| 处理器 Processor |
Intel® 4th Gen. Core™ i3/i5/i7, Pentium®, Celeron® processor, LGA1150 Socket |
| 芯片Chipset |
Intel® H81 Chipset |
| 内存 Memory |
DDR3 1333/1600MHz, 2 x DIMM Slot, up to 16GB |
| 存储 Storage |
2 x SATA 2.0, 2 x SATA 3.0 |
| 图形 Graphics |
Intel® HD Graphics, dual display |
| 操作系统 OS |
Windows XP (limited function)/7/8/10, Linux |
| 外部接口 External I/O |
| 网口 Ethernet |
2 x RJ45 Realtek® RTL8111G-CG GbE (10/100/1000 Mbps) |
| 音频 Audio |
1 x Line-in, 1 x Line-out, 1 x Mic-in |
| 显示 Video |
1 x VGA: max resolution up to 1920 x 1200
1 x HDMI: max resolution up to 2560 x 1600
1 x DVI-D: max resolution up to 1920 x 1200 |
| 内部接口 Internal I/O |
| 扩展接口 Expansion |
1 x PCIe X 16 Slot, 1 x PCIe X 1 Slot, 2 x PCI Slot |
| 风扇 FAN |
1 x CPU Fan , 1 x System Fan |
| GPIO |
1 x 8-bit GPIO (optional) |
| 扬声器 Speaker |
4-pin 3W AMP Output Wafer (optional) |
| 环境 Environment |
| 操作温度 Operation Temp. |
0℃ ~ 40℃ |
| 存储温度 Storage Temp. |
-20℃ ~ 60℃ |
| 湿度 Relative Humidity |
5% ~ 95%, 非凝结状态 Non-condensing |
| 电源 Power |
| 电源输入 Power Input |
180~240V(AC) |
| 电源功耗 Power Watt |
300W |
| 机构 Mechanical |
| 外观 Housing |
SGCC |
| 尺寸 Dimension |
320(L) x 300(W) x 132(H)mm |
| 重量 Weight |
9kg(约) |
| 安装方式 Mounting |
桌面式 (Desk-Mount) |
| 认证 Certification |
| 安规认证 Safety Certification |
CCC |
| 配置 Configuration |
| 型号 Model Name |
CES-3H81-A261 |
CES-3H81-A2A0 |
| 串口 COM |
6 (5 x In-RS232, 1 x R-RS232) |
10 (2 x In-RS485/422/232, 7 x In-RS232, 1 x R-RS232) |
| USB |
8 (6 x R-USB 2.0, 2 x R-USB 3.0) |
10 (2 x In-USB 2.0, 6 x R-USB 2.0, 2 x R-USB 3.0) |
| LVDS |
0 |
1 (optional) |
| TPM |
0 |
TPM |
