产品名称: Atom Mini ITX 工業主板
型  号: DT-K1130
Specification:
CPU
 Pineview-D/M (Atom D410/D510/N450) processor
System Memory
1x200pin SO-DIMM Socket Dual Channel DDR2 533/677 SDRAM up to 2GB
Chipset
 Intel Pineview + ICH8M
BIOS
 Award 16 MB BIOS
Ethernet
 One Realtek PCI-E Gigabit LAN
 Second Realtek PCI-E Gigabit LAN (Option)
Audio
 Built-in Intel® High Definition Audio
 Audio Codec:VIA VT1708A HDA Codec
 Audio Interface:Mic-in, Line-in, Line-out
Display
 VGA
 One Channel 18bit LVDS
I/O Interface
 Chipset:Winbond W83697HG
 Serial Port (RS232/422/485):2 x External D-SUB 9-pin Connectors for COM1/COM2)
   Serial erial Port (RS232):4 x Internal Box Header for COM3/COM4/COM5/COM6) (Option)
 Universal Serial Bus 2.0:10 (4 x Front, 4 x Rear, 2 x Internal)
 PS/2:One 2L Mini-Din Connector for Keyboard and Mouse
 Compact Flash:1 x Compact Flash connector
 SATA:2 x SATA II
 GPIO:4 in / 4 out
 IDE:One 44pin Box Header for IDE Device
Watchdog Timer
 Reset : Generates system reset; 256 levels
H/W Status Monitor
 Monitoring CPU temperature, and voltage status.
Expansion Slot
 One PCI Slot
Dimensions
 170 mm (L) x 170 mm (W) -> ATX Power
 210 mm (L) x 170 mm (W) -> 12V/5A, 60Watt DC Adaptor
关 键 词: Atom Mini-ITX Pineview
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
AMD LX800 工業(DT-M2100)
