| ■ 产品规格 Specification |
| 系统 System |
| 处理器 Processor |
Intel® Bay Trail Celeron® J1900 processor (2.00 GHz) |
| 内存 Memory |
1 x DDR3L 1333 SODIMM Slot, up to 8GB |
| 存储 Storage |
1 x mSATA |
| 图形 Graphics |
Intel® HD Graphics for Intel® Atom® Processor Z3700 Series |
| 操作系统 OS |
Windows 7/8.1/10, Linux |
| 触摸屏 Touchscreen |
| 触摸屏 Touch Type |
全平面五线电阻触摸屏 5-Wire Resistive Touch |
| 触击 Touch |
35,000,000 times |
| 显示屏 Display |
| 尺寸 Size |
12.1 inch |
| 分辨率 Resolution |
1024(H) x 768(V) |
| 屏幕宽高比 Ratio |
4:3 |
| 亮度 Brightness |
450 nits |
| 可视区 Active Area |
245.76(H) x 184.32(V)mm |
| LCD尺寸 Dimension |
279.0(W) x 209.0(H) x 8.6(D)mm |
| 可视角 Viewing Angle |
80°(R)/80°(L) 80°(U)/80°(D) |
| 对比度 Contrast Ratio |
700 |
| 色深 Display Color |
16.2M/262K |
| 像素 Pixel Pitch |
0.240(H) x 0.240(V) |
| 背光 Backlight |
LED Backlight |
| 背光寿命 Backlight Lifetime |
50000Hrs |
| 功耗 Power Consumption |
6.4W |
| 机构 Mechanical |
| 前框 Front Panel |
铝 Aluminum |
| 铝挤 Heat-Sink |
铝 Aluminum |
| 底板 Rear Cover |
铁 SECC |
| 安装方式 Mounting |
Panel Mount, Wall and VESA-mount (75 x 75mm) |
| 尺寸 Dimension |
307(W) x 241.6(H) x 60(D)mm |
| 开孔尺寸 Cut Out |
299 x 233.6mm |
| 重量 Weight |
2.9kg |
| 外部接口 External I/O |
| 串口 COM |
2 x RS232 (COM1~2) |
| USB |
1 x USB 2.0, 1 x USB 3.0 |
| 网口 Ethernet |
2 x Realtek® 8111F GbE (10/100/1000 Mbps) |
| 显示 Video |
1 x VGA (up to 2560 x 1600) |
| 电源输入 Power Input |
1 x Power Connector (2P Phoenix) |
| 内部接口 Internal I/O |
| 扩展接口 Expansion |
1 x full-size Mini-PCIe Slot (1 x Wifi/3G/4G), 1 x SIM Card Slot |
| 电源 Power |
| 电源输入 Power Input |
12V DC |
| 适配器 Adapter |
AC-DC, 12V@5A, 60W |
| 环境 Environment |
| 操作温度 Operation Temp. |
-10℃ ~ 60℃ (SSD) |
| 存储温度 Storage Temp. |
-40℃ ~ 70℃ |
| 湿度 Relative Humidity |
5% ~ 95%, Non-condensing |
| 随机振动 Random Vibration |
5~500Hz, 2Grms (SSD)operation |
| 正弦振动 Sine Vibration |
5~500Hz, 2G Non-operation |
| 机械冲击 Shock |
10g 11ms operation, 30g 11ms Non-operation |
| 认证 Certification |
| 安规认证Safety Certification |
CCC |
