ÐͺÅType
GCR20-1100
ÓÐЧ¸ºÔØ Max Payload
20kg
×ÔÓÉ¶È Degree of Freedom
6
TCP×î´óËÙ¶È TCP Max Speed
1 m/s
ÓÐЧ¹¤×÷°ë¾¶ Reach
1100mm
Öظ´¶¨Î»¾«¶ÈRepeatability
±0.05mm (GB/T 12642-2013 eqv ISO 9283)
¹Ø½ÚJoint
Ô˶¯·¶Î§
Working Range
×î´óËÙ¶ÈMax Speed
J6
+180° to -180 °
160°/s
J5
+180° to -180 °
160°/s
J4
+180° to -180 °
160°/s
J3
+160° to -160 °
120°/s
J2
+180° to -180 °
120°/s
J1
+180° to -180 °
120°/s
¹¤¾ß½Ó¿Ú Tool Interface
GB/T 14468.1-50-4-M6 (eqv ISO 9409-1)
I/O
¿ØÖƹñControl Box£º14 Dig I/O, 24V, 0.5A
Ä©¶Ë End Joint£º2 Dig I/O, 24V, 1A
ͨѶ·½Ê½
Communication Protocol
TCP/IP, MODBUS/TCP, Ö§³Ö¶àÖÖͨѶÐÒéÍØÕ¹
Support various communication protocols expansion.
µçÔ´Power Supply
230VAC £¨-15%~+10%£©£¬50-60Hz
¹¦ºÄ Power Consumption
µäÐ͹¤¿öÔ¼600W
Typical power consumption 600W
»úÆ÷ÈËÍâÐγߴç
Robot Dimensions
1320mm x 420mm x 140mm
¿ØÖƹñ³ß´çControl Box Size
540mm x 510mm x 210mm
°²×°·½Ê½Installation
ÖõØʽ¡¢µ¹¹Òʽ¡¢Ðü±ÛʽInstalled in any direction
»·¾³Î¶È
Ambient Temperature Range
0¡æ - 45¡æ
´æ´¢Î¶È
Storage Temperature Range
-40¡æ~55¡æ
IPµÈ¼¶ IP Class
IP54
ÔëÉùNoise
≤75dB(A)
°ü×°ÐÅÏ¢£¨¹²2Ï䣩
Package Information
£¨Total 2 packages£©
- »úÆ÷ÈË°ü×°ÏäRobot (Package 1)
- ³ß´çSize: 1050mm x 520mm x 530mm
- ¾»ÖØ/ëÖØNet/Gross Weight: 51kg/61kg
- ¿ØÖÆϵͳ°ü×°Ïä Control System(Package2)
- ³ß´çSize:735mm x 635mm x 350mm
- ¾»ÖØ/ëÖØ Net/Gross Weight: 31kg/45kg
