产品名称: 差动远传压力表
型  号: YTT-150
价  格:
产品名称:
YTT-150系列差动远传压力表
YTT-150系列差动远传压力表
YTT-150 Series Differential Motion Remote Transmitting Pressure Meter
简介
      YTT-150系列差动远传压力表用于测量对铜及其合金不起腐蚀作用的液体、气体和蒸汽的压力。仪表带上阻尼器后,可测量脉动、冲击、突然卸荷介质的压力。带上隔膜部分后,可测量粘度大、有腐蚀性介质的压力。本仪表除就地进行压力指示外,还连续输出与被测压力信号成线性的4~20mA或0-10mA直流信号。可以与分别DDZ-Ⅲ电动单元组合仪表中的显示、记录、调节仪表联用,组成自动记录、调节、控制等系统。适用于石油化工、冶金、电站、轻工业等部门使用。
      YTT-150 series differential motion remote transmitting pressure meter is used for measuring pressures of liquids, gases, or vapors that do not corrode copper and its alloys. If equipped with shock damper, this meter mayalso measure
Pressures caused by pulsation, concussion, and sudden unloaded mediums. If equipped with diaphragm, it may also be used to measure pressures of such mediums with big viscosity and causticity.This instrument provides not only local pressures with indication, but also continual output of 4~20mA direct current signal with linear relationship with its testee pressure signal. It may compose automatic recording, adjustment, control, or other systems, in combination with displaying, recording, and adjusting instruments of DDZ-II electricity-powered units, applicable for applications in such departments as petroleum chemical industry, metallurgy, or light industry.
主要技术参数
  • 精确度:1.6级
  • 输出信号:4~20mA DC或0~10mA AC,二线制或四线制
  • 负载电阻:250Ω~350Ω
  • 供电电源:直流24V
  • 工作环境:
          (1)温度:-10~+55℃
          (2)相对湿度:≤85%
          (3)外磁场:≤5奥斯特
  • Accuracy: : grade 1.6
  • Output signal: 4~20mA DC,0~10mA AC
                                two or four wire system
  • Resistance value of load: 250Ω~350Ω
  • Power supply: 24V DC
  • Working environment:
         (1) Temperature: -10~+55℃
         (2) Relative humidity: ≤85%
         (3) External magnetic field: ≤5oresteds
        标记示例:YZTT-150B  产品电脑编码为 091206301
        差动远传压力真空表,输出信号为4~20mA DC。产品电脑编码详见
      《差动远传压力系列仪表选型指南》。
        Mark example: the product computer code for YZTT-150B is 091206301.
For differential motion remote transmitting pressure vacuum meter, the output signal is 4~20mA DC. for further information on computer code, please see the “Guide for type selection of differential motion remote
transmittingseries instruments and meters”
型号规格 Types and specifications
外形尺寸 External dimension
接口尺寸包括:M20×1.5;G1/2;1/2NPT
Joint dimension includes: M20x1.5, G1/2, and 1/2NPT.
订货须知:
      订货时须注明:型号、名称、精确度等级、测量范围。如特殊要求,订货时请注明技术要求。
无锡市宜兴双华仪表有限公司    联系人:  刘丽娜             联系方式:025-52771556
关 键 词: 差动远传压力表 不锈钢差动远传压力表
公司名称: 宜兴市双华仪表有限公司南京办事处
联 系 人: 刘丽娜
电  话: 025-52771556
手  机: 18912957256
地  址: 南京市江宁区禄口大街蓝天路85号
邮  编: 214221
双针压力表(Y-60/100/150)
膜片压力表(YP-100/150)
耐震电接点压力表(YTNXC-100/150)
定位型压力表(Y-100)
膜盒压力表(YE-150)
氧气压力表(YO-60/100/150)
不锈钢膜片压力表(YPF)
卫生型隔膜压力表(YTFP-60/100/150)
电接点压力表(YX\YXC)
差压表(YCBF100/150)
电阻远传压力表(YTZ)
隔膜压力表(YTP-100/150)
精密压力表(YB-150)
防腐耐高温压力表(YTW)
耐震压力表(YTN-60/100/150/200/250)
普通压力表(Y-60/100/150/200/250)
不锈钢膜盒压力表(YTFE100/150)
氨用压力表(YA)
安全型不锈钢压力表(YQF)
