| ■ 产品规格 Specification |
| 系统 System |
| 处理器 Processor |
Intel® Bay Trail Celeron® J1900 processor (2.00 GHz) |
| 内存 Memory |
1 x DDR3L 1333 SODIMM Slot, up to 8GB |
| 存储 Storage |
1 x 2.5" Drive Bay for SATA HDD/SSD, 1 x mSATA |
| 图形 Graphics |
Intel® HD Graphics for Intel® Atom® Processor Z3700 Series |
| 操作系统 OS |
Windows 7/8.1/10, Linux |
| 触摸屏 Touchscreen |
| 触摸屏 Touch Type |
全平面五线电阻触摸屏 5-Wire Resistive Touch |
| 触击 Touch |
35,000,000 times |
| 显示屏 Display |
| 尺寸 Size |
17 inch |
| 分辨率 Resolution |
1280(H) x 1024(V) |
| 屏幕宽高比 Ratio |
4:3 |
| 亮度 Brightness |
250 nits |
| 可视区 Active Area |
337.92 x 270.336mm |
| LCD尺寸 Dimension |
358.5(W) x 296.5(H) x 10.5(D) |
| 可视角 Viewing Angle |
CR≥10,170°(H)/160°(V) ;CR≥5,178°(H)/170°(V) |
| 对比度 Contrast Ratio |
1000 |
| 色深 Display Color |
16.7M |
| 像素 Pixel Pitch |
0.264(H) x 0.264(V) |
| 背光 Backlight |
LED Backlight |
| 背光寿命 Backlight Lifetime |
50000Hrs |
| 功耗 Power Consumption |
8.95W |
| 机构 Mechanical |
| 前框 Front Panel |
铝 Aluminum |
| 铝挤 Heat-Sink |
铝 Aluminum |
| 底板 Rear Cover |
铁 SECC |
| 安装方式 Mounting |
Panel Mount, Wall and VESA-mount (75 x 75mm) |
| 尺寸 Dimension |
392.4(W) x 327.7(H) x 66(D)mm |
| 开孔尺寸 Cut Out |
382.2 x 317.5mm |
| 重量 Weight |
5.2kg |
| 外部接口 External I/O |
| 串口 COM |
4 x RS232 (COM1~4) |
| USB |
3 x USB 2.0, 1 x USB 3.0 |
| 网口 Ethernet |
2 x Realtek® 8111F GbE (10/100/1000 Mbps) |
| 显示 Video |
1 x VGA (up to 2560 x 1600), 1 x HDMI (up to 1920 x 1200) |
| 电源输入 Power Input |
1 x Power Connector (2P Phoenix) |
| 音频 Audio |
1 x Line-out, 1 x Mic-in |
| 内部接口 Internal I/O |
| 扩展接口 Expansion |
1 x full-size Mini-PCIe Slot (1 x Wifi/3G/4G), 1 x SIM Card Slot |
| 电源 Power |
| 电源输入 Power Input |
12V DC |
| 适配器 Adapter |
AC-DC, 12V@5A, 60W |
| 环境 Environment |
| 操作温度 Operation Temp. |
-10℃ ~ 50℃ (SSD), 0℃ ~ 40℃ (HDD) |
| 存储温度 Storage Temp. |
-40℃ ~ 70℃ |
| 湿度 Relative Humidity |
5% ~ 95%, Non-condensing |
| 随机振动 Random Vibration |
5~500Hz, 1Grms (HDD)operation, 5~500Hz, 2Grms (SSD)operation |
| 正弦振动 Sine Vibration |
5~500Hz, 2G Non-operation |
| 机械冲击 Shock |
10g 11ms operation, 30g 11ms Non-operation |
| 认证 Certification |
| 安规认证Safety Certification |
CCC |
