²úÆ·Ãû³Æ£º
Core 2 Duo ëpºËÐŤ¿Ø™C
ÐÍ ºÅ£º
DT-B1104S
Specification
CPU
- Intel® Core 2 Duo/ Core Duo/ Core Solo mobile Processor
Chipset
- North Bridge: Intel GME965
Memory
- 2 x 200pin SO-DIMM Socket Support Dual Channel DDR2 533/667 SDRAM up to 4GB
BIOS
Display
- Intel GME965 Integrated Graphics Media Accelerator X3100, supports 384MB video memory
- Resolution: 2048*1536 @32bpp (@60Hz)
- Dual Display: CRT + LVDS or CRT + DVI-D
- LVDS: 18/24-bit Dual-channel LVDS
- DVI: Chrontel CH7307C DVI transmitter up to 165MB pixels/second
Audio
- AC97 2.0 CODEC compatible
- 1 x Mic-in£¬1 x Line-in£¬1 x Line-out
- TPA3005D2 5W Stereo Amplifier
Ethernet
- Controller: Realtek RTL8111B
- 2 x Gigabit Ethernet Port
I/O Interface
- SSD: 1 x Type II Compact Flash Connector
- IDE connector£º1 x 40pin IDE Connector
- SATA: 3 x Serial ATA Connector
- PS/2 Port £º1 x Keyboard, 1 x Mouse
- USB 2.0 Port£º2 x Front, 4 x Rear
- Serial Port£º4 x 1L D-SUB 9pin connector (Power output)
- DIO: 8-bit General Purpose I/O for DI & DO
Power
- 125W Internal Power Supply
- Reset: 1 sec ~ 255 min. and 1 sec or 1 min/step
- Monitoring CPU temperature, voltage, and cooling fan Status.
- Auto throttling control when CPU overheats
Mechanical and Environment
Dimensions
- 310mm ( L ) X 255mm ( W ) X 100mm ( H )
Housing
Temperature
Relative Humidity
Odering Information:
DT-B1104S
