ÐͺŠType
DSCR5
×î´ó¸ºÔØ Max Payload
10kg£¨5kg x 2£©
×ÔÓÉ¶È Degree of Freedom
µ¥±Û7 x 2£¬Í·²¿2£¬Í·²¿Ñ¡Åä
Each arm 7 x 2, Head 2, Head is optional
Öظ´¶¨Î»¾«¶È Repeatability
±0.02mm
¹¤×÷°ë¾¶ Reach
800mm x 2
TCP×î´óËÙ¶È TCP Max Speed
1m/s
¹Ø½ÚJoint
µ¥±ÛÔ˶¯·¶Î§
Each Arm Working Range
×î´óËÙ¶È
Max Speed(°/s)
J7
+180° to -180°
180
J6
+110° to -110 °
180
J5
+180° to -180°
180
J4
+115° to -115 °
180
J3
+180° to -180 °
180
J2
+105° to -105 °
120
J1
+180° to -180°
120
¹¤¾ß½Ó¿Ú Tool Interface
GB/T 14468.1-50-4-M6 (eqv ISO 9409-1)
µ¥±ÛÄ©¶ËI/O
Tool I/O of Each Arm
2 Dig I/O, 24V, 1A
µçÔ´Power Supply
230VAC (-15%~+10%), 50-60Hz
¹¦ºÄPower Consumption
µäÐ͹¤¿öÔ¼Typical working conditions 800W
¿ØÖÆϵͳ Control System
¼¯³ÉÔÚ»úÆ÷ÈËÄÚ²¿ Inside the robot body.
°²×°·½Ê½ Installation
¿ÉÒƶ¯Ê½ Moveable
µ¥±ÛÍâÐγߴç
Each Arm Robot Dimensions
1285mm x 220mm x 240 mm
»·¾³Î¶È
Ambient Temperature Range
0¡æ - 45¡æ
IPµÈ¼¶ IP Class
IP30
ÔëÉù Noise
≤75dB(A)
°ü×°ÐÅÏ¢Package Information
1¸öľÏä Wooden Box.
³ß´çSize:1000mm x 800mm x 1750mm(L x W x H)
¾»ÖØ/ëÖØ Net/Gross Weight:200kg/250kg
