Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú SAϵÁлúеÊÖ±Û
²úÆ·Ãû³Æ£º SAϵÁлúеÊÖ±Û
ÐÍ ºÅ£º SAϵÁÐ
SA-Series
Servo Motor-Driven On Traverse-axis
==Mechanical Drawings==
Model No.
C
D
E
F
H
J
K
L
M
N
SA700
180
370
774
150
1000
1226
2125
1417
160
560
SA900
180
370
894
200
1120
1406
2305
1617
160
680
SA1200
157
393
1029
300
1240
1646
2545
1917
127
800
Model No.
E
F
H
J
K
L
N
Q
SA700S
774
150
1000
1226
2125
1417
380
1582
SA900S
894
200
1120
1406
2305
1617
500
1762
Model No.
E
F
H
J
K
L
M
N
SA700D
764
150
1000
1226
2125
1125
120
510
SA900D
884
200
1120
1406
2305
1225
120
630
SA1200D
1013
300
1240
1646
2545
1375
110
750
Model No.
E
F
H
J
K
L
M
N
P
Q
SA700DS
764
150
1000
1226
2125
1125
120
300
195
1155
SA900DS
884
200
1120
1406
2305
1225
120
420
195
1255
SA1200DS
1013
300
1240
1646
2545
1375
110
505
226
1405
Power Source: AC 110V or 220V SINGLE PHASE
==Technical Specifications==
AC brushless servomotor
 drive on traverse axis,
 accuracy within +0.1mm.
 Available on 220V or
 110V single phase,
 please specified.
  Hand-Held Controller :
One key one function operational panel with large LCD
screen, provides you with multiple languages. Operated with
conversational control method for easy and user-friendly operation.
Application :
8 Spare Output and 5 Spare Input terminals for coordinate with other peripheral equipment.
Parts Removal :
Easy maneuver with In-Mold traverse movement, it can reach unconventional path to take out difficult De-Mold parts to reduce the cost of End Of Arm Tooling.
Parts drop off :
a) 9 programmable Cycle Position with 2 areas total of 18 points.
b) Added extra Cross Axis Setting can reach 36 points.
c) Rapid Equal Pitch Setting can reach 99 points.
d) Added extra Cross Axis Setting can reach 198 points.
Peripheral equipment :
Connected together with conveyor, spray mist, shear cutter, sensor and
second operation machine to become an automation system.
Inspection :
a) Reject: When detecting a reject signal from Injection Molding Machine, robot can drop the reject parts in designated point.
b) Inspection: By setting the counter quantity, robot can pick the parts into the inspection point.
c) Test Mold: By setting the counter quantity, robot can pick the test mold parts into the reject point and not set into counter.
d) Parts counter: By setting the counter quantity, robot will count good parts to reach this quantity and stop the operation.
¹«Ë¾Ãû³Æ£º ÉϺ£¾«Èñ¹ãÓö¯Á¦¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 69220577-1302 / ÔøÇ¿
ÊÖ»ú£º
µØ Ö·£º ÉϺ£ÊÐÇàÆÖ¹¤˜Iˆ@…^Öñӯ·128Ì–
ÓÊ ±à£º 201700
Ö÷ Ò³£º www.apexdyna.cn
  • MTϵÁÐSmall Traversing Robots
  • SAϵÁлúеÊÖ±Û
  • SBϵÁлúеÊÖ±Û
  • SCϵÁлúеÊÖ±Û
  • SC750-950Series»úеÊÖ±Û
  • SEϵÁлúеÊÖ±Û
  • SHϵÁлúеÊÖ±Û
  • SHD-DMϵÁлúеÊÖ±Û
  • STϵÁлúеÊÖ±Û
  • YSϵÁлúеÊÖ±Û
