产品名称: Core 2 Duo 工業計算機
型  号: DT-BMX945G
Specifications
CPU
Support Intel LGA775 CPU Socket, Core 2 Duo / Core Duo
/ P4 / Celeron-D CPU
FSB: 1066 / 800 / 533 Mhz
System Memory
4 x 240pin DIMM Socket Support
Dual Channel DDRII 533/667 up to 4GB
Chipset
Intel® 945G GMCH + ICH7
BIOS
Award 4MB Flash BIOS
Ethernet
1 x LAN Intel 82573 Gigabit
Audio
Codec: Realtek ALC882, 7.1Ch.
Audio Interface: 1 x Mic-in; 1 x Line-in; 1 x Line-out;
1 x CD Audio-in
Display
Chipset: Intel® integrated GMA 950
Display Memory: Intel DVMT 3.0 supports 224MB
Resolution: 2048 x 1536 @32bpp (60Hz)
External VGA Interface: PCI-E x16 VGA Interface
HDMI: HDMI Card (Optional)
LVDS: LVDS Card (Optional)
DVI: DVI Card (Optional)
Secondary VGA: VGA Card (Optional)
I/O Chip
Chipset:Winbond W83627EHG-A
Back Panel I/O Interface
1 x PS/2 Keyabord; 1 x PS/2 Mouse; 1 x PLT Port;
1 x COM; 1 x VGA Port; 1 x LAN RJ45;
4 x USB Ports (2.0/1.1); 7.1Ch (6 jacks)
Internal I/O Interface
2 x USB pin header supports additional 4 USB ports;
1 x IDE; 1 x COM; 1 x TPM; 4 x SATA; 1 x FDD;
One PCI-E x 16 slot; One PCI-E x1 slot;
2 PCI slots (PCI Rev. 2.2 compliant)
Driver Bays
One 5.25” External Driver Bays
One 3.5” Internal HDD Bay
Watchdog Timer
Reset: 1 sec. ~ 255 min. and 1 sec. or 1 min. / step
H/W Status Monitor
Monitoring CPU temperature, voltage and
cooling fan status.  Auto throttling control
when CPU overheats.
Mechanical & Environment
Dimensions
337(W) x 339.8(D) x 136(H)mm
13.3(W) x 13.4(D) x 5.4(H) inches
Housing
Heavy Duty Steel
Temperature
Operating: 0℃ ~ 40℃
Storage: -20℃ ~ 80℃
Relative Humidity
0% ~ 90%
Gross Weight
9.2kgs / 20.3lbs
Expansion
Support up to 4 slots
Power Supply
300W Micro ATX active PFC internal Power Supply
Cooling System
8cm low noise ball bearing fan
关 键 词: Core 2 Duo 工控機
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 工(DT-B1104)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
