产品名称: 膜盒压力表
型  号: YE-150
品介绍:
YE系列膜盒压力表
Theca Case Pressure Gauge
      膜盒压力表采用膜盒作为测压力敏感元件。测量对铜合金不起腐蚀作用、无爆炸危险的气体的微压和真空,广泛应用于锅炉通风、气体管道、燃烧装置及其它类似设备上。
      不锈钢膜盒压力表在普通膜盒压力表的基础上导压系统及外壳均采用了不锈钢材料。应用于耐腐蚀要求较高的工艺流程中对各种气体介质的压力和真空的测量。
      在膜盒压力表的基础上内部填充阻尼液和缓冲装置即成耐震膜盒压力表具有良好的耐震性能;适用于被测介质的压力有强烈脉冲变化或压力冲击和在生产工艺中经常突然卸荷的场合,以及环境震动较大的场所。
      膜盒压力表与相应的电气器件配套使用,即成为电接点膜盒压力表,可达到对被测压力系统实现预先设定的最大或最小压力值的双位自动控制和发信(报警)的目的。
      我公司生产的YE-70膜盒压力表批量出口美国。
Brief Introduction
      Theca box pressure gauges are used to measure micro pressure and negative pressure of gas that has no danger of explosion and does not erode alloy.       Adopting theca box as sense organ, the gauges are  widely applied to boiler ventilating, gas pipeline, burning device and other similar devices.
      Based on common theca box pressure gauges, stainless theca box pressure gauges introduce stainless material uesd in pressure leading system and crust. The gauges are not only suitable for measuring micro pressure and negative pressure of various gas medium in craftwork flow, which require higher performance of corrosion resistance, but also can be applied to boiler ventilating, gas pipeline, burning device and other similar devices.
构成示意图
结构原理  Structure
      仪表由导压系统(包括接头、膜盒等)、传动机构、指示装置、和外壳等组成(电接点膜盒压力表还包括磁助电接点装置、调节装置及航空插头等)。
      当被测介质作用于膜盒时,其管端产生相应的弹性变形——位移,经传动机构放大后,由指示装置在度盘上把被测压力指示出来。
      电接点膜盒压力表在指示装置将被测压力显示在仪表度盘上的同时,指针带动电接点装置的活动触点与设定指针上的触头(上限或下限)相接触的瞬时,控制系统接通或断开电路,以达到自动控制和发信报警的目的。
      The meter is composed of pressure leading system (including joint and theca box, etc), driving framework, indicating device and crust.(electric contact theca box dressart meter in dude,magnetism of electric conacd)
      When theca box is operated by measured medium, its end will produce elasticity distortiondisplacement. The displacement is enlarged by driving machine, and measured pressure value will be shown up by indicating device on meter dial.
When indicating device installed at electric contact theca box pressure meter shows the measured pressure value on meter dial, the pointer will simultaneously drive active contactor of electric contact device to meet the contactor (upper limit or lower limit) installed at the pointer. Thus control system will switch on or cut off circuit, and both aims of autocontrol and signal sending are all achieved
型号表示
标记示例:Y..
E-100-ZT 产品电脑编码为0030053402
      膜盒电接点压力表,表壳公称直径100mm,安装形式为轴向前边,轴向盘装式。详细电脑编码参照《膜盒压力系列仪表选型指南》
      Marking in stanceYJE-100-ZT  Production computer coding0030053402
Electric contact theca box pressure meter , meter dials nominal diameter is 100mm, installation mode is axial front, and installing mode is axial plate mounting. For detail production computer coding information, please refer to “Guide for type selection of theca box series instruments and meters”
主要技术参数
  • 精确度:1.6级、2.5
  • 使用环境温度:-25~55,相对湿度不大于85%
  • 温度影响:不大于0.4%/10
  • 抗工作环境振动:V.H.3
                            V.H.4
    (耐震膜盒压力表)
Principal technical parameters
  • Accuracy:  1.6 2.5 grades
  • Temperature of applicable circumstance: -25~55,relative
  • humidity not greater than 85%
  • Temperature influence: no more than 0.4%/10
  • Resistance against vibration of working environment: V.H. 3
                   V.H.4(shockproof theca box pressure meter
型号规格
型号
标度范围   Measuring ranges(kPa)
精确度
Accuracy
压力
Pressure
真空 Vacuum
压力真空(联程)
 Pressure vacuum (linkage)
YE-40
YE-50
YE-60
YE-70
YE-75
YE-100
YE-150
01.6
02.5
04
06
010
016
025
040
060
-1.60
-2.50
-40
-60
-100
-160
-250
-400
-600
-0.8+0.8
-1.2+1.2
-22
-3+3
-5+5
-8+8
-12+12
-20+20
-30+30
1.62.5
材质说明
零件名称
材质名称
普通膜盒压力表
不锈钢膜盒压力表
接液材质
黄铜HPb59-1
1Cr18Ni9不锈钢、304不锈钢、316L不锈钢
敏感元件
(膜盒)
铍青铜 QBe2
316L不锈钢
外壳
钢板08F
1Cr18Ni9不锈钢、304不锈钢
外形尺寸
型号model
D
D1
d0
A
B1
B
H
h
h1
L
d1
d2
40
Φ40
8
40
42
21
2
10
Φ5
Φ50
Φ68
Φ60
10.5
31.5
2
2
10
Φ5
Φ3.4
60
Φ60
Φ78
Φ70
12.3
59
56
31
2
2
14
Φ5
Φ3.4
70
Φ70
Φ85
Φ76
8
42
58
58
3
2
14
Φ5
Φ4.5
75
Φ75
Φ95
Φ86
8
42
56
38
3
2
14
Φ5
Φ4.5
100
Φ100
130
118
17
91
90
48.5
3
3
20
Φ6
Φ6
150
Φ150
180
165
17
95
118
54
3
3
20
Φ6
Φ6
型号model
D
D1
d0
L1
B
H
H1
H2
L
d
100
Φ100
130
118
91
90
84
17
48.5
20
20
150
Φ150
180
165
95
118
84
17
20
接口尺寸
型号model
接口尺寸
YJE-4050系列
M10×1;G1/8;1/8NPT;
YJE-607075系列
M14×1.51/4NPT;G1/4;
YJE-100150系列
M20×1.5G1/21/2NPT
电气电路连接示意图   Electrocircuit Connection Chart
接点装置电气参数及控制形式
触头功率
Contact
 power
最高工作电压
The maximal
 voltage
最大工作电流
The maximal
current
控制形式
Controlling
 type
30VA
(阻性负载)
220V DC
380V AC
1A
上下限、双上限、
双下限
订货须知:
      订货时须注明:型号、名称、精确度等级、测量范围。如特殊要求,订货时请注明技术要求。
电接点膜盒压力表的型号:YEXC+量程+连接方式
耐震膜盒压力表的型号:YNE+量程+连接方式
不锈钢膜盒可以参考  普通膜盒压力表的型号
无锡市宜兴双华仪表有限公司南京办事处    联系人:  刘丽娜             联系方式:025-52771556
关 键 词: 压力表 膜盒压力表
公司名称: 宜兴市双华仪表有限公司南京办事处
联 系 人: 刘丽娜
电  话: 025-52771556
手  机: 18912957256
地  址: 南京市江宁区禄口大街蓝天路85号
邮  编: 214221
双针压力表(Y-60/100/150)
膜片压力表(YP-100/150)
耐震电接点压力表(YTNXC-100/150)
定位型压力表(Y-100)
氧气压力表(YO-60/100/150)
不锈钢膜片压力表(YPF)
卫生型隔膜压力表(YTFP-60/100/150)
电接点压力表(YX\YXC)
差压表(YCBF100/150)
电阻远传压力表(YTZ)
隔膜压力表(YTP-100/150)
精密压力表(YB-150)
防腐耐高温压力表(YTW)
耐震压力表(YTN-60/100/150/200/250)
差动远传压力表(YTT-150)
普通压力表(Y-60/100/150/200/250)
不锈钢膜盒压力表(YTFE100/150)
氨用压力表(YA)
安全型不锈钢压力表(YQF)
