产品名称: 3.5 VIA 計算機系統
型  号: DT-B3100
CPU
l          VIA Eden-V4 400MHz~1.5GHz Processor
l          VIA C7 1.0GHz~2.0GHz Processor
System Memory
l          1 x 200-pin SODIMM Socket for DDR2 533 SDRAM up to 1GB
Chipset
l          VIA CX700M Chipset
BIOS
l          Award system BIOS
l          Supports “Power on” after power failure
l          Supports Wake on LAN
l          4MB flash ROM
LAN
l          On Board One Realtek RTL8110SC Chip to support 10/100/1000Mbps Ethernet
l          1 x RJ-45 connector
Audio
l          Audio Codec:VIA VT1708A HDA Codec
l          Audio Interface:Mic-in, Line-in, Line-out
Display
l          1 x DVI-I connector (VGA & DVI)
l          1 x 18/24bit LVDS connector
I/O Interface
l          1 x External D-SUB 9-pin Connectors for COM1(RS232), 1 x Internal pin header for COM2(RS232/422/485)
l          Universal Serial Bus: Supports 6 x USB2.0 connector (Front x 4, Rear x 2)
l          PS/2: One Mini-Din connector for keyboard and mouse
l          On-board One compact flash Socket(Type-II socket)
l          Serial-ATA Interface: Two SATA connector
Watchdog Timer
l          Reset : Generates system reset; 256 levels
H/W Status Monitor
l          Monitoring CPU temperature, and voltage status.
On-board RTC
l          Internal RTC supporting by CX700M
Expansion Slot
l          One PC-104 Slot
System Power
l          ATX Power
Environment
l          System Level Operating Temperature: 0oC ~40oC
l          Storage Temperature: -20oC ~80oC
Dimensions
l          166 x 122 mm
关 键 词: VIA EDEN C7
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
