²úÆ·Ìصã Product Features
- ¾¼Ã Economic Efficient
1.1ÖØÁ¿18.6kg,¿É¿ìËÙ²¿Êð/Çл» Weight 18.6kg, available for rapid deployment & changeover
1.2Õ¼µØС£¬µ××ùÖ±¾¶180mm£¬¶ÔÖܱ߻·¾³¸Ä¶¯Ð¡Small footprint, Base diameter 180mm, less changes to environment
1.3¿ÉÈÎÒâ×Ë̬°²×°Installed in any direction
1.4ÄܺĵÍÖÁ250W Power consumption 250W
1.5¸ßÐÔ¼Û±ÈMore cost-effective
1.6Ͷ×ʻر¨ÂʸßHigh ROI(return on investment)
- °²È« Safe
2.1Åöײ¼ì²â Collision Detection
2.2ÁéÃô¶È¿Éµ÷ Sensitivity adjustable.
2.3·ûºÏISO10218-1, ISO15066±ê×¼£¬Conform with ISO10218-1, ISO15066 Standard
- Ò×ÓÃ Easy-to-use
3.1¼òÒ×±à³Ì-Ç£Òýʾ½Ì£¬ Easy programming-Traction demonstration¡£
3.2TCP/IP, ModbusͨѶ£¬Ö§³ÖProfinetµÈ³£¹æ¹¤Òµ¼¶Í¨Ñ¶À©Õ¹ TCP/IP,Modbus communication protocol, support communication protocol expansion such as Profinet,CC-Link,etc.
ÔöÖµ·þÎñ Value-added Service
- רҵµÄÓ¦ÓÃÆÀ¹À Professional application evaluation
- ÆëÈ«µÄÖܱßÅä¼þ Various accessories optional
- ÍêÉƵÄÅàѵÌåϵ Complete training system
- ¼°Ê±µÄÊÛºóÏìÓ¦ Timely after-sales response
²úÆ·²ÎÊýProduct Parameters£º
ÐͺÅType
SCR3
×î´ó¸ºÔØMax Payload
3kg
×ÔÓɶÈDegree of Freedom
7
TCP×î´óËÙ¶È Max TCP speed
1m/s
¹¤×÷¿Õ¼äReach
600mm
Öظ´¶¨Î»¾«¶ÈRepeatability
±0.02mm (GB/T 12642-2013 eqv ISO 9283)
¹Ø½ÚJoint
Ô˶¯·¶Î§
Working Range
×î´óËÙ¶È
Max Speed(°/s)
J7
ÎÞÏÞÐýתInfinite rotating
180
J6
+120° to -120 °
180
J5
+180° to -180°
180
J4
+120° to -120 °
180
J3
+180° to -180 °
180
J2
+115° to -115 °
180
J1
+180° to -180°
180
¹¤¾ß½Ó¿ÚTool Interface
GB/T 14468.1-50-4-M6 (eqv ISO 9409-1)
I/O
¿ØÖƹñControl Box£º14 Dig I/O, 24V, 0.5A
Ä©¶ËEnd Joint I/O£º2 Dig I/O, 24V, 1A
ͨѶ·½Ê½
Communication Protocol
TCP/IP, MODBUS/TCP, Ö§³Ö¶àÖÖͨѶÐÒéÍØÕ¹
Support various communication protocols expansion.
µçÔ´ Power Supply
230VAC (-15%~+10%), 50-60Hz
¹¦ºÄ Power Consumption
µäÐ͹¤¿öÔ¼Typical working conditions 250W
ÍâÐγߴçRobot Dimensions
1035mm x 232mm x 202 mm
¿ØÖƹñ³ß´çControl Box Size
530mmx480mmx180mm
°²×°·½Ê½Installation
ÖõØʽ¡¢µ¹¹Òʽ¡¢Ðü±ÛʽInstalled in any direction
»·¾³Î¶È
Ambient Temperature Range
0¡æ - 45¡æ
´æ´¢Î¶È
Storage Temperature Range
-40¡æ~55¡æ
IPµÈ¼¶ IP Class
IP54
ÔëÉù Noise
≤75dB(A)
°ü×°ÐÅÏ¢(¹²2Ïä)
Package Information
£¨Total 2 packages£©
- »úÆ÷ÈË°ü×°ÏäRobot (Package 1)
- ³ß´çSize: 735mm x 635mm x 350mm
- ¾»ÖØ/ëÖØNet/Gross Weight: 18.6kg/24.5kg
- ¿ØÖÆϵͳ°ü×°Ïä Control System(Package 2)
- ³ß´çSize:735mm x 635mm x 350mm
- ¾»ÖØ/ëÖØ Net/Gross Weight: 20.5kg/29kg
