产品名称: 氨用压力表
型  号: YA
价  格:
YA系列氨压力表YA
Series Ammonia Pressure Meter
简介
      氨压力表为氨专用仪表,用于测量对普通碳钢、合金结构钢、澳氏体类不锈钢及锡铅合金钎焊料无腐蚀作用,非结晶和凝固的氨气、氨液介质的压力。主要适用于化肥生产过程中设备或其他中用来测量氨的液体、气体或其混合物等的压力。
Brief Introduction:
      Ammonia pressure meter is a special meter for ammonia, used to measure various non-crystallized and solidified medium that have no corrosive action on common carbon system steel, alloy structural steel, Austenite stainless steel, or tinsel bar solder, principally applicable for measuring pressures of liquefied ammonia, gas, or other mixtures in cooling equipments in chemical fertilizer production.
结构原理
      仪表由导压系统(包括接头、弹簧管等)、传动机构、指示装置和外壳等组成。
当被测介质作用于弹簧管时,其管端产生相应的弹性变形——位移,经传动机构放大后,由指示装置在度盘上把被测压力指示出来。
Configuration principle
      This instrument consists of pressure pilot system (comprising joints, spring pipe, and so on), running gear, indicating device, and outer housing, etc.
When the medium acts on the spring pipe, corresponding elastic deformation or displacement occurs at the pipe end accordingly, which is amplified through running gear and displayed in indicating devices dial as the pressure being tested.
型号表示
      标记示例:YA-150ZT
      轴向前边氨用压力表,安装形式为轴向盘装式。
      产品电脑编码详见《氨用压力系列仪表选型指南》。
Model designations
      Mark example:  YA-150ZT
      For axial front pressure meter for ammonia, the installation form is dial-mounted in axial direction. For further information on computer code, please see the “Guide for type selection of ammonia series instruments and meters”
主要技术参数
  • 精确度:2.5级,1.6级
  • 使用环境条件:-40~70℃,相对湿度不大于90%
  • 温度影响:不大于0.4%/10℃(使用温度偏离20±5℃)
Principal technical parameters:
  • Accuracy:  1.6, 2.5 grades
  • Environmental condition in use: -40~70℃, relative humidity less than 90%
  • Temperature affect: no greater than 0.4%/10oC (with temperature departure of 20±5oC)
型号规格 Tpes and specifications
型号
  精度 1.6
 压力范围(MPa)
YA-100、100Z、100ZT
YA-150、150Z、150ZT
 00.100.1600.2500.400.60101.602.50406010016025040060
外形尺寸 External dimension
订货须知 Ordering instructions
       订货时须注明:、型号、名称、精确度、测量范围。如特殊要求,请注明技术要求。
       Ordering instructions: types, names, accuracy grades, and measuring ranges .must be clearly noted. In case of special requirements, technical requirements shall be clearly noted specifications on the back of the order on ordering goods.
订货须知:
      订货时须注明:型号、名称、精确度等级、测量范围。如特殊要求,订货时请注明技术要求。
无锡市宜兴双华仪表有限公司    联系人:  刘丽娜             联系方式:025-52771556
关 键 词: 氨用压力表
公司名称: 宜兴市双华仪表有限公司南京办事处
联 系 人: 刘丽娜
电  话: 025-52771556
手  机: 18912957256
地  址: 南京市江宁区禄口大街蓝天路85号
邮  编: 214221
双针压力表(Y-60/100/150)
膜片压力表(YP-100/150)
耐震电接点压力表(YTNXC-100/150)
定位型压力表(Y-100)
膜盒压力表(YE-150)
氧气压力表(YO-60/100/150)
不锈钢膜片压力表(YPF)
卫生型隔膜压力表(YTFP-60/100/150)
电接点压力表(YX\YXC)
差压表(YCBF100/150)
电阻远传压力表(YTZ)
隔膜压力表(YTP-100/150)
精密压力表(YB-150)
防腐耐高温压力表(YTW)
耐震压力表(YTN-60/100/150/200/250)
差动远传压力表(YTT-150)
普通压力表(Y-60/100/150/200/250)
不锈钢膜盒压力表(YTFE100/150)
安全型不锈钢压力表(YQF)
