产品名称: 防腐耐高温压力表
型  号: YTW
价  格:
YTW 系列耐酸、耐高温压力表
YTW Series Acid Resistant & High Temperature Resistant Pressure Meter
简介
      本仪表广泛应用于石油、化工、化纤、冶金、电站等工业部门中对耐酸、耐高温有较高要求的工艺流程中测量各中流体介质的压力。
      耐酸压力表的零件全部采用不锈钢材料制成,具有较强的耐腐蚀性能,适用于检测腐蚀性较强介质的压力和在外部腐蚀环境中使用。
      耐高温压力表的零件全部采用不锈钢材料制成,导压系统采用焊接工艺,具有优良的耐腐蚀性能。适用于对腐蚀性较强的介质和锡钎焊工艺不宜采用的高温介质或温度较高环境中的压力检测。
Brief introduction:
      This sort of meter is used to measure pressure of various liquid mediums, which are widely used in technique flows of industry departments, such as oil industry, chemical industry, chemical fiber, metallurgy, electricity station, etc, which require higher acid-resistant performance.
      Parts of acid resistant pressure meter are all made of stainless steel material, so the meters acid-resistant performance is much better and can be used to measure pressure of medium with powerful corrosion.
      Parts of high temperature resistant pressure meter are all made of stainless steel material, and welding technique is adopted in its pressure leading system, so the meters corrosion resistant performance is good. This sort of meters can be used to measure pressure of following mediums: medium with strong corrosion, high temperature medium that is not suitable for braze welding technique, or medium with high temperature.
主要技术参数 Principal technical parameters
型号
Model
精确度
Accuracy
使用环境条件
Condition of
applicable
environment
温度影响
Temperature influence
标度范围
Measuring ranges(MPa)
YTW-100
1.6、2.5
-40~70℃,
-40~+200℃
(耐高温),
相对湿度不大于85%
(High temperature
resistants)Relative
humidity: ≤85%
使用温度如偏离20±5℃
其温度附加误
差不大于0.4%/10℃
with temperature
departure of 20±5℃
the additional errorshall
be less than 0.4%/10℃.
0~0.6;0~1;0~1.6;
0~2.5;0~4;0~6;
0~10;0~25;0~40;0~60
YTW-150
0~0.6;0~1;0~1.6;
0~2.5;0~4;0~6;
0~10;0~25;0~40;0~60
       标记示例:YTS-150
       耐酸压力表,公称直径150mm。
       Marking instance:YTS-150  Production computer coding:1400060302
       Acid resistant pressure meter, nominal diameter is 150mm. For detail production computer coding information
接口尺寸 Joint dimension
材质说明 Material description
订货须知:
      订货时须注明:型号、名称、精确度等级、测量范围。如特殊要求,订货时请注明技术要求。
无锡市宜兴双华仪表有限公司    联系人:  刘丽娜             联系方式:025-52771556
关 键 词: 防腐耐高温压力表 不锈防腐耐高温压力表
公司名称: 宜兴市双华仪表有限公司南京办事处
联 系 人: 刘丽娜
电  话: 025-52771556
手  机: 18912957256
地  址: 南京市江宁区禄口大街蓝天路85号
邮  编: 214221
双针压力表(Y-60/100/150)
膜片压力表(YP-100/150)
耐震电接点压力表(YTNXC-100/150)
定位型压力表(Y-100)
膜盒压力表(YE-150)
氧气压力表(YO-60/100/150)
不锈钢膜片压力表(YPF)
卫生型隔膜压力表(YTFP-60/100/150)
电接点压力表(YX\YXC)
差压表(YCBF100/150)
电阻远传压力表(YTZ)
隔膜压力表(YTP-100/150)
精密压力表(YB-150)
耐震压力表(YTN-60/100/150/200/250)
差动远传压力表(YTT-150)
普通压力表(Y-60/100/150/200/250)
不锈钢膜盒压力表(YTFE100/150)
氨用压力表(YA)
安全型不锈钢压力表(YQF)
