNAL CABLE,PREFAB,MC500,20M Siemens
6FX5002-2CA12-1CD0 SIGNAL CABLE,PREFAB,MC500,23M Siemens
6FX5002-2CA12-1CF0 SIGNAL CABLE,PREFAB,MC500,25M Siemens
6FX5002-2CA12-1DD0 SIGNAL CABLE,PREFAB,MC500,33M Siemens
6FX5002-2CA12-1DF0 SIGNAL CABLE,PREFAB,MC500,35M Siemens
6FX5002-2CA12-1EA0 SIGNAL CABLE,PREFAB,MC500,40M Siemens
6FX5002-2CA12-1HF0 SIGNAL CABLE, PREFAB,MC500,70M Siemens
6FX5002-2CA12-2BA0 SIGNAL CABLE,PREFAB,MC500,110M Siemens
6FX5002-2CA15-1CF0 SIGNAL CABLE,PREFAB,MC500,25M Siemens
6FX5002-2CA20-1AB0 SIGNAL CABLE,PREFAB,MC500,1M Siemens
6FX5002-2CA20-1AC0 SIGNAL CABLE,PREFAB,MC500,2M Siemens
6FX5002-2CA20-1AD0 SIGNAL CABLE,PREFAB,MC500,3M Siemens
6FX5002-2CA20-1AF0 SIGNAL CABLE,PREFAB,MC500,5M Siemens
6FX5002-2CA20-1BA0 SIGNAL CABLE,PREFAB,MC500,10M Siemens
6FX5002-2CA20-1BF0 CABLE,SIGNAL,PREFAB,DMAX=9.9MM,MC500,15M Siemens
6FX5002-2CA20-1BJ0 SIGNAL CABLE,PREFAB,MC500,18M Siemens
6FX5002-2CA20-1CF0 SIGNAL CABLE,PREFAB,MC500,25M Siemens
6FX5002-2CA20-1CJ0 SIGNAL CABLE,PREFAB,MC500,28M Siemens
6FX5002-2CA20-1DA0 SIGNAL CABLE,PREFAB,MC500,30M Siemens
6FX5002-2CA24-1AF0 SIGNAL CABLE,PREFAB,M17,5M Siemens
6FX5002-2CA31-1AB0 PREFAB,CABLE,ENC,STD,SHLD,1M Siemens
6FX5002-2CA31-1AC0 PREFAB,CABLE,ERN,STD,SHLD,2M Siemens
6FX5002-2CA31-1AD0 PREFAB,PWRCB,STD,ERN,SHLD,3M Siemens
6FX5002-2CA31-1AE0 PREFAB,PWRCB,STD,ERN,SHLD,4M Siemens
6FX5002-2CA31-1AE5 SIGNAL CABLE,PREFAB,MC500,4.5M Siemens
6FX5002-2CA31-1AF0 PREFAB,CABLE,ERN,STD.,SHIELDED,5M Siemens
6FX5002-2CA31-1AG0 PREFAB,CABLE,ERN,STD,SHLD,6M Siemens
6FX5002-2CA31-1AG5 SIGNAL CABLE,PREFAB,MC500,6.5M Siemens
6FX5002-2CA31-1AH0 PREFAB,PWRCB,STD,ERN,SHLD,7M Siemens
6FX5002-2CA31-1AH5 SIGNAL CABLE,PREFAB,MC500,7.5M Siemens
6FX5002-2CA31-1AJ0 PREFAB,PWRCB,STD,ERN,SHLD,8M Siemens
6FX5002-2CA31-1AJ5 SIGNAL CABLE,PREFAB,MC500,8.5M Siemens
6FX5002-2CA31-1AK0 PREFAB,PWRCB,ENC,SHLD,9M Siemens
6FX5002-2CA31-1BA0 PREFAB,CABLE,ERN,STD.,SHIELDED,10M Siemens
6FX5002-2CA31-1BB0 CABLE,SIGNAL,PREFAB,ERN,SHLD,MC500,11M Siemens
6FX5002-2CA31-1BB5 SIGNAL CABLE,PREFAB,MC500,11.5M Siemens
6FX5002-2CA31-1BC0 SIGNAL CABLE,PREFAB,MC500,12M Siemens
6FX5002-2CA31-1BD0 SIGNAL CABLE,PREFAB,MC500,13M Siemens
6FX5002-2CA31-1BE0 SIGNAL CABLE,PREFAB,MC500,14M Siemens
6FX5002-2CA31-1BF0 PREFAB,CABLE,ERN,STD.,SHIELDED,15M Siemens
6FX5002-2CA31-1BG0 SIGNAL CABLE,PREFAB,MC500,16M Siemens
6FX5002-2CA31-1BH0 CABLE,SIGNAL,PREFAB,ERN,SHLD,MC500,17M Siemens
6FX5002-2CA31-1BJ0 PREFAB,SIGCB,ERN,STD,SHLD,18M Siemens
6FX5002-2CA31-1BK0 SIGNAL CABLE,PREFAB,MC500,19M Siemens
6FX5002-2CA31-1CA0 PREFAB,PWRCB,STD,ERN,SHLD,20M Siemens
6FX5002-2CA31-1CC0 PREFAB,SIGCB,ERN,STD,SHLD,22M Siemens
6FX5002-2CA31-1CD0 PREFAB,CABLE,ERN,STD,SHLD,23M Siemens
6FX5002-2CA31-1CE0 SIGNAL CABLE,PREFAB,MC500,24M Siemens
