产品名称: 耐震压力表
型  号: YTN-60/100/150/200/250
价  格:
YTN系列耐震压力表
YTN Series Shock Proof Pressure Meter
简介
      耐震压力表内部充灌阻尼液和配套缓冲装置,具有良好的耐震性能,适用于被测介质的压力有强烈脉冲变化或压力冲击和在生产工艺中经常突然卸荷的场合,以及环境震动较大的场所。仪表能测气体、液体脉动压力的平均值,以克服介质强烈脉冲及环境震动对仪表带来的损害,确保读数的准确性。
Brief introduction:
      Shock proof pressure meter is filled with damping liquid inside and assembled with buffering device, owning good performance of shock proof. This sort of meters is suitable for locations where the pressure of medium changes intensely and pressure shock exists, or pressure is released suddenly in the course of manufacturing, or working environment shock largely. The meter can measure fluctuating pressure average of gas and liquid mediums. Thus damage to meter induced by intensive fluctuation and environmental shock can be overcome smoothly and accuracy of reading is ensured.
构成示意图 Internal structure
主要技术参数
  • 精确度:1.6级、2.5级
  • 使用环境温度:5℃~55℃   表壳内充甘油
                        -25℃~55℃   表壳内充硅油
  • 填充工作液:a:甘油;b:硅油;c:根据用户需求填充
  • 外壳防护等级:IP65
  • 抗工作环境振动:V.H.4
Principal technical parameters
  • Accuracy:  1.6,  2.5 grades
  • Temperature of applicable environment:   5℃~55℃   with glycerin filled inside the crust-25℃~55℃   with silicon petrol filled inside the crust
  • Filled operating liquid: a:glycerol; b:silicon petrol; c:Filled into
  • according to users requirement
  • Defend grade of crust: Ip65
  • Resistant operational environmental vibration: V.H.4
型号规格 Types and specifications
型  号
Model
精确度
Accuracy
YTN-60
2.5
M14×1.5
1/4NPT;G1/4;
0~0.16;0~0.25;0~0.4;0~0.6;0~1;0~1.6;
0~2.5;0~4;0~6;0~10;0~16;0~25;0~40;0~60
YTN-60Z、ZT
YTN-100
1.6
M20×1.5
G1/2;1/2NPT
0~0.1;0~0.16;~0~0.25;0~0.4;0~0.6;0~1;
0~1.6;0~2.5;0~4;0~6;0~10;0~16;0~25;
0~40;0~60
YTN-100Z、ZT
YTN-150
YTN-150Z、ZT
YZTN-100、100ZT
1.6
M20×1.5
G1/2;1/2NPT
0~40;0~60
TZTN-150、150ZT
注:接口尺寸可按用户要求制作。 Joint dimension can be customized
外形尺寸 External dimension
备注
      当润滑脂甘油或硅油与氯、氮酸、氧化氯等强氧化剂混合时,会自发的发生化学反应,有燃烧或爆炸造成设备损坏、人员伤亡的可能。当压力表用于这些场合时均不能充润滑脂甘油或硅油,请与厂家联系,充填正确的内充油。
      充填甘油的耐震表不能在低温条件下或地区使用。
-      0.1MPa量程范围内的真空压力表,精确度应低于1%(1.6或2.5)。
Remark
      When lubricating grease glycerin or silicon oil mixed with strong oxidant, such as chlorine, nitrogen acid, and chlorine oxide, chemical reaction occurs spontaneously. In the course of reaction, combustion or explosion may cause equipment damaged or personnel injured. When pressure meters are used in such circumstances, lubricating grease glycerin or silica gel oil cannot be filled inside. Please contact with manufacturer for proper in-filled oil.
      Shockproof pressure meter filled with glycerin inside cannot be used in low temperature condition or area.
      If measure range of vacuum pressure meter is within -0.1MPa, the meters precision shall be lower than 1%
订货须知:
      订货时须注明:型号、名称、精确度等级、测量范围。如特殊要求,订货时请注明技术要求。
无锡市宜兴双华仪表有限公司    联系人:  刘丽娜             联系方式:025-52771556
关 键 词: 耐震压力表 不锈刚耐震压力表 耐震电接点压力表
公司名称: 宜兴市双华仪表有限公司南京办事处
联 系 人: 刘丽娜
电  话: 025-52771556
手  机: 18912957256
地  址: 南京市江宁区禄口大街蓝天路85号
邮  编: 214221
双针压力表(Y-60/100/150)
膜片压力表(YP-100/150)
耐震电接点压力表(YTNXC-100/150)
定位型压力表(Y-100)
膜盒压力表(YE-150)
氧气压力表(YO-60/100/150)
不锈钢膜片压力表(YPF)
卫生型隔膜压力表(YTFP-60/100/150)
电接点压力表(YX\YXC)
差压表(YCBF100/150)
电阻远传压力表(YTZ)
隔膜压力表(YTP-100/150)
精密压力表(YB-150)
防腐耐高温压力表(YTW)
差动远传压力表(YTT-150)
普通压力表(Y-60/100/150/200/250)
不锈钢膜盒压力表(YTFE100/150)
氨用压力表(YA)
安全型不锈钢压力表(YQF)
