| 系统 System |
| 处理器 Processor |
Intel® Celeron® Processor J1900 processor (2.00 GHz) |
| 内存 Memory |
1 x DDR3L 1333 MHz SDRAM Slot, up to 8GB |
| 存储 Storage |
1 x 2.5" SATA 2.0 HDD/SSD, 1 x mSATA |
| 图形 Graphics |
Intel® HD Graphics for Intel Atom® Processor Z3700 Series, dual display |
| 操作系统 OS |
Windows 7/8/10, Linux |
| 外部接口 Rear I/O |
| 网口 Ethernet |
2 x RJ45 Realtek® RTL8111E GbE (10/100/1000 Mbps) |
| 音频 Audio |
1 x Line-out |
| 显示 Video |
1 x VGA: max resolution up to 2560 x 1600
1 x HDMI: max resolution up to 1920 x 1200 |
| USB |
3 x USB 2.0, 1 x USB 3.0 |
| 串口 COM |
2 x RS232 |
| 电源 Power Connector |
1 x DC 12V Power Input Connector |
| 内部接口 Internal I/O |
| 扩展接口 Expansion |
1 x Half-size Mini-PCIe Slot |
| 环境 Environment |
| 操作温度 Operation Temp. |
-10℃ ~ 60℃(SSD), 0℃ ~ 40℃(HDD) |
| 存储温度 Storage Temp. |
-40℃ ~ 85℃ |
| 湿度 Relative Humidity |
5% ~ 95%, 非凝结状态Non-condensing |
| 振动 Vibration |
SSD: 5~500Hz, 2Grms operation
HDD: 5~500Hz, 1Grms operation |
| 机械冲击 Shock |
Operation: 10G@11ms
Non-operation: 30G@11ms |
| 电源 Power |
| 电源输入 Power Input |
12V DC |
| 适配器 Adapter |
AC-DC, 12V@5A, 60W |
| 机构 Mechanical |
| 外观 Housing |
铝合金 Aluminum Alloy |
| 尺寸 Dimension |
134 x 126 x 38 mm |
| 重量 Weight |
0.65kg |
| 安装方式 Mounting |
桌面式(Stand-Mount), VESA (75 x 75mm) |
| 认证 Certification |
| 安规认证 Safety Certification |
CE, FCC Class A |
