产品名称: S7-200电池盒6ES7291-8BA20-0XA0
型  号: 6ES7291-8BA20-0XA0
价  格:
品  牌: 西门子(SIEMENS)
6ES7291-8BA20-0XA0
s7-200电池盒现货销售  6ES7291-8BA20-0XA0
Type
24 V/4 A
Order number
6EP1 332-1SH51
Input
Single-phase AC
Rated voltage Uinrated
100 V - 240 V AC wide-range input
Voltage range
85 V to 264 V AC
Overvoltage strength
2.3 x Uin rated/1.3 ms
Line buffering at Iout rated
> 40 ms at Uin = 187 V
Rated line frequency, rated line-frequency range
50/60 Hz; 47 Hz to 63 Hz
Rated current Iinrated
1.95 A - 0.97 A
Switch-on current limit (+25 °C)
< 30 A
I2t
< 2.5 A2s
Built-in line-side fuse
Internal
Recommended miniature circuit breaker (IEC 898) in the supply feeder
At and above 16 A, B characteristic or at and above 10 A, C characteristic
Output
Controlled, isolated DC voltage
Rated voltage Uoutrated
24 V DC
Total tolerance, static
±3 %
  • Static line smoothing
Approx. 0.1 %
  • Static load smoothing
Approx. 1.5 %
Ripple content
(clock frequency approx. 90 kHz)
< 200 m Vpp
Spikes (bandwidth approx. 20 MHz)
< 300 m Vpp
Adjustment range
22.2 V to 26.4 V
Operation indicator
Green LED for output voltage OK
Response on activation/deactivation
No overshoot of Uout (soft start)
Startup delay/voltage rise
< 0.5 s/typ. 35 ms
Rated current Ioutrated
4 A
Current range up to +55 °C
0 A to 4 A
Parallel switching for enhanced performance
Yes
Efficiency
Efficiency at Uoutrated, Iout rated
Typically. 89 %
Heat loss at Uoutrated, Iout rated
Typically 12 W
Control
Dynamic line smoothing
(Uin rated ±15 %)
< 0.2 % Uout
Dynamic load smoothing
(Iout: 10/90/10 %)
±1.5 % Uout
Load-step settling time
  • 10 at 90 %
Typically 20 ms
  • 90 at 10 %
Typically 20 ms
Protection and monitoring
Current limit
Typically 4.7 A
Short-circuit protection
Constant-current characteristic
Sustained-short-circuit-current rms value
< 10 A
Overload/short-circuit indicator
Security
Primary/secondary galvanic isolation
Yes, safety extra-low output voltage Uout to EN 60950 and EN 50178
Protection class
Class II (without protective conductor)
CE marking
Yes
UL/cUL (CSA) approval
Yes, cULus-listed (UL 508, CSA 22.2), file E197259; cURus-recognized (UL 60950, CSA 22.2), file E151273
FM approval
Yes, Class I Div. 2, Group A, B, C, D T4
Marine Type Approval
Yes, GL, ABS
Degree of protection (EN 60529)
IP20
EMC
Emitted interference
EN 55022 Class B
Supply-harmonics limitation
EN 61000-3-2
Noise immunity
EN 61000-6-2
Operating data
Ambient temperature range
-20 °C to +55 °C with natural convection
Transport/storage temperature range
-40 °C to +70 °C
Humidity class
Climate class 3K3 to EN 60721, no condensation
Mechanical system
Supply-input connections L1, N
Solid/finely-stranded per screw-type terminal for 0.5 mm to 2.5 mm2
Connections
  • Output +
  • Output -
Per 2 screw-type terminals for 0.5 mm to 2.5 mm2
Dimensions (W x H x D) in mm
90 x 90 x 55
Weight
Approx. 0.34 kg
Mounting
Snaps onto DIN rail DIN EN 50022-35x15/7.5
关 键 词: s7-200 s7-200电池盒
公司名称: 上海黎西机电设备有限公司
联 系 人: 方华恩
电  话: 021-60441309
手  机: 18221990375
地  址: 上海市松江区人民北路71弄22号
邮  编: 201600
S7-200TD400C(6AV6640-0AA00-0AX1)
西门子编码器6FX200(6FX2001-8BA03)
S7-200TD200两(6ES7272-0AA30-0YA1)
西门子SMART1000(6AV6648-0AF11-3AX0 6AV6648-0AE11-3AX0)
西门子CPU313C-2(6ES7313-6BF03-0AB0)
西门子CPU226(6ES7216-2AD23-0XB8)
西门子CPU319-3P(6ES7318-3EL00-0AB0)
西门子CPU314(6ES7314-1AG13-0AB0)
西门子CPU224XP(CPU224XP DC/DC/DC,14DI/10DO,2AI/1AO)
西门子CPU224(6ES7214-1AD23-0XB8)
西门子CPU317-2D(6ES7317-2AJ10-0AB0)
西门子CPU222(6ES7212-1AB23-0XB8)
西门子CPU314C-2(6ES7314-6CG03-0AB0)
西门子CPU315-2D(6ES7315-2AG10-0AB0)
西门子CPU312(6ES7312-1AE13-0AB0)
西门子PCU50.3(PCU50.3)
西门子V10变频器6SL(6SL3217-0CE21-5UA1)
西门子V10变频器6SL(6SL3217-0CE23-0UA1)
西门子V10变频器6SL(6SL3217-0CE21-1UA1)
西门子V10变频器6SL(6SL3217-0CE15-5UA1)
