²úÆ·Ìصã Product Features
- ¾¼Ã Economic Efficient
1.1ÖØÁ¿21kg,¿É¿ìËÙ²¿Êð/Çл» Weight 21kg, available for rapid deployment & changeover
1.2Õ¼µØС120*120mm£¬¶ÔÖܱ߻·¾³¸Ä¶¯Ð¡Small footprint, 120*120mm, less changes to environment
1.3¿ÉÈÎÒâ×Ë̬°²×°Installed in any direction
1.4ÄܺĵÍÖÁ200W Power consumption 200W
1.5¸ßÐÔ¼Û±ÈMore cost-effective
1.6Ͷ×ʻر¨ÂʸßHigh ROI(return on investment)
- °²È« Safe
2.1Åöײ¼ì²â Collision Detection
2.2ÁéÃô¶È¿Éµ÷ Sensitivity adjustable.
2.3·ûºÏISO10218-1, ISO15066±ê×¼£¬Conform with ISO10218-1, ISO15066 Standard
- Ò×ÓÃ Easy-to-use
3.1¼òÒ×±à³Ì-Ç£Òýʾ½Ì£¬ Easy programming-Traction demonstration¡£
3.2TCP/IP, ModbusͨѶ£¬Ö§³ÖProfinetµÈ³£¹æ¹¤Òµ¼¶Í¨Ñ¶À©Õ¹ TCP/IP,Modbus communication protocol, support communication protocol expansion such as Profinet,CC-Link,etc.
ÔöÖµ·þÎñ Value-added Service
- רҵµÄÓ¦ÓÃÆÀ¹À Professional application evaluation
- ÆëÈ«µÄÖܱßÅä¼þ Various accessories optional
- ÍêÉƵÄÅàѵÌåϵ Complete training system
- ¼°Ê±µÄÊÛºóÏìÓ¦ Timely after-sales response
²úÆ·²ÎÊýProduct Parameters£º
ÐͺÅType
GCR5-910
×î´ó¸ºÔØMax Payload
5kg
×ÔÓɶÈDegree of Freedom
6
TCP×î´óËÙ¶È Max TCP speed
1m/s
ÖØÁ¿Weight
21kg
¹¤×÷¿Õ¼äReach
912mm
Öظ´¶¨Î»¾«¶ÈRepeatability
±0.05mm (GB/T 12642-2013 eqv ISO 9283)
¹Ø½ÚJoint
Ô˶¯·¶Î§
Working Range
×î´óËÙ¶È
Max Speed(°/s)
J6
+180° to -180°
180
J5
+180° to -180°
180
J4
+180° to -180 °
180
J3
+160° to -160 °
180
J2
+180° to -180 °
180
J1
+180° to -180 °
180
¹¤¾ß½Ó¿ÚTool Interface
GB/T 14468.1-50-4-M6 (eqv ISO 9409-1)
I/O
¿ØÖƹñControl Box£º14 Dig I/O, 24V, 0.5A
Ä©¶ËEnd Joint I/O£º2 Dig I/O, 24V, 1A
ͨѶ·½Ê½
Communication Protocol
TCP/IP, MODBUS/TCP, Ö§³Ö¶àÖÖͨѶÐÒéÍØÕ¹
Support various communication protocols expansion.
µçÔ´ Power Supply
230VAC (-15%~+10%), 50-60Hz
¹¦ºÄ Power Consumption
µäÐ͹¤¿öÔ¼Typical working conditions 200W
»úÆ÷ÈËÍâÐγߴç
Robot Dimensions
1100mm x 330mm x 200 mm
¿ØÖƹñ³ß´çControl Box Size
530mm x 480mm x 180mm
¿ØÖƹñ¾»ÖØ/ëÖØ
Control Box Net/Gross Weight
20.5kg/29kg
°²×°·½Ê½Installation
ÖõØʽ¡¢µ¹¹Òʽ¡¢Ðü±Ûʽ
»·¾³Î¶È
Ambient Temperature Range
0¡æ - 45¡æ
´æ´¢Î¶È
Storage Temperature Range
-40¡æ~55¡æ
IPµÈ¼¶ IP Class
IP54
ÔëÉù Noise
≤75dB(A)
