产品名称: Core 2 Quad 四核心工控機
型  号: DT-BMX35Q
Specification
CPU
LGA775 socket for Intel® Core™2 Quad Core™2 Duo Processors with 45nm process technology
FSB
1333 / 1066 / 800 MHz
System Memory
Four 240-pin DIMM sockets support up to 8 GB Dual Channel DDR2 800/667/533 SDRAM
Chipset
Intel® Q35 GMCH / ICH9DO
Expansion
One PCI Express X16, one PCI Express X 1, two PCI (PCI Rev. 2.3 compliant)
IEEE 1394
LSI FW3227 support 2 IEEE1394 ports
Wake UP Mode
LAN mode (PME / RPL)
I/O
 1x EIDE 66/100/133, 6 x SATA, 1 x LPT, 1 x RS-232, 1x K/B, 1 x Mouse, 1 x FDD
12 USB
Display
Chipset
Intel Q35 GMCH integrated Graphics Media Accelerator 3100
Display Memory:
Intel DVMT 4.0 supports up to 384MB video memory
Resolution
2048 x 1536 @ 32 bpp (75Hz)
LVDS
Through ADD2 LVDS Card
DVI
Through ADD2 DVI Card
HDMI
Through ADD2 HDMI Card
Secondary VGA
Through ADD2 VGA Card
Audio
Realtek ALC888 with multiple streaming
Mic in, Line in, CD Audio in, Line out
Ethernet
Intel 82566DM Gigabit LAN
Back Panel I/O Port
1 x Parallel port / 1 x COM Port / 1 x IEEE1394a
1 x RJ45 port / 4 x USB 2.0/1.1 / Audio Jack (6 ports)
International I/O Connector
4 x USB connectors support additional 8 USB ports
1 x IDE connector
6 x SATA connectors
1 x IEEE1394a connector
Mechanical & Environmental
Power Supply
300W Micro ATX active PFC internal Power Supply
Dimention:
337(W) x 339.8(D) x 136(H)mm
13.3(W) x 13.4(D) x 5.4(H) inches
Temperature
Operating: 0℃ ~ 40℃
Storage: -20℃ ~ 80℃
Relative Humidity
0% ~ 90%
Gross Weight
9.2kgs / 20.3lbs
Cooling System
8cm low noise ball bearing fan
关 键 词: Core 2 Quad
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
